cannot build a static library
Hi all,
this might be a trivial question but …
I’ve got several fortran files that I used to link into a static library with an other compiler.
With pgf90 when I try to link these objects into a lib.a file I always have this error message :
/usr/local/pgi/linux86-64/6.1/lib/f90main.o: In function main': f90main.c:(.text+0x42): undefined reference to MAIN_’
I tried to pass -Mnomain but I stil have an error message :
/usr/lib64/crt1.o: In function _start': ../sysdeps/x86_64/elf/start.S:109: undefined reference to main’
I succeeded in building a shared library using -fPIC during compilation and -shared during linking, but I need a static one.
There’s certainly a switch I’m missing … any ideas?
Will.
Hi Will,
To build static libraries, use the “ar” utility. For example:
% pgf90 -c [optimization flags] -o foo.o foo.c
% pgf90 -c [optimization flags] -o bar.o bar.c
% ar rcu libmylib.a foo.o bar.o
Hope this helps,
Mat
it helps!
thanks a lot.
Will
