using:
Jetson Orin Nano
Jetpack 5.1.2
L4T 35.4.1
Ubuntu 20.04
I am attempting to build the following pipeline:
video source → tee → video sink
|__-> appsink
each of the pipeline with just one sink, even with the tee works:
# TEE videotestsrc - filesink
gst-launch-1.0 videotestsrc ! tee name=t ! \
queue ! nvvidconv ! 'video/x-raw, format=(string)RGBA' ! nvvidconv ! 'video/x-raw, format=(string)NV12' ! x264enc speed-preset=fast ! h264parse ! qtmux ! filesink location=demoVideos/videotestsrc.mov -e
# TEE videotestsrc - appsink
queue ! nvvidconv ! 'video/x-raw, format=(string)RGBA' ! appsink -e
However, when attaching both sinks to the tee, i’m getting ‘queue_dataflow gstqueue.c:1516:gst_queue_loop: queue is empty’ using GST_DEBUG=3,queue_dataflow:5
queue ! nvvidconv ! 'video/x-raw, format=(string)RGBA' ! nvvidconv ! 'video/x-raw, format=(string)NV12' ! x264enc speed-preset=fast ! h264parse ! qtmux ! filesink location=demoVideos/videotestsrc.mov t. ! \
i’ve tried:
- appsink drop=true
- increasing queue max-size-buffer
- fakesink instead of app sink
Thank you
The nvvidconv supports the use-cases:
video/x-raw(memory:NVMM) ! nvvidconv ! video/x-raw
video/x-raw ! nvvidconv ! video/x-raw(memory:NVMM)
video/x-raw(memory:NVMM) ! nvvidconv ! video/x-raw(memory:NVMM)
In your use-case, you don’t need frame data in NVMM buffer, so you may use videoconvert plugin.
good to know to use videoconvert, if i don’t need the buffer to stay in the NVMM
However, this still doesn’t solve the problem, changing the pipeline to the following still doesn’t work
queue ! videoconvert ! 'video/x-raw, format=(string)RGBA' ! videoconvert ! 'video/x-raw, format=(string)NV12' ! x264enc speed-preset=fast ! h264parse ! qtmux ! filesink location=test/videotestsrc.mov t. ! \
queue ! videoconvert ! 'video/x-raw, format=(string)RGBA' ! appsink -e
Not sure if appsink works in gst-launch-1.0 command. Generally it is used in C/python code for accessing GstBuffer. Please try with fakesink.
Hi, i tried in python as well, both fakesink and appsink did not work, could you please try on your end
