Cannot build opencv 4.8.0 with nvidia docker
HI,
I don’t know if this is the right place.
I have been trying to build opencv 4.8 on nvcr.io/nvidia/jetpack-linux-aarch64-crosscompile-x86:5.1.2 based image.
When i use the attached cmake file
aarch64-toolchain-jetson.cmake.txt (2.1 KB)
with the below cmake command :
cmake …/…/… -DBUILD_LIST=core,imagecodecs,imgproc,videoio,calib3d,highgui -DBUILD_opencv_apps=OFF \
-DBUILD_SHARED_LIBS=OFF
-DBUILD_EXAMPLES=OFF
-DBUILD_PERF_TESTS=OFF
-DBUILD_TESTS=OFF
-DBUILD_DOCS=OFF
-DENABLE_NEON=OFF
-DCMAKE_BUILD_TYPE=Release
-DCMAKE_TOOLCHAIN_FILE=/nvidia-orin/build_tools/cmake/aarch64-toolchain-jetson.cmake
-DCMAKE_INSTALL_PREFIX=“/usr/local/opencv”
-DFFMPEG_DIR=“/usr/local/ffmpeg” -DWITH_FFMPEG=ON -DFFMPEG_INCLUDE_DIRS=“/usr/local/ffmpeg/include” -DOPENCV_FFMPEG_SKIP_BUILD_CHECK=ON -DWITH_CAROTENE=OFF -DCUDA_ROOT=“/usr/local/cuda/targets/aarch64-linux” -DWITH_CUDA=ON -D OPENCV_DNN_CUDA=ON -D OPENCV_EXTRA_MODULES_PATH=/tmp/opencv_contrib-4.8.0/modules/ --fresh
i get the below error:
CMake Error at CMakeLists.txt:160 (message):
CMake fails to determine the bitness of the target platform.
Please check your CMake and compiler installation. If you are cross-compiling then ensure that your CMake toolchain file correctly sets the compiler details.
How can i fix it?
It also happens with opencv 4.2.0
Thanks,
Oren
Moved to Jetson AGX Orin forum
Could you remove the below line and try it again?
It works, but it will not compile to aarch64.
I am not building on the board, but i want to cross-compile to aarach16, that’s why i am using the docker and -DCMAKE_TOOLCHAIN_FILE
Thanks,
Oren
Have you installed the cross-compile toolchain? (ex. g+±aarch64-linux-gnu)
Its apart of the docker image.
It’s already in the docker image at /usr/bin
The toolchain is at /usr/aarch64-linux-gnu
The toolchain does not contain lib64:
ls /usr/aarch64-linux-gnu/
bin include lib
But event when i copy lib to lib 64 it didnt help
Do you use our cross-compile container?
If not, could you give it a try?
HI, yes.
I am using nvcr.io/nvidia/jetpack-linux-aarch64-crosscompile-x86:5.1.2
Thanks,
Oren
We need to check it further.
Will share more information with you later.
Thanks for your patience.
We can build OpenCV 4.8 within the cross-compile container.
Please give it a try:
Host install_opencv4.8.0_Jetson.sh (2.5 KB)
$ sudo docker run -it --privileged --net=host -v /dev/bus/usb:/dev/bus/usb -v ${WORKSPACE}:/workspace nvcr.io/nvidia/jetpack-linux-aarch64-crosscompile-x86:5.1.2
$ chmod +x install_opencv4.8.0_Jetson.sh
$ ./install_opencv4.8.0_Jetson.sh
Copy workspace/opencv-4.8.0/release to device
Device
$ cd release
$ sudo make install && sudo ldconfig
$  opencv_version -v
General configuration for OpenCV 4.8.0 =====================================
  Version control:               58f22c2-dirty
  Extra modules:
    Location (extra):            /l4t/workspace/opencv_contrib-4.8.0/modules
    Version control (extra):     58f22c2-dirty
  Platform:
    Timestamp:                   2023-10-23T06:42:37Z
    Host:                        Linux 5.4.0-150-generic x86_64
    Target:                      Linux 1 aarch64
