hi.
I got some trace log when I was trying to capture frames on my custom module.
But I cannot understand the log.
Please advise me what is wrong.
Here are trace log and dmesg log and some information below.
ubuntu@ubuntu-desktop:~$ v4l2-ctl --stream-mmap --verbose
VIDIOC_QUERYCAP: ok
VIDIOC_REQBUFS: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_QUERYBUF: ok
VIDIOC_QBUF: ok
VIDIOC_STREAMON: ok
^C
[ 122.795748] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 122.802272] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 123.020019] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 123.026697] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 123.243874] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 123.250467] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 123.463656] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 123.470158] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 123.683617] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 123.690052] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 123.903575] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 123.909999] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 124.123639] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 124.130220] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 124.351520] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 124.357994] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 124.571558] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 124.578048] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 124.791538] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 124.798017] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 125.011464] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 125.017938] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
root@ubuntu-desktop:/home/ubuntu# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 529/529 #P:6
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/3:0-30 [003] .... 151.600376: rtos_queue_peek_from_isr_failed: tstamp:5014021154 queue:0x0b4b4500
kworker/3:0-30 [003] .... 151.772310: rtos_queue_peek_from_isr_failed: tstamp:5019021123 queue:0x0b4b4500
kworker/3:0-30 [003] .... 151.940307: rtos_queue_peek_from_isr_failed: tstamp:5024021167 queue:0x0b4b4500
kworker/3:0-30 [003] .... 152.108361: rtos_queue_peek_from_isr_failed: tstamp:5029021197 queue:0x0b4b4500
kworker/3:0-30 [003] .... 152.276345: rtos_queue_peek_from_isr_failed: tstamp:5034021192 queue:0x0b4b4500
kworker/3:0-30 [003] .... 152.388304: rtos_queue_peek_from_isr_failed: tstamp:5039021174 queue:0x0b4b4500
kworker/3:0-30 [003] .... 152.556291: rtos_queue_peek_from_isr_failed: tstamp:5044021157 queue:0x0b4b4500
kworker/3:0-30 [003] .... 152.724262: rtos_queue_peek_from_isr_failed: tstamp:5049021188 queue:0x0b4b4500
kworker/3:0-30 [003] .... 152.892254: rtos_queue_peek_from_isr_failed: tstamp:5054021188 queue:0x0b4b4500
kworker/3:0-30 [003] .... 153.060230: rtos_queue_peek_from_isr_failed: tstamp:5059021178 queue:0x0b4b4500
kworker/3:0-30 [003] .... 153.228233: rtos_queue_peek_from_isr_failed: tstamp:5064021212 queue:0x0b4b4500
kworker/3:0-30 [003] .... 153.396214: rtos_queue_peek_from_isr_failed: tstamp:5069021215 queue:0x0b4b4500
kworker/3:0-30 [003] .... 153.508200: rtos_queue_peek_from_isr_failed: tstamp:5074021221 queue:0x0b4b4500
kworker/3:0-30 [003] .... 153.676137: rtos_queue_peek_from_isr_failed: tstamp:5079021205 queue:0x0b4b4500
kworker/3:0-30 [003] .... 153.844110: rtos_queue_peek_from_isr_failed: tstamp:5084021219 queue:0x0b4b4500
kworker/3:0-30 [003] .... 154.012106: rtos_queue_peek_from_isr_failed: tstamp:5089021224 queue:0x0b4b4500
kworker/3:0-30 [003] .... 154.180146: rtos_queue_peek_from_isr_failed: tstamp:5094021265 queue:0x0b4b4500
kworker/3:0-30 [003] .... 154.348123: rtos_queue_peek_from_isr_failed: tstamp:5099021249 queue:0x0b4b4500
kworker/3:0-30 [003] .... 154.516126: rtos_queue_peek_from_isr_failed: tstamp:5104021262 queue:0x0b4b4500
kworker/3:0-30 [003] .... 154.628103: rtos_queue_peek_from_isr_failed: tstamp:5109021285 queue:0x0b4b4500
kworker/3:0-30 [003] .... 154.796089: rtos_queue_peek_from_isr_failed: tstamp:5114021283 queue:0x0b4b4500
kworker/3:0-30 [003] .... 154.964003: rtos_queue_peek_from_isr_failed: tstamp:5119021319 queue:0x0b4b4500
kworker/3:0-30 [003] .... 155.132055: rtos_queue_peek_from_isr_failed: tstamp:5124021337 queue:0x0b4b4500
kworker/3:0-30 [003] .... 155.299997: rtos_queue_peek_from_isr_failed: tstamp:5129021308 queue:0x0b4b4500
kworker/3:0-30 [003] .... 155.468047: rtos_queue_peek_from_isr_failed: tstamp:5134021314 queue:0x0b4b4500
kworker/3:0-30 [003] .... 155.584016: rtos_queue_peek_from_isr_failed: tstamp:5139021289 queue:0x0b4b4500
kworker/3:0-30 [003] .... 155.751987: rtos_queue_peek_from_isr_failed: tstamp:5144021310 queue:0x0b4b4500
kworker/3:0-30 [003] .... 155.919984: rtos_queue_peek_from_isr_failed: tstamp:5149021325 queue:0x0b4b4500
kworker/3:0-30 [003] .... 156.031974: rtos_queue_peek_from_isr_failed: tstamp:5151600560 queue:0x0b4b4500
v4l2-ctl-8745 [000] .... 163.762841: tegra_channel_open: vi-output, imx556 2-0057
v4l2-ctl-8745 [002] .... 163.764375: tegra_channel_set_power: imx556 2-0057 : 0x1
v4l2-ctl-8745 [002] .... 163.764395: camera_common_s_power: status : 0x1
v4l2-ctl-8745 [002] .... 163.769282: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l2-ctl-8745 [002] .... 163.769291: csi_s_power: enable : 0x1
v4l2-ctl-8745 [002] .... 163.778288: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 20
vi-output, imx5-8746 [000] .... 163.778515: tegra_channel_set_stream: enable : 0x1
vi-output, imx5-8746 [000] .... 163.780373: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x1
vi-output, imx5-8746 [000] .... 163.780376: csi_s_stream: enable : 0x1
vi-output, imx5-8746 [000] .... 163.780413: tegra_channel_set_stream: imx556 2-0057 : 0x1
kworker/3:0-30 [003] .... 163.783324: rtos_queue_peek_from_isr_failed: tstamp:5395149240 queue:0x0b4b4500
kworker/3:0-30 [003] .... 163.783330: rtcpu_start: tstamp:5395150856
kworker/3:0-30 [003] .... 163.783333: rtos_queue_send_from_isr_failed: tstamp:5395162189 queue:0x0b4a7258
kworker/3:0-30 [003] .... 163.783334: rtos_queue_send_from_isr_failed: tstamp:5395162294 queue:0x0b4aad68
kworker/3:0-30 [003] .... 163.783335: rtos_queue_send_from_isr_failed: tstamp:5395162403 queue:0x0b4ac998
kworker/3:0-30 [003] .... 163.783337: rtos_queue_send_from_isr_failed: tstamp:5395162507 queue:0x0b4ae518
kworker/3:0-30 [003] .... 163.783338: rtos_queue_send_from_isr_failed: tstamp:5395162608 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 163.783339: rtos_queue_send_from_isr_failed: tstamp:5395162709 queue:0x0b4b0098
kworker/3:0-30 [003] .... 163.783341: rtos_queue_send_from_isr_failed: tstamp:5395162810 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 163.783342: rtos_queue_send_from_isr_failed: tstamp:5395162911 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 163.783344: rtos_queue_send_failed: tstamp:5395163375 queue:0x0b4a7258
kworker/3:0-30 [003] .... 163.783345: rtos_queue_send_from_isr_failed: tstamp:5395166666 queue:0x0b4a7258
kworker/3:0-30 [003] .... 163.783347: rtos_queue_send_from_isr_failed: tstamp:5395166770 queue:0x0b4aad68
kworker/3:0-30 [003] .... 163.783348: rtos_queue_send_from_isr_failed: tstamp:5395166879 queue:0x0b4ac998
kworker/3:0-30 [003] .... 163.783349: rtos_queue_send_from_isr_failed: tstamp:5395166981 queue:0x0b4ae518
kworker/3:0-30 [003] .... 163.783351: rtos_queue_send_from_isr_failed: tstamp:5395167083 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 163.783352: rtos_queue_send_from_isr_failed: tstamp:5395167184 queue:0x0b4b0098
kworker/3:0-30 [003] .... 163.783353: rtos_queue_send_from_isr_failed: tstamp:5395167285 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 163.783354: rtos_queue_send_from_isr_failed: tstamp:5395167387 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 163.783356: rtos_queue_send_failed: tstamp:5395168268 queue:0x0b4a7258
kworker/3:0-30 [003] .... 163.955366: rtos_queue_peek_from_isr_failed: tstamp:5400149587 queue:0x0b4b4500
vi-output, imx5-8746 [000] .... 164.041338: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 20
vi-output, imx5-8746 [000] .... 164.041376: tegra_channel_capture_frame: sof:-549620695332.-269031629120
kworker/3:0-30 [003] .... 164.067319: rtos_queue_send_from_isr_failed: tstamp:5403335885 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.067328: rtos_queue_send_from_isr_failed: tstamp:5403336017 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.067331: rtos_queue_send_from_isr_failed: tstamp:5403336138 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.067333: rtos_queue_send_from_isr_failed: tstamp:5403336257 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.067336: rtos_queue_send_from_isr_failed: tstamp:5403336374 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.067338: rtos_queue_send_from_isr_failed: tstamp:5403336492 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.067340: rtos_queue_send_from_isr_failed: tstamp:5403336607 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.067343: rtos_queue_send_from_isr_failed: tstamp:5403336724 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.067347: rtos_queue_send_failed: tstamp:5403337602 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.067351: rtcpu_vinotify_event: tstamp:5403338682 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:1 vi_tstamp:5403337092 data:0x08000000
kworker/3:0-30 [003] .... 164.067353: rtos_queue_send_from_isr_failed: tstamp:5403350243 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.067356: rtos_queue_send_from_isr_failed: tstamp:5403350361 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.067358: rtos_queue_send_from_isr_failed: tstamp:5403350493 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.067360: rtos_queue_send_from_isr_failed: tstamp:5403350627 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.067363: rtos_queue_send_from_isr_failed: tstamp:5403350750 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.067365: rtos_queue_send_from_isr_failed: tstamp:5403350867 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.067368: rtos_queue_send_from_isr_failed: tstamp:5403350982 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.067370: rtos_queue_send_from_isr_failed: tstamp:5403351099 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.067372: rtos_queue_send_failed: tstamp:5403351586 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.067375: rtos_queue_send_from_isr_failed: tstamp:5403360476 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.067377: rtos_queue_send_from_isr_failed: tstamp:5403360594 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.067379: rtos_queue_send_from_isr_failed: tstamp:5403360714 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.067381: rtos_queue_send_from_isr_failed: tstamp:5403360832 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.067384: rtos_queue_send_from_isr_failed: tstamp:5403360948 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.067386: rtos_queue_send_from_isr_failed: tstamp:5403361065 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.067388: rtos_queue_send_from_isr_failed: tstamp:5403361182 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.067390: rtos_queue_send_from_isr_failed: tstamp:5403361297 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.067393: rtos_queue_send_failed: tstamp:5403361777 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.067395: rtos_queue_send_from_isr_failed: tstamp:5403374387 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.067397: rtos_queue_send_from_isr_failed: tstamp:5403374508 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.067400: rtos_queue_send_from_isr_failed: tstamp:5403374627 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.067402: rtos_queue_send_from_isr_failed: tstamp:5403374745 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.067404: rtos_queue_send_from_isr_failed: tstamp:5403374862 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.067407: rtos_queue_send_from_isr_failed: tstamp:5403374977 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.067409: rtos_queue_send_from_isr_failed: tstamp:5403375093 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.067411: rtos_queue_send_from_isr_failed: tstamp:5403375208 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.067413: rtos_queue_send_failed: tstamp:5403376721 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.067416: rtcpu_vinotify_event: tstamp:5403377801 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:1 vi_tstamp:5403376055 data:0x00000001
kworker/3:0-30 [003] .... 164.067418: rtcpu_vinotify_event: tstamp:5403377970 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5403376056 data:0x00000001
kworker/3:0-30 [003] .... 164.123362: rtos_queue_peek_from_isr_failed: tstamp:5405149600 queue:0x0b4b4500
vi-output, imx5-8746 [003] .... 164.261701: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 20
vi-output, imx5-8746 [003] .... 164.261824: tegra_channel_capture_frame: sof:-549620695332.-269031629120
kworker/3:0-30 [003] .... 164.291392: rtos_queue_peek_from_isr_failed: tstamp:5410149606 queue:0x0b4b4500
kworker/3:0-30 [003] .... 164.291400: rtos_queue_send_from_isr_failed: tstamp:5410208358 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.291403: rtos_queue_send_from_isr_failed: tstamp:5410208483 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.291406: rtos_queue_send_from_isr_failed: tstamp:5410208603 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.291408: rtos_queue_send_from_isr_failed: tstamp:5410208737 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.291411: rtos_queue_send_from_isr_failed: tstamp:5410208868 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.291413: rtos_queue_send_from_isr_failed: tstamp:5410208992 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.291415: rtos_queue_send_from_isr_failed: tstamp:5410209113 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.291417: rtos_queue_send_from_isr_failed: tstamp:5410209235 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.291421: rtos_queue_send_failed: tstamp:5410209913 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.291423: rtos_queue_send_from_isr_failed: tstamp:5410229910 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.291426: rtos_queue_send_from_isr_failed: tstamp:5410230031 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.291428: rtos_queue_send_from_isr_failed: tstamp:5410230149 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.291430: rtos_queue_send_from_isr_failed: tstamp:5410230268 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.291432: rtos_queue_send_from_isr_failed: tstamp:5410230388 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.291435: rtos_queue_send_from_isr_failed: tstamp:5410230508 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.291437: rtos_queue_send_from_isr_failed: tstamp:5410230629 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.291439: rtos_queue_send_from_isr_failed: tstamp:5410230748 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.291441: rtos_queue_send_failed: tstamp:5410231267 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.291444: rtos_queue_send_from_isr_failed: tstamp:5410245905 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.291446: rtos_queue_send_from_isr_failed: tstamp:5410246044 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.291448: rtos_queue_send_from_isr_failed: tstamp:5410246163 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.291451: rtos_queue_send_from_isr_failed: tstamp:5410246286 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.291453: rtos_queue_send_from_isr_failed: tstamp:5410246403 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.291455: rtos_queue_send_from_isr_failed: tstamp:5410246519 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.291457: rtos_queue_send_from_isr_failed: tstamp:5410246635 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.291460: rtos_queue_send_from_isr_failed: tstamp:5410246752 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.291462: rtos_queue_send_failed: tstamp:5410247295 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.291464: rtos_queue_send_from_isr_failed: tstamp:5410264818 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.291466: rtos_queue_send_from_isr_failed: tstamp:5410264954 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.291469: rtos_queue_send_from_isr_failed: tstamp:5410265075 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.291471: rtos_queue_send_from_isr_failed: tstamp:5410265194 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.291473: rtos_queue_send_from_isr_failed: tstamp:5410265311 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.291475: rtos_queue_send_from_isr_failed: tstamp:5410265429 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.291478: rtos_queue_send_from_isr_failed: tstamp:5410265546 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.291480: rtos_queue_send_from_isr_failed: tstamp:5410265662 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.291482: rtos_queue_send_failed: tstamp:5410266800 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.459285: rtos_queue_peek_from_isr_failed: tstamp:5415149622 queue:0x0b4b4500
vi-output, imx5-8746 [002] .... 164.481095: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 20
vi-output, imx5-8746 [002] .... 164.481151: tegra_channel_capture_frame: sof:-549620695332.-269031629120
kworker/3:0-30 [003] .... 164.515337: rtos_queue_send_from_isr_failed: tstamp:5417084500 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.515343: rtos_queue_send_from_isr_failed: tstamp:5417084623 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.515345: rtos_queue_send_from_isr_failed: tstamp:5417084741 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.515348: rtos_queue_send_from_isr_failed: tstamp:5417084859 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.515350: rtos_queue_send_from_isr_failed: tstamp:5417084976 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.515355: rtos_queue_send_from_isr_failed: tstamp:5417085091 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.515358: rtos_queue_send_from_isr_failed: tstamp:5417085208 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.515361: rtos_queue_send_from_isr_failed: tstamp:5417085323 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.515364: rtos_queue_send_failed: tstamp:5417085983 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.515366: rtos_queue_send_from_isr_failed: tstamp:5417093267 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.515369: rtos_queue_send_from_isr_failed: tstamp:5417093399 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.515371: rtos_queue_send_from_isr_failed: tstamp:5417093520 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.515373: rtos_queue_send_from_isr_failed: tstamp:5417093639 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.515376: rtos_queue_send_from_isr_failed: tstamp:5417093756 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.515378: rtos_queue_send_from_isr_failed: tstamp:5417093871 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.515380: rtos_queue_send_from_isr_failed: tstamp:5417093988 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.515383: rtos_queue_send_from_isr_failed: tstamp:5417094106 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.515385: rtos_queue_send_failed: tstamp:5417094584 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.515387: rtos_queue_send_from_isr_failed: tstamp:5417110265 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.515389: rtos_queue_send_from_isr_failed: tstamp:5417110395 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.515392: rtos_queue_send_from_isr_failed: tstamp:5417110514 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.515394: rtos_queue_send_from_isr_failed: tstamp:5417110633 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.515396: rtos_queue_send_from_isr_failed: tstamp:5417110753 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.515398: rtos_queue_send_from_isr_failed: tstamp:5417110869 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.515401: rtos_queue_send_from_isr_failed: tstamp:5417110986 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.515403: rtos_queue_send_from_isr_failed: tstamp:5417111103 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.515405: rtos_queue_send_failed: tstamp:5417111598 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.515407: rtos_queue_send_from_isr_failed: tstamp:5417122253 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.515410: rtos_queue_send_from_isr_failed: tstamp:5417122373 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.515412: rtos_queue_send_from_isr_failed: tstamp:5417122491 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.515414: rtos_queue_send_from_isr_failed: tstamp:5417122609 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.515416: rtos_queue_send_from_isr_failed: tstamp:5417122727 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.515419: rtos_queue_send_from_isr_failed: tstamp:5417122848 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.515421: rtos_queue_send_from_isr_failed: tstamp:5417122963 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.515423: rtos_queue_send_from_isr_failed: tstamp:5417123080 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.515426: rtos_queue_send_failed: tstamp:5417124186 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.627263: rtos_queue_peek_from_isr_failed: tstamp:5420149633 queue:0x0b4b4500
vi-output, imx5-8746 [002] .... 164.701169: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 20
vi-output, imx5-8746 [002] .... 164.701216: tegra_channel_capture_frame: sof:-549620695332.-269031629120
kworker/3:0-30 [003] .... 164.739367: rtos_queue_send_from_isr_failed: tstamp:5423984921 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.739374: rtos_queue_send_from_isr_failed: tstamp:5423985053 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.739377: rtos_queue_send_from_isr_failed: tstamp:5423985173 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.739379: rtos_queue_send_from_isr_failed: tstamp:5423985291 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.739381: rtos_queue_send_from_isr_failed: tstamp:5423985407 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.739384: rtos_queue_send_from_isr_failed: tstamp:5423985522 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.739386: rtos_queue_send_from_isr_failed: tstamp:5423985639 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.739388: rtos_queue_send_from_isr_failed: tstamp:5423985754 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.739391: rtos_queue_send_failed: tstamp:5423986431 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.739393: rtos_queue_send_from_isr_failed: tstamp:5423991885 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.739395: rtos_queue_send_from_isr_failed: tstamp:5423992021 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.739397: rtos_queue_send_from_isr_failed: tstamp:5423992139 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.739399: rtos_queue_send_from_isr_failed: tstamp:5423992257 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.739402: rtos_queue_send_from_isr_failed: tstamp:5423992375 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.739404: rtos_queue_send_from_isr_failed: tstamp:5423992492 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.739406: rtos_queue_send_from_isr_failed: tstamp:5423992607 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.739408: rtos_queue_send_from_isr_failed: tstamp:5423992724 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.739410: rtos_queue_send_failed: tstamp:5423993196 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.739413: rtos_queue_send_from_isr_failed: tstamp:5424000167 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.739415: rtos_queue_send_from_isr_failed: tstamp:5424000285 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.739417: rtos_queue_send_from_isr_failed: tstamp:5424000404 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.739419: rtos_queue_send_from_isr_failed: tstamp:5424000524 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.739421: rtos_queue_send_from_isr_failed: tstamp:5424000640 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.739423: rtos_queue_send_from_isr_failed: tstamp:5424000757 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.739425: rtos_queue_send_from_isr_failed: tstamp:5424000874 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.739428: rtos_queue_send_from_isr_failed: tstamp:5424000992 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.739430: rtos_queue_send_failed: tstamp:5424001475 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.739432: rtos_queue_send_from_isr_failed: tstamp:5424005731 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.739434: rtos_queue_send_from_isr_failed: tstamp:5424005849 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.739436: rtos_queue_send_from_isr_failed: tstamp:5424005968 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.739439: rtos_queue_send_from_isr_failed: tstamp:5424006086 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.739441: rtos_queue_send_from_isr_failed: tstamp:5424006203 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.739443: rtos_queue_send_from_isr_failed: tstamp:5424006318 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.739445: rtos_queue_send_from_isr_failed: tstamp:5424006434 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.739448: rtos_queue_send_from_isr_failed: tstamp:5424006549 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.739450: rtos_queue_send_failed: tstamp:5424007654 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.739453: rtos_queue_peek_from_isr_failed: tstamp:5425149618 queue:0x0b4b4500
kworker/3:0-30 [003] .... 164.907239: rtos_queue_peek_from_isr_failed: tstamp:5430149657 queue:0x0b4b4500
vi-output, imx5-8746 [000] .... 164.925305: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 20
vi-output, imx5-8746 [000] .... 164.925353: tegra_channel_capture_frame: sof:-549620695332.-269031629120
kworker/3:0-30 [003] .... 164.963237: rtos_queue_send_from_isr_failed: tstamp:5430955075 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.963242: rtos_queue_send_from_isr_failed: tstamp:5430955183 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.963243: rtos_queue_send_from_isr_failed: tstamp:5430955288 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.963244: rtos_queue_send_from_isr_failed: tstamp:5430955394 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.963246: rtos_queue_send_from_isr_failed: tstamp:5430955495 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.963247: rtos_queue_send_from_isr_failed: tstamp:5430955599 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.963248: rtos_queue_send_from_isr_failed: tstamp:5430955700 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.963249: rtos_queue_send_from_isr_failed: tstamp:5430955803 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.963252: rtos_queue_send_failed: tstamp:5430956386 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.963253: rtos_queue_send_from_isr_failed: tstamp:5430960611 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.963255: rtos_queue_send_from_isr_failed: tstamp:5430960725 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.963256: rtos_queue_send_from_isr_failed: tstamp:5430960827 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.963257: rtos_queue_send_from_isr_failed: tstamp:5430960930 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.963258: rtos_queue_send_from_isr_failed: tstamp:5430961031 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.963260: rtos_queue_send_from_isr_failed: tstamp:5430961133 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.963261: rtos_queue_send_from_isr_failed: tstamp:5430961238 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.963262: rtos_queue_send_from_isr_failed: tstamp:5430961340 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.963264: rtos_queue_send_failed: tstamp:5430961767 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.963265: rtos_queue_send_from_isr_failed: tstamp:5430974411 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.963266: rtos_queue_send_from_isr_failed: tstamp:5430974525 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.963267: rtos_queue_send_from_isr_failed: tstamp:5430974628 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.963269: rtos_queue_send_from_isr_failed: tstamp:5430974733 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.963270: rtos_queue_send_from_isr_failed: tstamp:5430974834 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.963271: rtos_queue_send_from_isr_failed: tstamp:5430974935 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.963272: rtos_queue_send_from_isr_failed: tstamp:5430975036 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.963274: rtos_queue_send_from_isr_failed: tstamp:5430975138 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.963275: rtos_queue_send_failed: tstamp:5430975572 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.963276: rtos_queue_send_from_isr_failed: tstamp:5430990390 queue:0x0b4a7258
kworker/3:0-30 [003] .... 164.963278: rtos_queue_send_from_isr_failed: tstamp:5430990503 queue:0x0b4aad68
kworker/3:0-30 [003] .... 164.963279: rtos_queue_send_from_isr_failed: tstamp:5430990607 queue:0x0b4ac998
kworker/3:0-30 [003] .... 164.963280: rtos_queue_send_from_isr_failed: tstamp:5430990711 queue:0x0b4ae518
kworker/3:0-30 [003] .... 164.963281: rtos_queue_send_from_isr_failed: tstamp:5430990810 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 164.963283: rtos_queue_send_from_isr_failed: tstamp:5430990912 queue:0x0b4b0098
kworker/3:0-30 [003] .... 164.963284: rtos_queue_send_from_isr_failed: tstamp:5430991011 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 164.963285: rtos_queue_send_from_isr_failed: tstamp:5430991113 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 164.963287: rtos_queue_send_failed: tstamp:5430991988 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.075315: rtos_queue_peek_from_isr_failed: tstamp:5435149629 queue:0x0b4b4500
vi-output, imx5-8746 [002] .... 165.144916: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 20
vi-output, imx5-8746 [002] .... 165.144956: tegra_channel_capture_frame: sof:-549620695332.-269031629120
kworker/3:0-30 [003] .... 165.187280: rtos_queue_send_from_isr_failed: tstamp:5437835525 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.187288: rtos_queue_send_from_isr_failed: tstamp:5437835631 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.187291: rtos_queue_send_from_isr_failed: tstamp:5437835736 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.187294: rtos_queue_send_from_isr_failed: tstamp:5437835840 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.187296: rtos_queue_send_from_isr_failed: tstamp:5437835941 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.187298: rtos_queue_send_from_isr_failed: tstamp:5437836042 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.187301: rtos_queue_send_from_isr_failed: tstamp:5437836142 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.187303: rtos_queue_send_from_isr_failed: tstamp:5437836244 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.187306: rtos_queue_send_failed: tstamp:5437836834 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.187308: rtos_queue_send_from_isr_failed: tstamp:5437842222 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.187310: rtos_queue_send_from_isr_failed: tstamp:5437842335 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.187312: rtos_queue_send_from_isr_failed: tstamp:5437842437 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.187315: rtos_queue_send_from_isr_failed: tstamp:5437842541 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.187317: rtos_queue_send_from_isr_failed: tstamp:5437842643 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.187319: rtos_queue_send_from_isr_failed: tstamp:5437842744 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.187321: rtos_queue_send_from_isr_failed: tstamp:5437842846 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.187323: rtos_queue_send_from_isr_failed: tstamp:5437842951 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.187325: rtos_queue_send_failed: tstamp:5437843367 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.187327: rtos_queue_send_from_isr_failed: tstamp:5437857242 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.187330: rtos_queue_send_from_isr_failed: tstamp:5437857353 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.187332: rtos_queue_send_from_isr_failed: tstamp:5437857455 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.187334: rtos_queue_send_from_isr_failed: tstamp:5437857559 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.187336: rtos_queue_send_from_isr_failed: tstamp:5437857660 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.187338: rtos_queue_send_from_isr_failed: tstamp:5437857761 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.187340: rtos_queue_send_from_isr_failed: tstamp:5437857862 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.187343: rtos_queue_send_from_isr_failed: tstamp:5437857964 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.187345: rtos_queue_send_failed: tstamp:5437858391 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.187347: rtos_queue_send_from_isr_failed: tstamp:5437873686 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.187349: rtos_queue_send_from_isr_failed: tstamp:5437873800 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.187351: rtos_queue_send_from_isr_failed: tstamp:5437873902 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.187353: rtos_queue_send_from_isr_failed: tstamp:5437874005 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.187355: rtos_queue_send_from_isr_failed: tstamp:5437874106 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.187358: rtos_queue_send_from_isr_failed: tstamp:5437874208 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.187360: rtos_queue_send_from_isr_failed: tstamp:5437874309 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.187362: rtos_queue_send_from_isr_failed: tstamp:5437874411 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.187364: rtos_queue_send_failed: tstamp:5437875292 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.243292: rtos_queue_peek_from_isr_failed: tstamp:5440149635 queue:0x0b4b4500
vi-output, imx5-8746 [002] .... 165.364300: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 20
vi-output, imx5-8746 [002] .... 165.364346: tegra_channel_capture_frame: sof:-549620695332.-269031629120
kworker/3:0-30 [003] .... 165.411233: rtos_queue_send_from_isr_failed: tstamp:5444710805 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.411246: rtos_queue_send_from_isr_failed: tstamp:5444710930 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.411249: rtos_queue_send_from_isr_failed: tstamp:5444711049 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.411252: rtos_queue_send_from_isr_failed: tstamp:5444711168 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.411254: rtos_queue_send_from_isr_failed: tstamp:5444711285 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.411257: rtos_queue_send_from_isr_failed: tstamp:5444711400 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.411259: rtos_queue_send_from_isr_failed: tstamp:5444711517 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.411262: rtos_queue_send_from_isr_failed: tstamp:5444711634 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.411265: rtos_queue_send_failed: tstamp:5444712303 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.411268: rtos_queue_send_from_isr_failed: tstamp:5444717505 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.411270: rtos_queue_send_from_isr_failed: tstamp:5444717657 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.411272: rtos_queue_send_from_isr_failed: tstamp:5444717777 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.411274: rtos_queue_send_from_isr_failed: tstamp:5444717895 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.411277: rtos_queue_send_from_isr_failed: tstamp:5444718011 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.411279: rtos_queue_send_from_isr_failed: tstamp:5444718128 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.411281: rtos_queue_send_from_isr_failed: tstamp:5444718243 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.411284: rtos_queue_send_from_isr_failed: tstamp:5444718361 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.411286: rtos_queue_send_failed: tstamp:5444718868 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.411288: rtos_queue_send_from_isr_failed: tstamp:5444724445 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.411290: rtos_queue_send_from_isr_failed: tstamp:5444724563 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.411293: rtos_queue_send_from_isr_failed: tstamp:5444724682 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.411295: rtos_queue_send_from_isr_failed: tstamp:5444724803 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.411297: rtos_queue_send_from_isr_failed: tstamp:5444724927 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.411300: rtos_queue_send_from_isr_failed: tstamp:5444725045 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.411302: rtos_queue_send_from_isr_failed: tstamp:5444725165 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.411304: rtos_queue_send_from_isr_failed: tstamp:5444725284 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.411306: rtos_queue_send_failed: tstamp:5444725781 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.411309: rtos_queue_send_from_isr_failed: tstamp:5444728968 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.411311: rtos_queue_send_from_isr_failed: tstamp:5444729086 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.411313: rtos_queue_send_from_isr_failed: tstamp:5444729204 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.411315: rtos_queue_send_from_isr_failed: tstamp:5444729322 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.411318: rtos_queue_send_from_isr_failed: tstamp:5444729438 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.411320: rtos_queue_send_from_isr_failed: tstamp:5444729555 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.411322: rtos_queue_send_from_isr_failed: tstamp:5444729673 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.411324: rtos_queue_send_from_isr_failed: tstamp:5444729790 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.411327: rtos_queue_send_failed: tstamp:5444730884 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.411330: rtos_queue_peek_from_isr_failed: tstamp:5445149654 queue:0x0b4b4500
kworker/3:0-30 [003] .... 165.583241: rtos_queue_peek_from_isr_failed: tstamp:5450149650 queue:0x0b4b4500
vi-output, imx5-8746 [001] .... 165.584484: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 20
vi-output, imx5-8746 [001] .... 165.584550: tegra_channel_capture_frame: sof:-549620695332.-269031629120
kworker/3:0-30 [003] .... 165.639250: rtos_queue_send_from_isr_failed: tstamp:5451589571 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.639255: rtos_queue_send_from_isr_failed: tstamp:5451589684 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.639256: rtos_queue_send_from_isr_failed: tstamp:5451589789 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.639258: rtos_queue_send_from_isr_failed: tstamp:5451589902 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.639259: rtos_queue_send_from_isr_failed: tstamp:5451590003 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.639260: rtos_queue_send_from_isr_failed: tstamp:5451590112 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.639262: rtos_queue_send_from_isr_failed: tstamp:5451590213 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.639263: rtos_queue_send_from_isr_failed: tstamp:5451590314 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.639265: rtos_queue_send_failed: tstamp:5451590963 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.639267: rtos_queue_send_from_isr_failed: tstamp:5451594683 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.639267: rtos_queue_send_from_isr_failed: tstamp:5451594787 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.639268: rtos_queue_send_from_isr_failed: tstamp:5451594889 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.639269: rtos_queue_send_from_isr_failed: tstamp:5451594993 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.639269: rtos_queue_send_from_isr_failed: tstamp:5451595094 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.639270: rtos_queue_send_from_isr_failed: tstamp:5451595195 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.639270: rtos_queue_send_from_isr_failed: tstamp:5451595295 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.639271: rtos_queue_send_from_isr_failed: tstamp:5451595396 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.639271: rtos_queue_send_failed: tstamp:5451595808 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.639272: rtos_queue_send_from_isr_failed: tstamp:5451604509 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.639273: rtos_queue_send_from_isr_failed: tstamp:5451604613 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.639273: rtos_queue_send_from_isr_failed: tstamp:5451604717 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.639274: rtos_queue_send_from_isr_failed: tstamp:5451604820 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.639275: rtos_queue_send_from_isr_failed: tstamp:5451604923 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.639275: rtos_queue_send_from_isr_failed: tstamp:5451605024 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.639276: rtos_queue_send_from_isr_failed: tstamp:5451605125 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.639277: rtos_queue_send_from_isr_failed: tstamp:5451605227 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.639277: rtos_queue_send_failed: tstamp:5451605663 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.639278: rtos_queue_send_from_isr_failed: tstamp:5451609776 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.639279: rtos_queue_send_from_isr_failed: tstamp:5451609881 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.639279: rtos_queue_send_from_isr_failed: tstamp:5451609985 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.639280: rtos_queue_send_from_isr_failed: tstamp:5451610087 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.639281: rtos_queue_send_from_isr_failed: tstamp:5451610189 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.639281: rtos_queue_send_from_isr_failed: tstamp:5451610290 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.639282: rtos_queue_send_from_isr_failed: tstamp:5451610390 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.639282: rtos_queue_send_from_isr_failed: tstamp:5451610492 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.639283: rtos_queue_send_failed: tstamp:5451611411 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.751251: rtos_queue_peek_from_isr_failed: tstamp:5455149670 queue:0x0b4b4500
vi-output, imx5-8746 [001] .... 165.806193: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 20
vi-output, imx5-8746 [001] .... 165.806237: tegra_channel_capture_frame: sof:-549620695332.-269031629120
kworker/3:0-30 [003] .... 165.807178: rtos_queue_send_from_isr_failed: tstamp:5458515245 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.807185: rtos_queue_send_from_isr_failed: tstamp:5458515352 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.807187: rtos_queue_send_from_isr_failed: tstamp:5458515456 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.807189: rtos_queue_send_from_isr_failed: tstamp:5458515560 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.807191: rtos_queue_send_from_isr_failed: tstamp:5458515661 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.807193: rtos_queue_send_from_isr_failed: tstamp:5458515762 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.807196: rtos_queue_send_from_isr_failed: tstamp:5458515863 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.807198: rtos_queue_send_from_isr_failed: tstamp:5458515967 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.807201: rtos_queue_send_failed: tstamp:5458516552 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.807204: rtos_queue_send_from_isr_failed: tstamp:5458522659 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.807206: rtos_queue_send_from_isr_failed: tstamp:5458522763 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.807208: rtos_queue_send_from_isr_failed: tstamp:5458522865 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.807210: rtos_queue_send_from_isr_failed: tstamp:5458522969 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.807212: rtos_queue_send_from_isr_failed: tstamp:5458523072 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.807214: rtos_queue_send_from_isr_failed: tstamp:5458523173 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.807216: rtos_queue_send_from_isr_failed: tstamp:5458523274 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.807219: rtos_queue_send_from_isr_failed: tstamp:5458523376 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.807221: rtos_queue_send_failed: tstamp:5458523791 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.807223: rtos_queue_send_from_isr_failed: tstamp:5458531122 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.807225: rtos_queue_send_from_isr_failed: tstamp:5458531225 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.807228: rtos_queue_send_from_isr_failed: tstamp:5458531326 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.807230: rtos_queue_send_from_isr_failed: tstamp:5458531430 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.807232: rtos_queue_send_from_isr_failed: tstamp:5458531532 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.807234: rtos_queue_send_from_isr_failed: tstamp:5458531634 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.807236: rtos_queue_send_from_isr_failed: tstamp:5458531736 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.807238: rtos_queue_send_from_isr_failed: tstamp:5458531837 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.807240: rtos_queue_send_failed: tstamp:5458532288 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.807243: rtos_queue_send_from_isr_failed: tstamp:5458536841 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.807245: rtos_queue_send_from_isr_failed: tstamp:5458536945 queue:0x0b4aad68
kworker/3:0-30 [003] .... 165.807247: rtos_queue_send_from_isr_failed: tstamp:5458537049 queue:0x0b4ac998
kworker/3:0-30 [003] .... 165.807249: rtos_queue_send_from_isr_failed: tstamp:5458537152 queue:0x0b4ae518
kworker/3:0-30 [003] .... 165.807251: rtos_queue_send_from_isr_failed: tstamp:5458537256 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 165.807254: rtos_queue_send_from_isr_failed: tstamp:5458537361 queue:0x0b4b0098
kworker/3:0-30 [003] .... 165.807256: rtos_queue_send_from_isr_failed: tstamp:5458537462 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 165.807258: rtos_queue_send_from_isr_failed: tstamp:5458537565 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 165.807260: rtos_queue_send_failed: tstamp:5458538440 queue:0x0b4a7258
kworker/3:0-30 [003] .... 165.867183: rtos_queue_peek_from_isr_failed: tstamp:5460149673 queue:0x0b4b4500
vi-output, imx5-8746 [001] .... 166.025318: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 20
vi-output, imx5-8746 [001] .... 166.025366: tegra_channel_capture_frame: sof:-549620695332.-269031629120
kworker/3:0-30 [003] .... 166.035224: rtos_queue_peek_from_isr_failed: tstamp:5465149679 queue:0x0b4b4500
kworker/3:0-30 [003] .... 166.035235: rtos_queue_send_from_isr_failed: tstamp:5465337603 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.035238: rtos_queue_send_from_isr_failed: tstamp:5465337729 queue:0x0b4aad68
kworker/3:0-30 [003] .... 166.035241: rtos_queue_send_from_isr_failed: tstamp:5465337848 queue:0x0b4ac998
kworker/3:0-30 [003] .... 166.035243: rtos_queue_send_from_isr_failed: tstamp:5465337967 queue:0x0b4ae518
kworker/3:0-30 [003] .... 166.035246: rtos_queue_send_from_isr_failed: tstamp:5465338084 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 166.035248: rtos_queue_send_from_isr_failed: tstamp:5465338201 queue:0x0b4b0098
kworker/3:0-30 [003] .... 166.035250: rtos_queue_send_from_isr_failed: tstamp:5465338316 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 166.035253: rtos_queue_send_from_isr_failed: tstamp:5465338433 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 166.035256: rtos_queue_send_failed: tstamp:5465339082 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.035259: rtos_queue_send_from_isr_failed: tstamp:5465367223 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.035261: rtos_queue_send_from_isr_failed: tstamp:5465367345 queue:0x0b4aad68
kworker/3:0-30 [003] .... 166.035264: rtos_queue_send_from_isr_failed: tstamp:5465367463 queue:0x0b4ac998
kworker/3:0-30 [003] .... 166.035266: rtos_queue_send_from_isr_failed: tstamp:5465367581 queue:0x0b4ae518
kworker/3:0-30 [003] .... 166.035268: rtos_queue_send_from_isr_failed: tstamp:5465367696 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 166.035270: rtos_queue_send_from_isr_failed: tstamp:5465367813 queue:0x0b4b0098
kworker/3:0-30 [003] .... 166.035273: rtos_queue_send_from_isr_failed: tstamp:5465367930 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 166.035275: rtos_queue_send_from_isr_failed: tstamp:5465368046 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 166.035278: rtos_queue_send_failed: tstamp:5465368518 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.035280: rtos_queue_send_from_isr_failed: tstamp:5465377056 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.035282: rtos_queue_send_from_isr_failed: tstamp:5465377174 queue:0x0b4aad68
kworker/3:0-30 [003] .... 166.035284: rtos_queue_send_from_isr_failed: tstamp:5465377290 queue:0x0b4ac998
kworker/3:0-30 [003] .... 166.035286: rtos_queue_send_from_isr_failed: tstamp:5465377408 queue:0x0b4ae518
kworker/3:0-30 [003] .... 166.035289: rtos_queue_send_from_isr_failed: tstamp:5465377525 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 166.035291: rtos_queue_send_from_isr_failed: tstamp:5465377642 queue:0x0b4b0098
kworker/3:0-30 [003] .... 166.035293: rtos_queue_send_from_isr_failed: tstamp:5465377757 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 166.035296: rtos_queue_send_from_isr_failed: tstamp:5465377887 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 166.035298: rtos_queue_send_failed: tstamp:5465378385 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.035300: rtos_queue_send_from_isr_failed: tstamp:5465383916 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.035303: rtos_queue_send_from_isr_failed: tstamp:5465384034 queue:0x0b4aad68
kworker/3:0-30 [003] .... 166.035305: rtos_queue_send_from_isr_failed: tstamp:5465384152 queue:0x0b4ac998
kworker/3:0-30 [003] .... 166.035307: rtos_queue_send_from_isr_failed: tstamp:5465384273 queue:0x0b4ae518
kworker/3:0-30 [003] .... 166.035309: rtos_queue_send_from_isr_failed: tstamp:5465384404 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 166.035312: rtos_queue_send_from_isr_failed: tstamp:5465384522 queue:0x0b4b0098
kworker/3:0-30 [003] .... 166.035316: rtos_queue_send_from_isr_failed: tstamp:5465384639 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 166.035319: rtos_queue_send_from_isr_failed: tstamp:5465384754 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 166.035321: rtos_queue_send_failed: tstamp:5465385858 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.203244: rtos_queue_peek_from_isr_failed: tstamp:5470149685 queue:0x0b4b4500
v4l2-ctl-8745 [002] .... 166.219756: tegra_channel_close: vi-output, imx556 2-0057
vi-output, imx5-8746 [002] .... 166.245165: tegra_channel_capture_setup: vnc_id 0 W 1280 H 480 fmt 20
vi-output, imx5-8746 [002] .... 166.245207: tegra_channel_capture_frame: sof:-549620695332.-269031629120
v4l2-ctl-8745 [001] .... 166.247330: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-8745 [001] .... 166.247337: tegra_channel_set_stream: imx556 2-0057 : 0x0
v4l2-ctl-8745 [001] .... 166.247626: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-8745 [001] .... 166.247674: csi_s_stream: enable : 0x0
v4l2-ctl-8745 [002] .... 166.256217: tegra_channel_set_power: imx556 2-0057 : 0x0
v4l2-ctl-8745 [002] .... 166.256226: camera_common_s_power: status : 0x0
v4l2-ctl-8745 [002] .... 166.258473: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x0
v4l2-ctl-8745 [002] .... 166.258480: csi_s_power: enable : 0x0
kworker/3:0-30 [003] .... 166.263155: rtos_queue_send_from_isr_failed: tstamp:5472229941 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.263161: rtos_queue_send_from_isr_failed: tstamp:5472230065 queue:0x0b4aad68
kworker/3:0-30 [003] .... 166.263162: rtos_queue_send_from_isr_failed: tstamp:5472230184 queue:0x0b4ac998
kworker/3:0-30 [003] .... 166.263163: rtos_queue_send_from_isr_failed: tstamp:5472230303 queue:0x0b4ae518
kworker/3:0-30 [003] .... 166.263164: rtos_queue_send_from_isr_failed: tstamp:5472230420 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 166.263165: rtos_queue_send_from_isr_failed: tstamp:5472230539 queue:0x0b4b0098
kworker/3:0-30 [003] .... 166.263166: rtos_queue_send_from_isr_failed: tstamp:5472230656 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 166.263167: rtos_queue_send_from_isr_failed: tstamp:5472230771 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 166.263169: rtos_queue_send_failed: tstamp:5472231434 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.263170: rtos_queue_send_from_isr_failed: tstamp:5472238319 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.263171: rtos_queue_send_from_isr_failed: tstamp:5472238437 queue:0x0b4aad68
kworker/3:0-30 [003] .... 166.263173: rtos_queue_send_from_isr_failed: tstamp:5472238555 queue:0x0b4ac998
kworker/3:0-30 [003] .... 166.263174: rtos_queue_send_from_isr_failed: tstamp:5472238673 queue:0x0b4ae518
kworker/3:0-30 [003] .... 166.263175: rtos_queue_send_from_isr_failed: tstamp:5472238790 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 166.263176: rtos_queue_send_from_isr_failed: tstamp:5472238905 queue:0x0b4b0098
kworker/3:0-30 [003] .... 166.263177: rtos_queue_send_from_isr_failed: tstamp:5472239021 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 166.263178: rtos_queue_send_from_isr_failed: tstamp:5472239136 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 166.263179: rtos_queue_send_failed: tstamp:5472239616 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.263180: rtos_queue_send_from_isr_failed: tstamp:5472247982 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.263181: rtos_queue_send_from_isr_failed: tstamp:5472248113 queue:0x0b4aad68
kworker/3:0-30 [003] .... 166.263182: rtos_queue_send_from_isr_failed: tstamp:5472248243 queue:0x0b4ac998
kworker/3:0-30 [003] .... 166.263183: rtos_queue_send_from_isr_failed: tstamp:5472248374 queue:0x0b4ae518
kworker/3:0-30 [003] .... 166.263184: rtos_queue_send_from_isr_failed: tstamp:5472248489 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 166.263185: rtos_queue_send_from_isr_failed: tstamp:5472248605 queue:0x0b4b0098
kworker/3:0-30 [003] .... 166.263186: rtos_queue_send_from_isr_failed: tstamp:5472248721 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 166.263187: rtos_queue_send_from_isr_failed: tstamp:5472248838 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 166.263189: rtos_queue_send_failed: tstamp:5472249354 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.263190: rtos_queue_send_from_isr_failed: tstamp:5472254480 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.263191: rtos_queue_send_from_isr_failed: tstamp:5472254582 queue:0x0b4aad68
kworker/3:0-30 [003] .... 166.263192: rtos_queue_send_from_isr_failed: tstamp:5472254686 queue:0x0b4ac998
kworker/3:0-30 [003] .... 166.263193: rtos_queue_send_from_isr_failed: tstamp:5472254789 queue:0x0b4ae518
kworker/3:0-30 [003] .... 166.263194: rtos_queue_send_from_isr_failed: tstamp:5472254890 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 166.263195: rtos_queue_send_from_isr_failed: tstamp:5472254991 queue:0x0b4b0098
kworker/3:0-30 [003] .... 166.263196: rtos_queue_send_from_isr_failed: tstamp:5472255092 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 166.263197: rtos_queue_send_from_isr_failed: tstamp:5472255193 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 166.263198: rtos_queue_send_failed: tstamp:5472256082 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.263199: rtos_queue_send_from_isr_failed: tstamp:5472307509 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.263200: rtos_queue_send_from_isr_failed: tstamp:5472307622 queue:0x0b4aad68
kworker/3:0-30 [003] .... 166.263201: rtos_queue_send_from_isr_failed: tstamp:5472307724 queue:0x0b4ac998
kworker/3:0-30 [003] .... 166.263202: rtos_queue_send_from_isr_failed: tstamp:5472307826 queue:0x0b4ae518
kworker/3:0-30 [003] .... 166.263204: rtos_queue_send_from_isr_failed: tstamp:5472307928 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 166.263205: rtos_queue_send_from_isr_failed: tstamp:5472308029 queue:0x0b4b0098
kworker/3:0-30 [003] .... 166.263206: rtos_queue_send_from_isr_failed: tstamp:5472308129 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 166.263207: rtos_queue_send_from_isr_failed: tstamp:5472308230 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 166.263208: rtos_queue_send_failed: tstamp:5472308826 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.263209: rtos_queue_send_from_isr_failed: tstamp:5472315556 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.263210: rtos_queue_send_from_isr_failed: tstamp:5472315658 queue:0x0b4aad68
kworker/3:0-30 [003] .... 166.263211: rtos_queue_send_from_isr_failed: tstamp:5472315762 queue:0x0b4ac998
kworker/3:0-30 [003] .... 166.263212: rtos_queue_send_from_isr_failed: tstamp:5472315864 queue:0x0b4ae518
kworker/3:0-30 [003] .... 166.263213: rtos_queue_send_from_isr_failed: tstamp:5472315966 queue:0x0b4af2d8
kworker/3:0-30 [003] .... 166.263214: rtos_queue_send_from_isr_failed: tstamp:5472316067 queue:0x0b4b0098
kworker/3:0-30 [003] .... 166.263215: rtos_queue_send_from_isr_failed: tstamp:5472316177 queue:0x0b4b0e58
kworker/3:0-30 [003] .... 166.263216: rtos_queue_send_from_isr_failed: tstamp:5472316277 queue:0x0b4b1c18
kworker/3:0-30 [003] .... 166.263218: rtos_queue_send_failed: tstamp:5472316692 queue:0x0b4a7258
kworker/3:0-30 [003] .... 166.375247: rtos_queue_peek_from_isr_failed: tstamp:5475149700 queue:0x0b4b4500
kworker/3:0-30 [003] .n.. 166.543355: rtos_queue_peek_from_isr_failed: tstamp:5480149692 queue:0x0b4b4500
kworker/3:0-30 [003] .... 166.711178: rtos_queue_peek_from_isr_failed: tstamp:5485149706 queue:0x0b4b4500
kworker/3:0-30 [003] .... 166.823191: rtos_queue_peek_from_isr_failed: tstamp:5490149726 queue:0x0b4b4500
kworker/3:0-30 [003] .... 166.991151: rtos_queue_peek_from_isr_failed: tstamp:5495149744 queue:0x0b4b4500
kworker/3:0-30 [003] .... 167.159173: rtos_queue_peek_from_isr_failed: tstamp:5500149721 queue:0x0b4b4500
kworker/3:0-30 [003] .... 167.327134: rtos_queue_peek_from_isr_failed: tstamp:5505149735 queue:0x0b4b4500
ubuntu@ubuntu-desktop:~$ media-ctl -p -d /dev/media0
Media controller API version 0.1.0
Media device information
driver tegra-vi4
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 0.0.0
Device topology
- entity 1: 150c0000.nvcsi--1 (2 pads, 2 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
<- "imx556 2-0057":0 [ENABLED]
pad1: Source
-> "vi-output, imx556 2-0057":0 [ENABLED]
- entity 4: imx556 2-0057 (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev1
pad0: Source
[fmt:SRGGB12_1X12/1280x480 field:none colorspace:srgb]
-> "150c0000.nvcsi--1":0 [ENABLED]
- entity 6: vi-output, imx556 2-0057 (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "150c0000.nvcsi--1":1 [ENABLED]
ubuntu@ubuntu-desktop:~$ v4l2-ctl --list-devices
vi-output, imx556 2-0057 (platform:15700000.vi:0):
/dev/video0
Any ideas are welcome.
