Cannot clara pull platform
I am following an 2. Installation — Clara Deploy SDK 0.7.3 documentation guide to install Clara deploy but has faced some issues when i run the command clara pull platform.
I am installing Clara on an AWS instance:
Deep Learning Base AMI (Ubuntu 18.04) Version 33.0
instance type : p2.xlarge
ubuntu@ip:~$ clara pull platform
✔ Yes
Pulling Clara Platform …
| Error: Couldn’t load repositories file (/home/ubuntu/.helm/repository/reposito ries.yaml).
You might need to run helm init (or helm init --client-only if tiller is alr eady installed)
ubuntu@ip:~$ helm init
Creating /home/ubuntu/.helm/repository/repositories.yaml
Adding stable repo with URL: https://kubernetes-charts.storage.googleapis.com
Error: error initializing: Looks like “https://kubernetes-charts.storage.googlea pis.com” is not a valid chart repository or cannot be reached: Failed to fetch h ttps://kubernetes-charts.storage.googleapis.com/index.yaml : 403 Forbidden
Hi 14pw.tanboonhing,
Sorry for the trouble with this. Helm v2 was recently deprecated, and the helm init command now requires providing the URL for the old stable repo:
helm init --stable-repo-url https://charts.helm.sh/stable --service-account tiller
The docs and installation scripts will be updated to reflect this change.
Thanks,
Kris
Hi kkersten, thank you for the help.
I am still facing some issue running that helm init command
ubuntu@ip:~$ helm init --stable-repo-url https://charts.helm.sh/st able --service-account tiller
Adding stable repo with URL: https://charts.helm.sh/stable
Error: error initializing: Looks like “https://charts.helm.sh/stable” is not a v alid chart repository or cannot be reached: open /home/ubuntu/.helm/repository/c ache/stable-index.yaml: permission denied
Would you be able to help me on this?
It looks like this may just be a permissions issue on your ~/.helm directory. Try changing ownership to your user/group by running:
sudo chown -R <your username>:<default group> ~/.helm
