I’m trying to compile samples from GPU SDK for CUDA. I have i7 Intel processor and two GTX 460.
I’ve installed following packages:
devdriver_3.2_linux_64_260.19.26.run
cudatoolkit_3.2.16_linux_64_ubuntu10.04.run
gpucomputingsdk_3.2.16_linux.run
I did all the tricks (add blacklist …) according to the links:
http://developer.download.nvidia.com…rted_Linux.pdf
http://wiki.accelereyes.com/wiki/ind...r_Ubuntu_10.04
http://developer.nvidia.com/object/c...downloads.html
The PATH and LD_LIBRARY_PATH=/usr/local/cuda/lib64:/usr/local/cuda/lib: are set. The latter in .bashrc and in /etc/ld.so.conf.d/cuda.conf.
I’m getting the following error during the “make” process:
/usr/bin/ld: cannot find -lGLU
…/…/bin/linux/release/postProcessGL Error 1
The solution: sudo ln -s libGL.so.260.19.26 libGL.so does not help.
If I do: sudo apt-get install freeglut3-dev I get error: Broken packages
The following packages have unmet dependencies:
freeglut3-dev: Depends: libgl1-mesa-dev but it is not going to be installed or libgl-dev
Depends: libglu1-mesa-dev but it is not going to be installed or libglu-dev
If I do: sudo apt-get install libgl1-mesa-dev
libgl1-mesa-dev: Depends: libgl1-mesa-glx(= 7.7.1-1ubuntu2) but 7.7.1-1ubuntu3 is to be installed
If I do: sudo apt-get install libgl1-mesa-glx
is already the newest version
I googled it and I’ve tried to install all kinds of packages and now just don’t know what to do. I think I have dependency problem.
Does anyone have any ideas how can I solve compilation problems?
Roman
