Here’s what I get from UART.
(Note: This is from my last attempt, where I cross-compiled the ifb module and tried to install it on the Xavier NX afterwards. Anyways, the errors came up after reboot as usual).
ÿâ
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0000.034] I> MB1 (prd-version: 2.6.0.0-t194-41334769-cab45716)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Platform: Silicon
[0000.045] I> Chip revision : A02P
[0000.048] I> Bootrom patch version : 15 (correctly patched)
[0000.053] I> ATE fuse revision : 0x200
[0000.056] I> Ram repair fuse : 0x0
[0000.060] I> Ram Code : 0x1
[0000.062] I> rst_source: 0x0, rst_level: 0x0
[0000.067] I> Boot-device: QSPI (instance: 0)
[0000.071] I> Qspi flash params source = brbct
[0000.075] I> Qspi clock source : pllp
[0000.078] I> Qspi-0 initialized successfully
[0000.082] I> Boot chain mechanism: A/B
[0000.086] I> Current Boot-Chain Slot: 0
[0000.089] I> BR-BCT Boot-Chain: 0, status: 0. update flag: 0
[0000.095] I> Qspi flash params source = brbct
[0000.101] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0000.108] I> Temperature = 54000
[0000.111] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.116] W> Skipping boost for clk: BPMP_APB
[0000.120] W> Skipping boost for clk: AXI_CBB
[0000.124] W> Skipping boost for clk: AON_CPU_NIC
[0000.128] W> Skipping boost for clk: CAN1
[0000.132] W> Skipping boost for clk: CAN2
[0000.136] I> Boot-device: QSPI (instance: 0)
[0000.140] I> Qspi flash params source = mb1bct
[0000.144] I> Qspi clock source : pllc_out0
[0000.148] I> Qspi-0 reinitialized
[0000.151] I> Qspi flash params source = mb1bct
[0000.164] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.171] W> Thermal config not found in BCT
[0000.179] W> MEMIO rail config not found in BCT
[0000.189] RÍÁ¥flash params source = mb1bct
[0000.202] I> Qspi flash params source = mb1bct
[0000.236] I> Q.¥f+Í¡params source = mb1bct
[0000.800] I> Qspi flash params source = mb1bct
[0000.817] I> Qspi flash params source = mb1bct
[0000.856] W> Platform config not found in BCT
[0000.883] I> Qspi flash params source = mb1bct
[0000.909] I> MB1 done
ÿýÿàmain enter
SPE VERSION #: R01.00.18 Created: Jan 29 2021 @ 14:18:27
HW Function test
Start Scheduler.
in late init
ÿâ
[0000.918] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-74494172)
[0000.919] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.919] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.920] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.926] W> device prod register failed
[0000.930] I> gpio framework initialized
[0000.933] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.941] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.948] I> No valid sdcard_params in mb1_bct
[0000.953] I> Boot_device: QSPI_FLASH instance: 0
[0000.957] I> qspi flash-0 params source = boot args
[0000.963] I> QSPI-0l initialized successfully
[0000.973] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0000.974] I> Active Boot chain : 0
[0001.656] I> Relocating BR-BCT
[0001.657] > DEVICE_PROD: device prod is not initialized.
[0001.683] E> I2C: slave not found in slaves.
[0001.684] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.685] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.686] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0001.686] E> eeprom: Failed to read I2C slave device
[0001.690] I> Failed to read CVB eeprom data @ AE
[0001.694] I> Retrying CVB eeprom read @ AC ...
[0001.699] E> I2C: slave not found in slaves.
[0001.703] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0001.710] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.716] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0001.725] E> eeprom: Failed to read I2C slave device
[0001.730] I> Failed to read CVB eeprom data @ AC
[0001.997] I> Relocating OP-TEE dtb from: 0x6bfff240 to 0x70050000, size: 1008
[0001.998] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0001.998] I> [1] START: 0xaf010000, SIZE: 0x189f0000
[0001.999] I> [2] START: 0xc7b00000, SIZE: 0xc0000
[0001.999] I> [3] START: 0xca000000, SIZE: 0x800000
[0002.000] I> dram_block larger than 80000000
[0002.002] I> [4] START: 0x100000000, SIZE: 0x180000000
[0002.014] I> Setting NS memory ranges to OP-TEE dtb finished.
[0002.017] I> found decompressor handler: lz4
[0002.327] I> EKB detected (length: 0x410) @ VA:0x526ff400
[0002.329] I> Setting EKB blob info to OPTEE dtb finished.
ÿäNOTICE: BL31: v2.6(release):07eea4970
NOTICE: BL31: Built : 07:55:15, Mar 19 2023
I/TC:
ÿâ
bpmp: init
bpmp: tag is 128431eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
ÿäÿâclk_early initialized
ÿäI/TCÿâmail_early initialized
ÿä: ÿâfuse initialized
hwwdt initialized
ÿäNon-sÿât194_ec_get_ec_list: found 45 ecs
ÿäecure exteÿâec initialized
ÿärÿâvmon_setup_monitors: found 3 monitors
vmon initialized
ÿänalÿâadc initialized
fmon_populate_monitors: found 73 monitors
ÿä DT found
ÿâfmon initialized
mc initialized
reset initialized
nvhs initialized
uphy_early initialized
emc_early initialized
392 clocks registered
clk initialized
io_dpd initialized
thermal initialized
thermal_mrq initialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmon initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
suspend initialized
pg_late initialized
pg_mrq_init initialized
strap initialized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
ÿäI/TC: OP-TEE version: 3.19 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Sun ÿâclk_dt_late initialized
ÿäMÿânoc_late initialized
pm_post initialized
dbells initialized
ÿäar ÿâdmce initialized
ÿä1ÿâcvc initialized
ÿä9 15:02:42 Uÿâavfs_clk_mach_post initialized
ÿäTC 20ÿâavfs_clk_platform_post initialized
ÿä23ÿâcvc_late initialized
regulator_post initialized
ÿä aarcÿârm initialized
console_late initialized
clk_dt_post initialized
mc_reg initialized
ÿäh64
I/TC: WARNINÿâpg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
] ÿäG: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
ÿá
[0002.949] I> Welcome to NVDisp-Init
[0002.949] I> NVDisp-Init version: t194-709c0123
[0002.949] I> CPU-BL Params @ 0xca020000
[0002.949] I> 0) Base:0x00000000 Size:0x00000000
[0002.950] I> 1) Base:0xc8100000 Size:0x00100000
[0002.950] I> 2) Base:0xc9800000 Size:0x00200000
[0002.950] I> 3) Base:0xc8600000 Size:0x00200000
[0002.953] I> 4) Base:0xc8000000 Size:0x00100000
[0002.957] I> 5) Base:0xc7f00000 Size:0x00100000
[0002.962] I> 6) Base:0xc9400000 Size:0x00400000
[0002.966] I> 7) Base:0xc9000000 Size:0x00400000
[0002.971] I> 8) Base:0xc7e00000 Size:0x00100000
[0002.975] I> 9) Base:0xc7d00000 Size:0x00100000
[0002.980] I> 10) Base:0xca800000 Size:0x00800000
[0002.984] I> 11) Base:0x40000000 Size:0x00040000
[0002.989] I> 12) Base:0xc7c00000 Size:0x00100000
[0002.993] I> 13) Base:0x40046000 Size:0x00002000
[0002.998] I> 14) Base:0x40048000 Size:0x00002000
[0003.002] I> 15) Base:0xaf000000 Size:0x00004000
[0003.007] I> 16) Base:0x4004a000 Size:0x00002000
[0003.011] I> 17) Base:0xc7a00000 Size:0x00100000
[0003.015] I> 18) Base:0x4004c000 Size:0x00002000
[0003.020] I> 19) Base:0xc9a00000 Size:0x00600000
[0003.024] I> 20) Base:0x4004e000 Size:0x00002000
[0003.029] I> 21) Base:0xc7bc0000 Size:0x0000c000
[0003.033] I> 22) Base:0x00000000 Size:0x00000000
[0003.038] I> 23) Base:0xc7be0000 Size:0x00020000
[0003.042] I> 24) Base:0xcc000000 Size:0x02000000
[0003.047] I> 25) Base:0x40050000 Size:0x00002000
[0003.051] I> 26) Base:0x40040000 Size:0x00006000
[0003.056] I> 27) Base:0xc8c00000 Size:0x00400000
[0003.060] I> 28) Base:0xc8400000 Size:0x00200000
[0003.065] I> 29) Base:0xc8800000 Size:0x00400000
[0003.069] I> 30) Base:0xc7bd0000 Size:0x00010000
[0003.073] I> 31) Base:0x00000000 Size:0x00000000
[0003.078] I> 32) Base:0xf8000000 Size:0x08000000
[0003.082] I> 33) Base:0xce000000 Size:0x2a000000
[0003.087] I> 34) Base:0xcb000000 Size:0x01000000
[0003.091] I> 35) Base:0xae000000 Size:0x01000000
[0003.096] I> 36) Base:0xa0000000 Size:0x0e000000
[0003.100] I> 37) Base:0xca000000 Size:0x00800000
[0003.105] I> 38) Base:0x80000000 Size:0x20000000
[0003.109] I> 39) Base:0xb0000000 Size:0x08000000
[0003.114] I> 40) Base:0x00000000 Size:0x00000000
[0003.118] I> 41) Base:0x00000000 Size:0x00000000
[0003.123] I> 42) Base:0xc8200000 Size:0x00200000
[0003.127] I> 43) Base:0x00000000 Size:0x00000000
[0003.132] I> 44) Base:0x00000000 Size:0x00000000
[0003.136] I> 45) Base:0x00000000 Size:0x00000000
[0003.140] GIC-SPI Target CPU: 0
[0003.143] Interrupts Init done
[0003.146] calling constructors
[0003.149] initializing heap
[0003.152] I> Heap: [0xa0960000 ... 0xadf00000]
[0003.156] initializing threads
[0003.159] initializing timers
[0003.162] creating bootstrap completion thread
[0003.166] top of bootstrap2()
[0003.169] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0003.174] initializing platform
[0003.176] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0003.182] W> device prod register failed
[0003.186] I> Bl_dtb @0xadf00000
[0003.189] I> gpio framework initialized
[0003.200] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0003.205] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0003.211] I> fixed regulator driver initialized
[0003.225] I> register 'maxim' power off handle
[0003.228] I> virtual i2c enabled
[0003.228] I> registered 'maxim,max20024' pmic
[0003.228] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0003.230] I> Boot-device: QSPI
[0003.233] I> Boot_device: QSPI_FLASH instance: 0
[0003.237] I> configure_qspi_clk: qparams clk_src = 5, clk_div = 0, clk_src_freq = 800000000, interface_freq = 50000000
[0003.248] I> configure_qspi_clk: FORCING INTERFACE_FREQ TO 133000000!!
[0003.255] I> QSPI source rate = 204000 Khz
[0003.258] I> Requested rate for QSPI clock = 34000 Khz
[0003.264] I> BPMP-set rate for QSPI clk = 34000 Khz
[0003.268] I> tx_clk_tap_delay : 0
[0003.271] I> rx_clk_tap_delay : 16
[0003.274] I> QSPI Flash Size = 32 MB
[0003.282] I> Qspi initialized successfully
[0003.283] I> qspi flash-0 params source = boot args
[0003.287] W> No board IDs available
[0003.290] E> Failed to get board id info!
[0003.298] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0003.316] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.323] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.324] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0003.324] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0003.325] E> cannot find any other nvdisp nodes
[0003.326] E> no valid display unit config found in dtb
[0003.333] W> display init failed
[0003.334] initializing target
[0003.337] calling apps_init()
[0003.340] starting app kernel_boot_app
[0003.343] I> Kernel type = Normal
Jetson UEFI firmware (version 3.1-32827747 built on 2023-03-19T14:56:32+00:00)
3h
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
ÿäI/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
ÿá[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[ 0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-6289-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Sun Mar 19 07:55:28 PDT 2023
[ 0.000000] Machine model: NVIDIA Jetson Xavier NX Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x277505698 SMBIOS=0xc7bb0000 SMBIOS 3.0=0x258f40000 MEMATTR=0x259712018 ESRT=0x259752a18 RNG=0x27c54dd18 MEMRESERVE=0x25971af18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000259752a18 to 0x0000000259752a50.
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000027fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af010000-0x00000000c79fffff]
[ 0.000000] node 0: [mem 0x00000000c7b00000-0x00000000c7b9ffff]
[ 0.000000] node 0: [mem 0x00000000c7ba0000-0x00000000c7bbffff]
[ 0.000000] node 0: [mem 0x00000000ca000000-0x00000000ca7fffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000258c41fff]
[ 0.000000] node 0: [mem 0x0000000258c42000-0x0000000258db6fff]
[ 0.000000] node 0: [mem 0x0000000258db7000-0x0000000258f2ffff]
[ 0.000000] node 0: [mem 0x0000000258f30000-0x0000000258f4ffff]
[ 0.000000] node 0: [mem 0x0000000258f50000-0x00000002591affff]
[ 0.000000] node 0: [mem 0x00000002591b0000-0x00000002591fffff]
[ 0.000000] node 0: [mem 0x0000000259200000-0x00000002595dffff]
[ 0.000000] node 0: [mem 0x00000002595e0000-0x000000025962ffff]
[ 0.000000] node 0: [mem 0x0000000259630000-0x00000002596dffff]
[ 0.000000] node 0: [mem 0x00000002596e0000-0x000000025970ffff]
[ 0.000000] node 0: [mem 0x0000000259710000-0x000000025972ffff]
[ 0.000000] node 0: [mem 0x0000000259730000-0x000000025974ffff]
[ 0.000000] node 0: [mem 0x0000000259750000-0x000000025982ffff]
[ 0.000000] node 0: [mem 0x0000000259830000-0x0000000259a0ffff]
[ 0.000000] node 0: [mem 0x0000000259a10000-0x0000000259a5ffff]
[ 0.000000] node 0: [mem 0x0000000259a60000-0x0000000259d7ffff]
[ 0.000000] node 0: [mem 0x0000000259d80000-0x0000000259dfffff]
[ 0.000000] node 0: [mem 0x0000000259e00000-0x0000000259e0ffff]
[ 0.000000] node 0: [mem 0x0000000259e10000-0x0000000259ecffff]
[ 0.000000] node 0: [mem 0x0000000259ed0000-0x0000000259f6ffff]
[ 0.000000] node 0: [mem 0x0000000259f70000-0x000000025a06ffff]
[ 0.000000] node 0: [mem 0x000000025a070000-0x000000025a10ffff]
[ 0.000000] node 0: [mem 0x000000025a110000-0x000000025a1bffff]
[ 0.000000] node 0: [mem 0x000000025a1c0000-0x000000025a25ffff]
[ 0.000000] node 0: [mem 0x000000025a260000-0x000000025ab6ffff]
[ 0.000000] node 0: [mem 0x000000025ab70000-0x000000025ad4ffff]
[ 0.000000] node 0: [mem 0x000000025ad50000-0x000000027c4fffff]
[ 0.000000] node 0: [mem 0x000000027c500000-0x000000027c54ffff]
[ 0.000000] node 0: [mem 0x000000027c550000-0x000000027fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000027fffffff]
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c3800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1839269
[ 0.000000] Kernel command line: root=PARTUUID=7acf6058-ad21-4d49-81ba-9f017f910427 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=efifb:off nv-auto-config
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000b3800000-0x00000000c3800000] (256MB)
[ 0.000000] Memory: 6943044K/7473856K available (18496K kernel code, 3168K rwdata, 7172K rodata, 3968K init, 1418K bss, 465276K reserved, 65536K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000822] Console: colour dummy device 80x25
[ 0.002391] printk: console [tty0] enabled
[ 0.002453] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.002490] pid_max: default: 32768 minimum: 301
[ 0.002712] LSM: Security Framework initializing
[ 0.002770] Yama: becoming mindful.
[ 0.002816] SELinux: Initializing.
[ 0.002978] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.003038] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.006101] rcu: Hierarchical SRCU implementation.
[ 0.006354] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.007162] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-0001-p3509-0000.dts
[ 0.007256] DTB Build time: Mar 19 2023 08:08:44
[ 0.010745] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.011109] Remapping and enabling EFI services.
[ 0.012835] smp: Bringing up secondary CPUs ...
[ 0.041709] Detected PIPT I-cache on CPU1
[ 0.041785] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[ 0.072715] Detected PIPT I-cache on CPU2
[ 0.072792] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[ 0.102223] Detected PIPT I-cache on CPU3
[ 0.102295] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[ 0.131740] Detected PIPT I-cache on CPU4
[ 0.131816] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[ 0.161208] Detected PIPT I-cache on CPU5
[ 0.161344] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[ 0.161652] smp: Brought up 1 node, 6 CPUs
[ 0.161991] SMP: Total of 6 processors activated.
[ 0.162011] CPU features: detected: Privileged Access Never
[ 0.162049] CPU features: detected: LSE atomic instructions
[ 0.162067] CPU features: detected: User Access Override
[ 0.162085] CPU features: detected: 32-bit EL0 Support
[ 0.162102] CPU features: detected: RAS Extension Support
[ 0.162119] CPU features: detected: CRC32 instructions
[ 0.162137] CPU features: detected: 32-bit EL1 Support
[ 0.230263] CPU: All CPU(s) started at EL2
[ 0.235510] devtmpfs: initialized
[ 0.290507] Registered cp15_barrier emulation handler
[ 0.290628] Registered setend emulation handler
[ 0.290656] KASLR enabled
[ 0.290984] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.291042] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.292022] pinctrl core: initialized pinctrl subsystem
[ 0.292977] SMBIOS 3.0.0 present.
[ 0.293009] DMI: Unknown NVIDIA Jetson Xavier NX Developer Kit/NVIDIA Jetson Xavier NX Developer Kit, BIOS 3.1-32827747 03/19/2023
[ 0.293770] NET: Registered protocol family 16
[ 0.295646] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.296142] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.296840] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.296917] audit: initializing netlink subsys (disabled)
[ 0.297194] audit: type=2000 audit(0.292:1): state=initialized audit_enabled=0 res=1
[ 0.297559] thermal_sys: Registered thermal governor 'step_wise'
[ 0.297565] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.297585] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.299864] cpuidle: using governor menu
[ 0.300229] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.300762] ASID allocator initialised with 32768 entries
[ 0.301048] Serial: AMBA PL011 UART driver
[ 0.304973] Tegra reboot handler registered.
[ 0.377194] mc: mapped MMIO address: 0xffff800010580000 -> 0x2c10000
[ 0.377250] mc: mapped MMIO address: 0xffff8000105a0000 -> 0x2c20000
[ 0.377291] mc: mapped MMIO address: 0xffff8000105c0000 -> 0x2c30000
[ 0.377329] mc: mapped MMIO address: 0xffff8000105e0000 -> 0x2c40000
[ 0.377368] mc: mapped MMIO address: 0xffff800010600000 -> 0x2c50000
[ 0.377404] mc: mapped MMIO address: 0xffff800010620000 -> 0x2b80000
[ 0.377439] mc: mapped MMIO address: 0xffff800010640000 -> 0x2b90000
[ 0.377475] mc: mapped MMIO address: 0xffff800010660000 -> 0x2ba0000
[ 0.377509] mc: mapped MMIO address: 0xffff800010680000 -> 0x2bb0000
[ 0.377544] mc: mapped MMIO address: 0xffff8000106a0000 -> 0x1700000
[ 0.377578] mc: mapped MMIO address: 0xffff8000106c0000 -> 0x1710000
[ 0.377613] mc: mapped MMIO address: 0xffff8000106e0000 -> 0x1720000
[ 0.377647] mc: mapped MMIO address: 0xffff800010700000 -> 0x1730000
[ 0.377681] mc: mapped MMIO address: 0xffff800010720000 -> 0x1740000
[ 0.377716] mc: mapped MMIO address: 0xffff800010740000 -> 0x1750000
[ 0.377766] mc: mapped MMIO address: 0xffff800010760000 -> 0x1760000
[ 0.377815] mc: mapped MMIO address: 0xffff800010780000 -> 0x1770000
[ 0.377940] mc-err: mcerr ops are set to t19x
[ 0.389816] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.389850] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.389870] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.389888] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.396425] ACPI: Interpreter disabled.
[ 0.397617] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.398863] iommu: Default domain type: Translated
[ 0.398933] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.399356] SCSI subsystem initialized
[ 0.399508] usbcore: registered new interface driver usbfs
[ 0.399550] usbcore: registered new interface driver hub
[ 0.399589] usbcore: registered new device driver usb
[ 0.400014] mc: Linux media interface: v0.10
[ 0.400049] videodev: Linux video capture interface: v2.00
[ 0.400369] pps_core: LinuxPPS API ver. 1 registered
[ 0.400386] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.400419] PTP clock support registered
[ 0.400632] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.400949] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.401037] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.401571] Registered efivars operations
[ 0.401941] FPGA manager framework
[ 0.402044] Advanced Linux Sound Architecture Driver Initialized.
[ 0.402613] Bluetooth: Core ver 2.22
[ 0.402730] NET: Registered protocol family 31
[ 0.402768] Bluetooth: HCI device and connection manager initialized
[ 0.402792] Bluetooth: HCI socket layer initialized
[ 0.402812] Bluetooth: L2CAP socket layer initialized
[ 0.402840] Bluetooth: SCO socket layer initialized
[ 0.404146] camchar: rtcpu character device driver loaded
[ 0.404833] clocksource: Switched to clocksource arch_sys_counter
[ 0.698073] VFS: Disk quotas dquot_6.6.0
[ 0.698183] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.698572] pnp: PnP ACPI: disabled
[ 0.708723] la/ptsa driver initialized.
[ 0.708932] NET: Registered protocol family 2
[ 0.709098] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.715098] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.715172] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.715501] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.715946] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.716079] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.716175] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.716428] NET: Registered protocol family 1
[ 0.717366] RPC: Registered named UNIX socket transport module.
[ 0.717438] RPC: Registered udp transport module.
[ 0.717465] RPC: Registered tcp transport module.
[ 0.717490] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.717528] PCI: CLS 0 bytes, default 64
[ 0.717852] Trying to unpack rootfs image as initramfs...
[ 1.011414] Freeing initrd memory: 9120K
[ 1.016782] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.017241] kvm [1]: IPA Size Limit: 40 bits
[ 1.017774] kvm [1]: vgic interrupt IRQ9
[ 1.018474] kvm [1]: VHE mode initialized successfully
[ 1.019997] Initialise system trusted keyrings
[ 1.020363] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.026174] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.027143] NFS: Registering the id_resolver key type
[ 1.027194] Key type id_resolver registered
[ 1.027255] Key type id_legacy registered
[ 1.027353] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.027391] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.027439] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.037580] NET: Registered protocol family 38
[ 1.037612] Key type asymmetric registered
[ 1.037634] Asymmetric key parser 'x509' registered
[ 1.037686] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.037938] io scheduler mq-deadline registered
[ 1.037963] io scheduler kyber registered
[ 1.043772] tegra186-dpaux-pinctrl 155f0000.dpaux: can not get clock
[ 1.047297] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.047407] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.047495] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.047581] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.047700] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.054045] scrncapt: init (heads:4 wins:6 planes:4)
[ 1.054120] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[ 1.055383] EINJ: ACPI disabled.
[ 1.059055] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 1.059133] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 1.059192] tegra-pmc: ### PMC reset level: L0
[ 1.059228] tegra-pmc: ### PMC reset status reg: 0x0
[ 1.059351] tegra-pmc: PMC Prod config success
[ 1.064630] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.069778] random: fast init done
[ 1.069992] printk: console [ttyTCU0] enabled
[ 2.544359] arm-smmu 10000000.iommu: probing hardware configuration...
[ 2.548516] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.553140] arm-smmu 10000000.iommu: stage 1 translation
[ 2.558672] arm-smmu 10000000.iommu: stage 2 translation
[ 2.563823] arm-smmu 10000000.iommu: nested translation
[ 2.569427] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.576329] arm-smmu 10000000.iommu: 64 context banks (0 stage-2 only)
[ 2.585852] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.589800] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.596123] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.603664] arm-smmu 12000000.iommu: probing hardware configuration...
[ 2.609405] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.614133] arm-smmu 12000000.iommu: stage 1 translation
[ 2.619644] arm-smmu 12000000.iommu: stage 2 translation
[ 2.625069] arm-smmu 12000000.iommu: nested translation
[ 2.630481] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.637673] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 2.646995] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.650788] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.657083] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.664536] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.674478] tegra_profiler: version: 1.151, samples/io: 51/30
[ 2.677776] tegra_profiler: auth: init
[ 2.681704] THERMAL EST: found 3 subdevs
[ 2.685439] THERMAL EST num_resources: 0
[ 2.689287] [THERMAL EST subdev 0]
[ 2.692331] [THERMAL EST subdev 1]
[ 2.695754] [THERMAL EST subdev 2]
[ 2.699277] THERMAL EST: Found 2 profiles, default profile is quiet
[ 2.705412] THERMAL EST: thz register success.
[ 2.709690] THERMAL EST: end of probe, return err: 0
[ 2.714938] nvsciipc: loaded module
[ 2.721394] tun: Universal TUN/TAP device driver, 1.6
[ 2.724711] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.731027] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.736587] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.741262] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.747578] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.752646] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.759080] PPP generic driver version 2.4.2
[ 2.763308] PPP BSD Compression module registered
[ 2.767865] PPP Deflate Compression module registered
[ 2.773138] PPP MPPE Compression module registered
[ 2.778136] usbcore: registered new interface driver r8152
[ 2.783390] usbcore: registered new interface driver asix
[ 2.788957] usbcore: registered new interface driver ax88179_178a
[ 2.795090] usbcore: registered new interface driver cdc_ether
[ 2.801035] usbcore: registered new interface driver net1080
[ 2.806379] usbcore: registered new interface driver cdc_subset
[ 2.812665] usbcore: registered new interface driver zaurus
[ 2.818106] usbcore: registered new interface driver cdc_ncm
[ 2.823784] usbcore: registered new interface driver aqc111
[ 2.829445] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.835769] ohci-pci: OHCI PCI platform driver
[ 2.839806] ohci-platform: OHCI generic platform driver
[ 2.845441] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 2.851664] usbcore: registered new interface driver uas
[ 2.856363] usbcore: registered new interface driver usb-storage
[ 2.862434] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 2.868284] mousedev: PS/2 mouse device common for all mice
[ 2.873522] usbcore: registered new interface driver xpad
[ 2.881292] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.883980] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:24 UTC (24)
[ 2.891783] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.898491] i2c /dev entries driver
[ 2.901665] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 2.907649] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 2.913055] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 2.918455] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 2.923742] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 2.928985] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 2.934650] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 2.946592] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 2.947214] device-mapper: uevent: version 1.0.3
[ 2.951574] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.961959] cpuidle: Initializing cpuidle driver
[ 2.965719] sdhci: Secure Digital Host Controller Interface driver
[ 2.970351] sdhci: Copyright(c) Pierre Ossman
[ 2.975052] Synopsys Designware Multimedia Card Interface Driver
[ 2.981225] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.987154] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 2.987769] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[ 3.000327] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[ 3.019047] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 3.028184] vdd-1v0: supplied by regulator-dummy
[ 3.033586] vdd-1v8-hs: supplied by regulator-dummy
[ 3.038232] vdd-1v8-ls: supplied by regulator-dummy
[ 3.042926] vdd-1v8-ao: supplied by regulator-dummy
[ 3.046822] vddio-ddr-1v1: supplied by regulator-dummy
[ 3.051421] vdd-rtc: supplied by regulator-dummy
[ 3.053306] spmic-ldo1: supplied by regulator-dummy
[ 3.054738] vdd-ao-3v3: supplied by regulator-dummy
[ 3.061245] vddio-emmc-3v3: supplied by regulator-dummy
[ 3.067747] spmic-ldo4: supplied by regulator-dummy
[ 3.069242] vdd-usb-3v3: supplied by regulator-dummy
[ 3.075641] vddio-sdmmc1-3v3: supplied by regulator-dummy
[ 3.082074] vdd-csi-1v2: supplied by vdd-1v8-ls
[ 3.088030] spmic-ldo8: supplied by vdd-1v8-ls
[ 3.089983] gpio-510 (gpio_default): hogged as output/high
[ 3.091835] gpio-511 (gpio_default): hogged as output/high
[ 3.094783] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[ 3.232301] max77686-rtc max77620-rtc: registered as rtc0
[ 3.233585] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[ 3.233965] max77620 4-003c: max77620 probe successful
ÿârm_rail_debugfs_init: /rm/vdd_cpu: failed
debugfs initialized
ÿá[ 3.941982] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.943080] hid: raw HID events driver (C) Jiri Kosina
[ 3.943739] usbcore: registered new interface driver usbhid
[ 3.943889] usbhid: USB HID core driver
[ 3.945622] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 4
[ 3.946770] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
ÿå[ 25.566348] Camera-FW on t194-rce-safe started
TCU early console enabled.
[ 25.641652] Camera-FW on t194-rce-safe ready SHA1=26f9e5f7 (crt 0.776 ms, total boot 76.110 ms)
ÿá[ 4.031782] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.032515] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.033783] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.034614] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 4.036415] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 4.037345] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 4.037989] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 4.039620] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (48)
[ 4.039983] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.042197] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=26f9e5f7dc48f7914a7654904022cf8ae53e1e9f
[ 4.048271] tegra_aon c1a0000.aon: Adding to iommu group 5
[ 4.054473] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.059442] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.066020] denver_knobs_init:MTS_VERSION:55637613
[ 4.078095] t19x_cache tegra-cache: probed
[ 4.081169] optee: probing for conduit method.
[ 4.082342] optee: revision 3.19 (3f29c61f)
[ 4.084151] optee: dynamic shared memory is enabled
[ 4.087908] optee: initialized driver
[ 4.093765] nvpmodel: initialized successfully
[ 4.094403] tegra_hv: get_hvd: not initialized yet
[ 4.099348] user_ivc_mempool: hypervisor not present
[ 4.105089] usbcore: registered new interface driver snd-usb-audio
[ 4.111387] u32 classifier
[ 4.112743] input device check on
[ 4.116609] Actions configured
[ 4.120376] Initializing XFRM netlink socket
[ 4.125228] NET: Registered protocol family 10
[ 4.131240] Segment Routing with IPv6
[ 4.132382] NET: Registered protocol family 17
[ 4.136934] NET: Registered protocol family 15
[ 4.141327] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.154585] Bluetooth: RFCOMM socket layer initialized
[ 4.159311] Bluetooth: RFCOMM ver 1.11
[ 4.163470] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.169110] Bluetooth: HIDP socket layer initialized
[ 4.174993] 9pnet: Installing 9P2000 support
[ 4.178794] Key type dns_resolver registered
[ 4.183698] registered taskstats version 1
[ 4.186909] Loading compiled-in X.509 certificates
[ 4.226208] Loaded X.509 cert 'Build time autogenerated kernel key: e63fb224cdc2a940ac382bb67b420fcb52cc4aee'
[ 4.228217] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[ 4.233865] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 4.234172] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 4.234451] tegra194-pcie 14160000.pcie: MEM 0x1400000000..0x173fffffff -> 0x1400000000
[ 4.234793] tegra194-pcie 14160000.pcie: MEM 0x1740000000..0x17ffffffff -> 0x0040000000
[ 4.348919] tegra194-pcie 14160000.pcie: Link up
[ 4.352359] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 4.352599] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 4.352750] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 4.353040] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 4.353242] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 4.353639] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 4.354051] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 4.367875] pci 0004:01:00.0: [8086:2723] type 00 class 0x028000
[ 4.368491] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 4.370148] pci 0004:01:00.0: PME# supported from D0 D3hot D3cold
[ 4.379881] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 4.380240] pci 0004:01:00.0: BAR 0: assigned [mem 0x1740000000-0x1740003fff 64bit]
[ 4.380663] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 4.381014] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 4.381323] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 4.381725] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128
[ 4.383715] pcieport 0004:00:00.0: Adding to iommu group 6
[ 4.385319] pcieport 0004:00:00.0: PME: Signaling with IRQ 24
[ 4.391247] pcieport 0004:00:00.0: AER: enabled with IRQ 24
[ 4.398345] tegra194-pcie 141a0000.pcie: Adding to iommu group 7
[ 4.407470] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 4.408195] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 4.416608] tegra194-pcie 141a0000.pcie: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 4.425140] tegra194-pcie 141a0000.pcie: MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[ 4.540932] tegra194-pcie 141a0000.pcie: Link up
[ 4.550402] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 4.550574] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 4.550704] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 4.550923] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 4.551087] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 4.551350] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 4.551640] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 4.558987] pci 0005:01:00.0: [15b7:5019] type 00 class 0x010802
[ 4.559306] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 4.559636] pci 0005:01:00.0: reg 0x20: [mem 0x00000000-0x000000ff 64bit]
[ 4.567234] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[ 4.567472] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[ 4.567753] pci 0005:01:00.0: BAR 4: assigned [mem 0x1f40004000-0x1f400040ff 64bit]
[ 4.568058] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 4.568199] pci 0005:00:00.0: bridge window [mem 0x1f40000000-0x1f400fffff]
[ 4.568442] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 4.575274] pci 0005:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 4.584217] pcieport 0005:00:00.0: Adding to iommu group 7
[ 4.589374] pcieport 0005:00:00.0: PME: Signaling with IRQ 26
[ 4.595411] pcieport 0005:00:00.0: AER: enabled with IRQ 26
[ 4.601266] nvme 0005:01:00.0: Adding to iommu group 7
[ 4.606524] nvme nvme0: pci function 0005:01:00.0
[ 4.610532] nvme 0005:01:00.0: enabling device (0000 -> 0002)
[ 4.624030] host1x 13e10000.host1x: Adding to iommu group 8
[ 4.633566] nvme nvme0: allocated 32 MiB host memory buffer.
[ 4.635791] host1x 13e10000.host1x: initialized
[ 4.636394] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 9
[ 4.639260] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 4.649562] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 10
[ 4.655973] nvme nvme0: 6/0/0 default/read/poll queues
[ 4.655997] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 4.671415] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 11
[ 4.678252] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 4.688068] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 12
[ 4.695036] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 4.704714] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 13
[ 4.711558] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 4.721630] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 14
[ 4.721637] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 4.735043] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[ 4.745051] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 15
[ 4.752212] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[ 4.762240] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 16
[ 4.769205] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[ 4.778955] falcon 15340000.vic: Adding to iommu group 17
[ 4.788196] falcon 15340000.vic: initialized
[ 4.789053] falcon 15380000.nvjpg: Adding to iommu group 17
[ 4.796456] falcon 15380000.nvjpg: initialized
[ 4.799231] falcon 154c0000.nvenc: Adding to iommu group 17
[ 4.807813] falcon 154c0000.nvenc: initialized
[ 4.809263] falcon 15a80000.nvenc1: Adding to iommu group 17
[ 4.817678] falcon 15a80000.nvenc1: initialized
[ 4.819403] nvdec 15480000.nvdec: Adding to iommu group 17
[ 4.829314] nvdec 15480000.nvdec: initialized
[ 4.829643] nvdec 15140000.nvdec1: Adding to iommu group 17
[ 4.838967] nvdec 15140000.nvdec1: initialized
[ 4.839778] tsec 15500000.tsec: Adding to iommu group 18
[ 4.847566] tsec 15500000.tsec: initialized
[ 4.849441] tsec 15100000.tsecb: Adding to iommu group 19
[ 4.857121] tsec 15100000.tsecb: initialized
[ 4.861027] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 4.884305] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 4.890434] gpio-374 (wifi-enable): hogged as output/high
[ 4.890666] gpio-431 (camera-control-output-low): hogged as output/low
[ 4.890894] gpio-432 (camera-control-output-low): hogged as output/low
[ 4.891886] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[ 4.897745] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[ 4.903681] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 4.909493] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 4.915083] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 4.921167] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 4.926469] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 4.933512] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 4.942434] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 20
[ 4.951429] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 4.958951] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[ 4.965329] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 4.974299] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 4.983311] tegra194-vi5 15c10000.vi: Adding to iommu group 21
[ 4.989455] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[ 4.998027] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 5.004521] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 5.013760] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[ 5.020135] pva 16000000.pva0: Adding to iommu group 22
[ 5.036105] pva 16000000.pva0: initialized
[ 5.037629] pva 16800000.pva1: Adding to iommu group 23
[ 5.047498] pva 16800000.pva1: initialized
[ 5.048900] nvdla 15880000.nvdla0: Adding to iommu group 24
[ 5.055540] nvdla 15880000.nvdla0: initialized
[ 5.056188] nvdla 158c0000.nvdla1: Adding to iommu group 25
[ 5.060693] nvdla 158c0000.nvdla1: initialized
[ 5.062821] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=62
[ 5.062865] tegradccommon 15200000.display-hub: host1x channel mapped
[ 5.063187] tegradc 15200000.display: Adding to iommu group 26
[ 5.063783] tegradc 15210000.display: Adding to iommu group 26
[ 5.066920] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[ 5.073392] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[ 5.079350] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 5.085011] tegradccommon 15200000.display-hub: dma mapping done
[ 5.110238] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 5.115958] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 5.121479] tegra_cec 3960000.tegra_cec: probed
[ 5.126509] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[ 5.132806] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 5.138626] kfuse 3830000.kfuse: initialized
[ 5.143350] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 5.149473] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 5.156094] serial-tegra 3100000.serial: Adding to iommu group 2
[ 5.162298] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 31, base_baud = 0) is a TEGRA_UART
[ 5.171060] serial-tegra 3110000.serial: Adding to iommu group 2
[ 5.176887] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 32, base_baud = 0) is a TEGRA_UART
[ 5.186217] serial-tegra 3140000.serial: Adding to iommu group 2
[ 5.191851] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 33, base_baud = 0) is a TEGRA_UART
[ 5.206305] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[ 5.209600] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.215366] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 5.223361] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[ 5.231936] tegra-xusb 3610000.xhci: irq 187, io mem 0x03610000
[ 5.238349] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.246462] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.253605] usb usb1: Product: xHCI Host Controller
[ 5.258576] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 5.264619] usb usb1: SerialNumber: 3610000.xhci
[ 5.269640] hub 1-0:1.0: USB hub found
[ 5.273430] hub 1-0:1.0: 4 ports detected
[ 5.277475] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.282825] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 5.290433] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 5.298012] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 5.305774] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.313280] usb usb2: Product: xHCI Host Controller
[ 5.317994] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 5.324465] usb usb2: SerialNumber: 3610000.xhci
[ 5.329567] hub 2-0:1.0: USB hub found
[ 5.332656] hub 2-0:1.0: 4 ports detected
[ 5.352622] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 5.355606] i2c i2c-2: Added multiplexed i2c bus 9
[ 5.356660] i2c i2c-2: Added multiplexed i2c bus 10
[ 5.356861] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 5.361014] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1898000 KHz, changing to: 1907200 KHz
[ 5.370309] tegra194-cpufreq ccplex: probed with BWMGR
[ 5.375560] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[ 5.376125] irq: IRQ268: trimming hierarchy from :pmc@c360000
[ 5.388477] usb-conn-gpio 3520000.xusb_padctl:ports:usb2-0:connector: repeated role: 0
[ 5.389941] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[ 5.403488] mmc0: CQHCI version 5.10
[ 5.410029] tegra194-vi5 15c10000.vi: initialized
[ 5.411442] tegradc 15200000.display: disp0 connected to head0->sor1
[ 5.412965] nvethernet 2490000.ethernet: Adding to iommu group 27
[ 5.416652] generic_infoframe_type: 0x87
[ 5.423054] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[ 5.427029] tegradc 15200000.display: DT parsed successfully
[ 5.434831] nvethernet 2490000.ethernet: failed to read MDIO address
[ 5.434840] nvethernet 2490000.ethernet: setting to default DMA bit mask
[ 5.440398] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[ 5.446878] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[ 5.446883] nvethernet 2490000.ethernet: Setting default PTP RX queue
[ 5.446915] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[ 5.455728] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 5.461748] nvethernet 2490000.ethernet: Failed to read DMA Rx ring size, using default [1024]
[ 5.461793] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pu_offset, setting default 0
[ 5.468343] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 5.468902] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 5.468908] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 5.469261] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[ 5.469285] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[ 5.470662] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[ 5.470667] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 5.473267] tegradc 15200000.display: probed
[ 5.474527] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pd_offset, setting default 0
[ 5.480908] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[ 5.544852] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 5.545054] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[ 5.570846] mmc0: Command Queue Engine enabled
[ 5.573488] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[ 5.574784] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:7a:b7:08
[ 5.579787] mmc0: periodic cache flush enabled
[ 5.579800] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 5.594334] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 5.597905] nvethernet 2490000.ethernet: Macsec not supported/Not enabled in DT
[ 5.598777] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[ 5.605178] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, chardev (510:0)
[ 5.613785] irq: IRQ270: trimming hierarchy from :pmc@c360000
[ 5.656689] irq: IRQ271: trimming hierarchy from :interrupt-controller@3881000
[ 5.656809] Console: switching to colour frame buffer device 80x30
[ 5.656877] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 5.663798] tegradc 15200000.display: fb registered
[ 5.671265] tegra-se-nvhost 15810000.se: Adding to iommu group 28
[ 5.676528] irq: IRQ272: trimming hierarchy from :pmc@c360000
[ 5.682908] tegra-se-nvhost 15810000.se: initialized
[ 5.688143] tegradc 15210000.display: disp1 connected to head1->sor
[ 5.697822] usb 1-2: New USB device found, idVendor=0424, idProduct=2744, bcdDevice= 2.05
[ 5.698149] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[ 5.698540] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 5.698791] tegra-se-nvhost 15820000.se: Adding to iommu group 29
[ 5.699766] tegra-se-nvhost 15820000.se: initialized
[ 5.701321] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 5.701786] tegra-se-nvhost 15830000.se: Adding to iommu group 30
[ 5.702465] tegra-se-nvhost 15830000.se: initialized
[ 5.703398] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 5.703869] tegra-se-nvhost 15840000.se: Adding to iommu group 31
[ 5.704538] tegra-se-nvhost 15840000.se: initialized
[ 5.704568] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.704574] usb 1-2: Product: USB2744
[ 5.704586] usb 1-2: Manufacturer: Microchip Tech
[ 5.705889] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 5.707550] tegra_actmon d230000.actmon: in actmon_register()...
[ 5.707708] tegra_actmon d230000.actmon: bwmgr_disable = 0
[ 5.708163] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 5.708700] hvc_sysfs: hypervisor is not present
[ 5.712894] tegradc 15210000.display: DT parsed successfully
[ 5.721522] hub 1-2:1.0: USB hub found
[ 5.726470] tegradc 15210000.display: Display dc.(____ptrval____) registered with id=1
[ 5.732527] hub 1-2:1.0: 5 ports detected
[ 5.736256] ALSA device list:
[ 5.736263] No soundcards found.
[ 5.737403] tegradc 15210000.display: vblank syncpt # 15 for dc 1
[ 5.825166] usb 2-3: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb
[ 5.827560] tegradc 15210000.display: vpulse3 syncpt # 16 for dc 1
[ 5.853818] usb 2-3: New USB device found, idVendor=0424, idProduct=5744, bcdDevice= 2.05
[ 5.867726] tegradc 15210000.display: probed
[ 5.873970] usb 2-3: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 5.873975] usb 2-3: Product: USB5744
[ 5.873979] usb 2-3: Manufacturer: Microchip Tech
[ 5.894049] tegradc 15210000.display: fb registered
[ 5.895221] hub 2-3:1.0: USB hub found
[ 5.902374] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 5.903195] hub 2-3:1.0: 4 ports detected
[ 5.909759] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 5.910502] Freeing unused kernel memory: 3968K
[ 5.926296] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 5.931464] tegradc 15210000.display: blank - powerdown
[ 5.936721] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 5.944755] Extcon DP: HPD disabled
[ 5.948689] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 5.955348] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 5.961126] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.976979] Run /init as init process
[ 5.980869] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 6.031003] Root device found: PARTUUID=7acf6058-ad21-4d49-81ba-9f017f910427
ÿâWARNING: clock_disable: clk_power_ungate on gated domain 27 for gpcclk
ÿá[ 6.135571] usb 1-3: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[ 6.135778] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 6.144886] tegra_cec 3960000.tegra_cec: Can't find physical address.
[ 6.145052] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 6.212878] usb 1-2.5: new high-speed USB device number 4 using tegra-xusb
[ 6.318141] usb 1-2.5: New USB device found, idVendor=0424, idProduct=2740, bcdDevice= 2.00
[ 6.318360] usb 1-2.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.318524] usb 1-2.5: Product: Hub Controller
[ 6.318625] usb 1-2.5: Manufacturer: Microchip Tech
[ 6.438156] EXT4-fs (nvme0n1p1): 1 orphan inode deleted
[ 6.438313] EXT4-fs (nvme0n1p1): recovery complete
[ 6.440372] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.451207] Rootfs mounted over PARTUUID=7acf6058-ad21-4d49-81ba-9f017f910427
[ 6.476958] Switching from initrd to actual rootfs
[ 6.560237] systemd[1]: System time before build time, advancing clock.
[ 6.871853] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 6.874399] systemd[1]: Detected architecture arm64.
[ 6.899989] systemd[1]: Set hostname to <ubuntu>.
[ 7.512090] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.512695] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 7.513074] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 7.518625] systemd[1]: Created slice system-modprobe.slice.
[ 7.519369] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.521452] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.521873] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.523758] systemd[1]: Created slice User and Session Slice.
[ 7.524562] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.526050] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.526771] systemd[1]: Reached target User and Group Name Lookups.
[ 7.526979] random: crng init done
[ 7.527134] random: 3 urandom warning(s) missed due to ratelimiting
[ 7.527541] systemd[1]: Reached target Slices.
[ 7.527929] systemd[1]: Reached target Mounting snaps.
[ 7.528256] systemd[1]: Reached target Mounted snaps.
[ 7.528597] systemd[1]: Reached target Swap.
[ 7.533326] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 7.539134] systemd[1]: Listening on Syslog Socket.
[ 7.544102] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 7.550621] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 7.557803] systemd[1]: Listening on Journal Audit Socket.
[ 7.562888] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.568878] systemd[1]: Listening on Journal Socket.
[ 7.573756] systemd[1]: Listening on udev Control Socket.
[ 7.579045] systemd[1]: Listening on udev Kernel Socket.
[ 7.589839] systemd[1]: Mounting Huge Pages File System...
[ 7.596156] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.602373] systemd[1]: Mounting RPC Pipe File System...
[ 7.609159] systemd[1]: Mounting Kernel Debug File System...
[ 7.615814] systemd[1]: Mounting Kernel Trace File System...
[ 7.623628] systemd[1]: Starting Journal Service...
[ 7.631025] systemd[1]: Starting Set the console keyboard layout...
[ 7.637436] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 7.642694] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 7.643258] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 7.651847] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 7.658543] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 7.665527] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 7.671062] systemd[1]: Starting Load Kernel Module ramoops...
[ 7.677448] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 7.684108] systemd[1]: Started Nameserver information manager.
[ 7.685626] systemd[1]: Reached target Network (Pre).
[ 7.700049] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 7.701566] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 7.726718] systemd[1]: Starting Load Kernel Modules...
[ 7.733799] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.739375] systemd[1]: Starting udev Coldplug all Devices...
[ 7.764497] systemd[1]: Mounted Huge Pages File System.
[ 7.771073] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.779518] systemd[1]: Mounted RPC Pipe File System.
[ 7.782013] systemd[1]: Mounted Kernel Debug File System.
[ 7.785868] systemd[1]: Mounted Kernel Trace File System.
[ 7.809228] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 7.812534] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[ 7.813919] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[ 7.815617] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[ 7.821307] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[ 7.824382] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 7.826687] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[ 7.830057] systemd[1]: Finished Load Kernel Module pstore_blk.
[ 7.832168] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[ 7.835345] systemd[1]: Finished Load Kernel Module pstore_zone.
[ 7.838646] systemd[1]: modprobe@ramoops.service: Succeeded.
[ 7.841464] systemd[1]: Finished Load Kernel Module ramoops.
[ 7.843514] systemd[1]: nvfb-udev.service: Succeeded.
[ 7.847911] systemd[1]: Finished NVIDIA specific first-boot udev script.
[ 7.858895] systemd[1]: Finished Load Kernel Modules.
[ 7.865253] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 7.867273] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 7.876177] systemd[1]: Mounting Kernel Configuration File System...
[ 7.882004] systemd[1]: Started OP-TEE Client Supplicant.
[ 7.884626] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 7.886370] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 7.893206] systemd[1]: Starting Load/Save Random Seed...
[ 7.900733] systemd[1]: Starting Apply Kernel Variables...
[ 7.906809] systemd[1]: Starting Create System Users...
[ 7.913979] systemd[1]: Mounted Kernel Configuration File System.
[ 7.932091] systemd[1]: Finished Set the console keyboard layout.
[ 7.967633] systemd[1]: Finished Load/Save Random Seed.
[ 8.166894] systemd[1]: proc-sys-fs-binfmt_misc.mount: Mount process exited, code=exited, status=32/n/a
[ 8.167374] systemd[1]: proc-sys-fs-binfmt_misc.mount: Failed with result 'exit-code'.
[ 8.171338] systemd[1]: Failed to mount Arbitrary Executable File Formats File System.
[ 9.816319] using random self ethernet address
[ 9.816608] using random host ethernet address
Ubuntu 20.04.5 LTS ubuntu ttyTCU0
ubuntu login:
