I am installing the newest version L4T and JetPack onto a TX1. During the installation process I am getting this error:
22:59:57 INFO: cuDNN on Target: dpkg: error processing archive /opt/nvidia/deb_repos/libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb (–install):
22:59:57 INFO: cuDNN on Target: package architecture (arm64) does not match system (amd64)
22:59:58 INFO: cuDNN on Target: Errors were encountered while processing:
22:59:58 INFO: cuDNN on Target: /opt/nvidia/deb_repos/libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb
22:59:58 INFO: cuDNN on Target: Unhandled error when running sudo dpkg -i /opt/nvidia/deb_repos/libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb
22:59:58 INFO: cuDNN on Target: [ Package Install Finished with Error ]
22:59:58 INFO: cuDNN on Target: [ NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP Install took 3s ]
22:59:58 ERROR: cuDNN on Target: [error]: dpkg install on target failed; [exec_command]: safe_apt_install “sudo dpkg -i /opt/nvidia/deb_repos/libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb” 5; sleep 5; ; [deb_path]: /home/dylan/Downloads/nvidia/sdkm_downloads/libcudnn8_8.0.0.180-1+cuda10.2_arm64.deb
22:59:58 ERROR: cuDNN on Target: command terminated with error
22:59:58 SUMMARY: cuDNN on Target: Failed to install debian package [target]
22:59:58 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta): Depends on failed component
22:59:58 SUMMARY: Multimedia API: Depends on failed component
22:59:58 SUMMARY: TensorRT on Target: Depends on failed component
22:59:58 SUMMARY: VisionWorks on Target: Install completed successfully.
What is going on here?
