I am using Jetson AGX Orin and trying to set it up for the first time.
For my first problem, I attempted to use my Display Port but did not receive a signal on my monitor. I checked the connection and changed the cable, but nothing happened.
I then tried to establish a serial connection via USB-C port and mobaXterm. However, I discovered that my revision is 0.1 instead of 1.0, so I attempted to use the following command:
sudo bash -c ‘echo “deb (link) r34.1 main” >> /etc/apt/sources.list.d/nvidia-l4t-apt-source.list’
sudo bash -c ‘echo “deb (link) main” >> /etc/apt/sources.list.d/nvidia-l4t-apt-source.list’
For my second problem, I encountered a ‘Permission Denied’ error. I searched for other solutions on Google but was unsuccessful.
I then skipped that part and ran the following commands:
sudo apt update
sudo apt dist-upgrade
For my third problem, the installation was successful, and I rebooted my device. However, I could no longer connect it to my PC using USB-C. My PC is unable to find the connection.
How can I resolve this issue?
