Would you please help a new user?
I am taking a NVidia training course in which DIGITS is used. I am attempting to reproduce the development environment on a local system.
I installed the docker related packages. I pulled DIGITS nvcr.io/nvidia/digits:19.04-caffe successfully. It appears to be running because I have the following in my terminal:
== DIGITS ==
NVIDIA Release 19.04 (build 6017623)
DIGITS Version 6.1.1
Container image Copyright © 2019, NVIDIA CORPORATION. All rights reserved.
DIGITS Copyright © 2014-2019, NVIDIA CORPORATION. All rights reserved.
Various files include modifications © NVIDIA CORPORATION. All rights reserved.
NVIDIA modifications are covered by the license terms that apply to the underlying project or file.
| _ / | | / |
| |) | | ( || | | | _
|/_|| || |__/ 6.1.1
Tensorflow support disabled.
2019-04-29 20:33:05 [INFO ] Loaded 0 jobs.
From a separate terminal I can see the container is running and port 5000 is being used:
docker container ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
e27931d2af7c nvcr.io/nvidia/digits:19.04-caffe “/usr/local/bin/nvid…” 12 minutes ago Up 11 minutes 5000/tcp digits
But when I tried 127.0.0.1:5000 from my web browser the connection was refused. Can you see any problem?
