**• Hardware Platform (Jetson / GPU)**V100
• DeepStream Version5.1.0
• TensorRT Version7.2.2.3
I plan to use deepstream-lpr-app
to recognize Chinese license plates. I have completed the following steps:
the OS supports Chinese:
But there is a problem with the Chinese display in the recognition result video
How can I solve it? Thank you
bcao
3
it can print the chinese info
Hi, do you have any new suggestions? Looking forward to your reply. Thanks
mchi
6
HI @1210586191 ,
Did you follow below suggestion in deepstream_lpr_app/deepstream-lpr-app at master · NVIDIA-AI-IOT/deepstream_lpr_app · GitHub ?
For Chinese plate recognition, please make sure the Chinese language support is in the OS.
For example:
With Ubuntu
- Install Chinese Language package .
sudo apt-get install language-pack-zh-hans
- Set the Chinese language enviroment
export LANG=zh_CN.UTF-8
export LANGUAGE=“zh_CN:zh:en_US:en”
Yes,I follow the suggestion
I realize that this problem may be caused by the Ubuntu system not installing Chinese fonts.
Then, I run this command
apt-get install ttf-wqy-microhei
to get the font package and install it.
The problem is solved!
thanks very much!
