Hey there!
We’re a couple of students on our course final’s project which revolves around computer vision using the Jetson Nano 4gb B01 equipped with the Waveshare JetBot AI Kit.
The problem is that when we try to run the pre-installed jupyter “Getting Started” notebooks, we get stuck in the second " Collision Avoidance" part, namely where you need to initialize the Camera.instance() function.
The code we’re trying to run:
import traitlets
import ipywidgets.widgets as widgets
from IPython.display import display
from jetbot import Camera, bgr8_to_jpeg
camera = Camera.instance(width=224, height=224)
image = widgets.Image(format='jpeg', width=224, height=224) # this width and height doesn't necessarily have to match the camera
camera_link = traitlets.dlink((camera, 'value'), (image, 'value'), transform=bgr8_to_jpeg)
display(image)
The error we keep getting:
RuntimeErrorTraceback (most recent call last)
/usr/local/lib/python3.6/dist-packages/jetbot-0.4.3-py3.6.egg/jetbot/camera/opencv_gst_camera.py in __init__(self, *args, **kwargs)
29 if not re:
---> 30 raise RuntimeError('Could not read image from camera.')
31
RuntimeError: Could not read image from camera.
During handling of the above exception, another exception occurred:
<ipython-input-7-1e624ef12a29> in <module>
4 from jetbot import bgr8_to_jpeg
5
----> 6 camera = Camera.instance(width=224, height=224, usb=1)
7 camera_rgb = Camera.instance(width=224, height=224, usb=1)
/usr/local/lib/python3.6/dist-packages/jetbot-0.4.3-py3.6.egg/jetbot/camera/opencv_gst_camera.py in instance(*args, **kwargs)
70 @staticmethod
71 def instance(*args, **kwargs):
---> 72 return OpenCvGstCamera(*args, **kwargs)
35 self.stop()
36 raise RuntimeError(
---> 37 'Could not initialize camera. Please see error trace.')
38
39 atexit.register(self.stop)
RuntimeError: Could not initialize camera. Please see error trace.
Checked the connections, switched between cameras (raspberry pi camera and the IMX 219 jetson camera),
v4l2-ctl --list-devices prints:
vi-output, imx219 7-0010 (platform:54080000.vi:0):
/dev/video0
Could really use anyone’s help, thanks!
