Hi
I tried to create instanceable asset through the method of the documents (5. Instanceable Assets - 5.5. Modifying Existing Assets).
I understand that I can create instanceable asset (which I think it is instanceable USD file) within Script Editor.
However, I cannot create instanceable assets even if I used provided asset Dofbot. The below is what I tried.
import omni.usd
import omni.client
from pxr import UsdGeom, Sdf
def create_parent_xforms(asset_usd_path, source_prim_path, save_as_path=None):
""" Adds a new UsdGeom.Xform prim for each Mesh/Geometry prim under source_prim_path.
Moves material assignment to new parent prim if any exists on the Mesh/Geometry prim.
Args:
asset_usd_path (str): USD file path for asset
source_prim_path (str): USD path of root prim
save_as_path (str): USD file path for modified USD stage. Defaults to None, will save in same file.
omni.usd.get_context().open_stage(asset_usd_path)
prims = [stage.GetPrimAtPath(source_prim_path)]
edits = Sdf.BatchNamespaceEdit()
while len(prims) > 0:
prim = prims.pop(0)
print(prim)
if prim.GetTypeName() in ["Mesh", "Capsule", "Sphere", "Box"]:
new_xform = UsdGeom.Xform.Define(stage, str(prim.GetPath()) + "_xform")
print(prim, new_xform)
edits.Add(Sdf.NamespaceEdit.Reparent(prim.GetPath(), new_xform.GetPath(), 0))
continue
children_prims = prim.GetChildren()
prims = prims + children_prims
stage.GetRootLayer().Apply(edits)
if save_as_path is None:
omni.usd.get_context().save_stage()
else:
omni.usd.get_context().save_as_stage(save_as_path)
def convert_asset_instanceable(asset_usd_path, source_prim_path, save_as_path=None, create_xforms=True):
""" Makes all mesh/geometry prims instanceable.
Can optionally add UsdGeom.Xform prim as parent for all mesh/geometry prims.
Makes a copy of the asset USD file, which will be used for referencing.
Updates asset file to convert all parent prims of mesh/geometry prims to reference cloned USD file.
Args:
create_xforms (bool): Whether to add new UsdGeom.Xform prims to mesh/geometry prims.
if create_xforms:
create_parent_xforms(asset_usd_path, source_prim_path, save_as_path)
asset_usd_path = save_as_path
instance_usd_path = ".".join(asset_usd_path.split(".")[:-1]) + "_meshes.usd"
omni.client.copy(asset_usd_path, instance_usd_path)
prim = prims.pop(0)
if prim:
parent_prim = prim.GetParent()
if parent_prim and not parent_prim.IsInstance():
parent_prim.GetReferences().AddReference(assetPath=instance_usd_path, primPath=str(parent_prim.GetPath()))
parent_prim.SetInstanceable(True)
continue
else:
convert_asset_instanceable('/home/bak/.local/share/ov/pkg/isaac_sim-2022.2.0/OmniIsaacGymEnvs/omniisaacgymenvs/usd/Dofbot.usd', '/Dofbot')
When I ran the above code, I got an 'AttributeError: 'NoneType' object has no attribute 'split'
message.
How can I create instanceable USD files?
