15:58:33 INFO : CUDA Toolkit for L4T : start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb to /home/flashmachine/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb
15:58:38 WARNING : CUDA Toolkit for L4T : retry to connect https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb caused by Error: The .mtd file is corrupt. Start a new download.
15:58:43 WARNING : CUDA Toolkit for L4T : retry to connect https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb caused by Error: The .mtd file is corrupt. Start a new download.
15:58:48 WARNING : CUDA Toolkit for L4T : retry to connect https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb caused by Error: The .mtd file is corrupt. Start a new download.
15:58:53 WARNING : CUDA Toolkit for L4T : retry to connect https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb caused by Error: The .mtd file is corrupt. Start a new download.
15:58:58 WARNING : CUDA Toolkit for L4T : retry to connect https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb caused by Error: The .mtd file is corrupt. Start a new download.
15:58:58 ERROR : CUDA Toolkit for L4T : download error: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb failed with Error: The .mtd file is corrupt. Start a new download.
15:58:58 WARNING : CUDA Toolkit for L4T : download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb failed, retrying 1…
15:58:58 INFO : CUDA Toolkit for L4T : start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb to /home/flashmachine/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb
16:00:03 WARNING : CUDA Toolkit for L4T : retry to connect https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb caused by Error: DevZone get download url failed: Error: socket hang up.
16:00:08 WARNING : CUDA Toolkit for L4T : retry to connect https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb caused by Error: The .mtd file is corrupt. Start a new download.
16:00:13 WARNING : CUDA Toolkit for L4T : retry to connect https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb caused by Error: The .mtd file is corrupt. Start a new download.
16:00:13 ERROR : CUDA Toolkit for L4T : download error: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb failed with Error: The .mtd file is corrupt. Start a new download.
16:00:13 WARNING : CUDA Toolkit for L4T : download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb failed, retrying 2…
16:00:13 INFO : CUDA Toolkit for L4T : start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb to /home/flashmachine/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb
16:01:18 WARNING : CUDA Toolkit for L4T : retry to connect https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb caused by Error: DevZone get download url failed: Error: socket hang up.
16:01:23 WARNING : CUDA Toolkit for L4T : retry to connect https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb caused by Error: The .mtd file is corrupt. Start a new download.
16:01:28 WARNING : CUDA Toolkit for L4T : retry to connect https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb caused by Error: The .mtd file is corrupt. Start a new download.
16:01:28 ERROR : CUDA Toolkit for L4T : download error: https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.2.1-ga/JETPACK_421_b97/cuda-repo-l4t-10-0-local-10.0.326_1.0-1_arm64.deb failed with Error: The .mtd file is corrupt. Start a new download.
Hi j90oboyle,
Could you try using eth0 ip address to download SDK components?
I have the exact same issue.
I tried looking for eth0 in my ifconfig but it’s not there even though I am connected via ethernet cable. It seems the eh0 has been renamed to enp30s0 on 18.04…
Could you please be more specific about the solution?
Hi Molloch,
Yes, for Ubuntu 18.04 is rename to “enp0s31f6”, you can use this ip address to install SDK components. Thanks!
