Cannot enable denver cores for TX2 (Jetpack 4.4 DP)
Yes, I flashed it. That reenabled the cores. There is something in /etc/apt/sources.list.d/nvidia-l4t-apt-source.list that if you disable that repo, it’s fine, but you then don’t get the updates for jetson.
If you read this thread you would see that. I wasted hours flashing and reflashing. I just want Nvidia to fix that repo and stop nerfing this device.
technically that already happened because I put it in the eMMC the first time. Now it’s in both.
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/sda1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=
LABEL backup
MENU LABEL backup kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=
Still broke-as-f
From the boot log, the filesystem from SSD is getting loaded since kernel command line has root=/dev/sda1
so the file in SSD need to be updated. Not the file in EMMC
What you can do is,
After the target is booted, edit the file in the target and reboot
/boot/extlinux/extlinux.conf
as per my post above…both have that tag.
LABEL primary
LINUX /boot/Image
INITRD /boot/initrd
LABEL backup
LINUX /boot/Image
INITRD /boot/initrd
can you post the boot log or the cat /proc/cmdline output?
cat /proc/cmdline
console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x140000@0x9607d000 lut_mem2=0x2008@0x9607a000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix=_b boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/sda1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
Doesn’t appear to want to take that instruction…every other command from that file is in here.
so the update is not there. Can you also post the output of
cat /boot/extlinux/extlinux.conf when the system is booted?
At uboot also, you should see two kernel boot options primary and backup.
TIMEOUT 30
DEFAULT primary
LABEL primary
LINUX /boot/Image
INITRD /boot/initrd
LABEL backup
LINUX /boot/Image
INITRD /boot/initrd
When testing a custom kernel, it is recommended that you create a backup of
the original kernel and add a new entry to this file so that the device can
fallback to the original kernel. To do this:
1, Make a backup of the original kernel
sudo cp /boot/Image /boot/Image.backup
2, Copy your custom kernel into /boot/Image
3, Uncomment below menu setting lines for the original kernel
4, Reboot
LABEL backup
LINUX /boot/Image.backup
INITRD /boot/initrd
APPEND ${cbootargs}
still at 2/3 power…
Still don’t know why the change cannot take effect in kernel commandline.
Could you try to remove the “quiet” in extlinux.conf, reboot and check if it is removed from kernel command line?
what does quiet do?
cat /proc/cmdline
TIMEOUT 30
DEFAULT primary
LABEL primary
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} root=/dev/sda1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=
LABEL backup
LINUX /boot/Image
INITRD /boot/initrd
“quiet” is still in kernel command line.
Looks like this extlinux file is not what the system is reading. That is why it does not take effect.
Could you check the uboot log and make sure this extlinux.conf is really the one bootloader is uring?
where is the uboot log?
Did you dump the serial console before?
nope, and I lack a serial cable and just installed windows onto my linux desktop.
Could you plug your ssd out from tegra, put it on host and open /boot/extlinux/extlinux.conf and see what is inside?
why would that be any different than what is displayed when looking at in on the tx2?
It is possible there are two extlinux.conf files.
One is on the emmc while another one is on the ssd. Obviously the one you are modifying does not take effect.
If you dump the bootloader log, then we can tell it. However, if you cannot, then I can just use such method to check.
