cannot find cusparse library in pyculib on anaconda3
I tried to install the latest version of
pyculib
, but got a problem. I used
conda install pyculib
in anaconda prompt and the installation runs successfully. But when I tried to
import pyculib
, the error occurs:
  File "<ipython-input-1-8322ab764e57>", line 1, in <module>
    import pyculib
  File "C:\Users\rl74173\AppData\Local\Continuum\anaconda3\lib\site-packages\pyculib\__init__.py", line 49, in <module>
    from . import blas, sparse, fft, rand, sorting
  File "C:\Users\rl74173\AppData\Local\Continuum\anaconda3\lib\site-packages\pyculib\sparse\__init__.py", line 2, in <module>
    from .api import *
  File "C:\Users\rl74173\AppData\Local\Continuum\anaconda3\lib\site-packages\pyculib\sparse\api.py", line 6, in <module>
    from .binding import (cuSparse, CUSPARSE_INDEX_BASE_ZERO,
  File "C:\Users\rl74173\AppData\Local\Continuum\anaconda3\lib\site-packages\pyculib\sparse\binding.py", line 1307, in <module>
    cuSparse = _init_cuSparse()
  File "C:\Users\rl74173\AppData\Local\Continuum\anaconda3\lib\site-packages\pyculib\sparse\binding.py", line 1292, in _init_cuSparse
    name, func = _init_api_function(k, v)
  File "C:\Users\rl74173\AppData\Local\Continuum\anaconda3\lib\site-packages\pyculib\sparse\binding.py", line 1237, in _init_api_function
    lib = libcusparse()
  File "C:\Users\rl74173\AppData\Local\Continuum\anaconda3\lib\site-packages\pyculib\utils\libutils.py", line 20, in __new__
    e))
Exception: Cannot open library for cusparse:
library cusparse not found
I have the same problem when trying to use
anaconda accelarate
Is this library missing in the latest version? I was able to use pyculib before. I can import pycuda and numba. I am using Anaconda3, python 3.6 on windows 10 pro.
I’m experiencing the same problem. Bump
os.environ[‘NUMBAPRO_CUDALIB’]=‘path/to/the/cudatoolkit/bin’
It works.
How would I go about applying that? I’m working with Windows 10.
You would issue that command in python, before you import numba or pyculib
It works for me. Thank you!
I tried typing
os.environ['NUMBAPRO_CUDALIB']='C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.2\bin'
in Anaconda Prompt and in Python code. Neither of those worked.
I’m not sure I understand what you mean by “issue that command in python.” I tried typing it in Python code and the Anaconda prompt and it didn’t work.
