You can try to get the image from each of your steps to see if that is normal.
Since you have verified it by using your model alone as PGIE and our nvinfer is open source. You can also get the image from each steps in the nvinfer. We have a detailed source code diagram that you can refer to.
yuweiw
36
Related topics
| Cannot obtain Classifier raw tensor output or classifier meta | 20 | 427 | February 14, 2025 | |
| How to pass custom input to non image layer of model during runtime | 13 | 369 | December 13, 2024 | |
| Create Deepstream plugin that encapsulates process of my ONNX model - where to start? | 13 | 1166 | January 22, 2024 | |
| Too much frame drop in deepstream pipeline | 20 | 459 | February 12, 2025 | |
| Object detection pre-trained model inference issue in deepstream | 50 | 1275 | August 9, 2024 | |
| How to transfer your own data in DeepStream | 9 | 244 | October 23, 2024 | |
| Custom detection ONNX model gives wrong outputs using nvinfer with DeepStream 5.1 | 16 | 3135 | September 27, 2021 | |
| Pre-processing input image with Custom object model detection | 6 | 771 | March 5, 2021 | |
| SGIE,transfer image to Device from OpenCV custom preprocessing | 7 | 1906 | March 22, 2021 | |
| How to custom preprocess in SGIE base on Deepstream 5.0? | 14 | 3603 | April 20, 2021 |
