# Cannot flash AGX Xavier
**URL:** <https://forums.developer.nvidia.com/t/cannot-flash-agx-xavier/265945>\
**Category:** Jetson AGX Xavier\
**Created:** [September 9, 2023, 8:13pm UTC](https://forums.developer.nvidia.com/t/cannot-flash-agx-xavier/265945 "2023-09-09T20:13:19Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![stevenlu443](https://developer.download.nvidia.com/images/forums/profile-default-devtalk-84.png) [@stevenlu443](https://forums.developer.nvidia.com/u/stevenlu443)\
**Post date:** [September 9, 2023, 8:13pm UTC](https://forums.developer.nvidia.com/t/cannot-flash-agx-xavier/265945/1 "2023-09-09T20:13:19Z")
</div>
[SDKM\_logs\_JetPack\_5.1.2\_Linux\_for\_Jetson\_AGX\_Xavier\_modules\_2023-09-09\_16-01-41.zip](https://forums.developer.nvidia.com/uploads/short-url/1ik8WWqjCZYbZnrFCfscMOJEDBF.zip) (142.4 KB)
Here is an excerpt from the tail end of the log:
```auto
16:09:39 INFO: Flash Jetson Linux - flash: [7.0024] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr_aligned.bin zerosbk
16:09:39 INFO: Flash Jetson Linux - flash: [7.0035] Header already present for blob_preboot_c10_prod_cr_aligned.bin
16:09:39 INFO: Flash Jetson Linux - flash: [7.0189] Header already present for blob_mce_c10_prod_cr_aligned.bin
16:09:39 INFO: Flash Jetson Linux - flash: [7.0390] Assuming zero filled SBK key
16:09:39 INFO: Flash Jetson Linux - flash: [7.0363] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr_aligned.bin zerosbk
16:09:39 INFO: Flash Jetson Linux - flash: [7.0376] adding BCH for blob_mts_c10_prod_cr_aligned.bin
16:09:39 INFO: Flash Jetson Linux - flash: [7.1115] Assuming zero filled SBK key
16:09:39 INFO: Flash Jetson Linux - flash: [7.1516] tegrahost_v2 --chip 0x19 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp-2_t194_aligned.bin zerosbk
16:09:39 INFO: Flash Jetson Linux - flash: [7.1528] adding BCH for blob_bpmp-2_t194_aligned.bin
16:09:39 INFO: Flash Jetson Linux - flash: [7.1901] Assuming zero filled SBK key
16:09:39 INFO: Flash Jetson Linux - flash: [7.2007] tegrahost_v2 --chip 0x19 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-a02-bpmp-p2888-a04_lz4_aligned.dtb zerosbk
16:09:39 INFO: Flash Jetson Linux - flash: [7.2234] Assuming zero filled SBK key
16:09:39 INFO: Flash Jetson Linux - flash: [7.2232] adding BCH for blob_spe_t194_aligned.bin
16:09:39 INFO: Flash Jetson Linux - flash: [7.2447] Assuming zero filled SBK key
16:09:39 INFO: Flash Jetson Linux - flash: [7.2427] adding BCH for blob_tos-optee_t194_aligned.img
16:09:39 INFO: Flash Jetson Linux - flash: [7.2776] Assuming zero filled SBK key
16:09:39 INFO: Flash Jetson Linux - flash: [7.2879] tegrahost_v2 --chip 0x19 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_t194_aligned.img zerosbk
16:09:39 INFO: Flash Jetson Linux - flash: [7.3073] Assuming zero filled SBK key
16:09:39 INFO: Flash Jetson Linux - flash: [7.3026] tegrahost_v2 --chip 0x19 0 --magicid CDTB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-p2888-0001-p2822-0000_aligned.dtb zerosbk
16:09:39 INFO: Flash Jetson Linux - flash: [7.3036] adding BCH for blob_tegra194-p2888-0001-p2822-0000_aligned.dtb
16:09:39 INFO: Flash Jetson Linux - flash: [7.3355] Assuming zero filled SBK key
16:09:40 INFO: Flash Jetson Linux - flash: [7.3341] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
16:09:40 INFO: Flash Jetson Linux - flash: [7.3390] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 145184
16:09:40 INFO: Flash Jetson Linux - flash: [7.3443] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 487488
16:09:41 INFO: Flash Jetson Linux - flash: [7.3530] Applet version 01.00.0000
16:09:41 INFO: Flash Jetson Linux - flash: [8.4309] Sending blob
16:09:41 INFO: Flash Jetson Linux - flash: [8.4310] [...] 015% [8.4310] [...] 031% [8.4310] [...] 046% [8.4310] [...] 062% [8.4310] [...] 078% [8.4310] [...] 093% [8.4310] [...] 100%
16:09:43 INFO: Flash Jetson Linux - flash: [9.3327] Applet version 01.00.0000
16:09:46 INFO: Flash Jetson Linux - flash: [13.6530] Bootloader version 01.00.0000
16:09:46 INFO: Flash Jetson Linux - flash: [14.1905] Bootloader version 01.00.0000
16:09:47 INFO: Flash Jetson Linux - flash: [14.1948] tegrarcm_v2 --oem platformdetails storage storage_info.bin
16:09:47 INFO: Flash Jetson Linux - flash: [14.1963] Applet is not running on device. Continue with Bootloader
16:09:48 INFO: Flash Jetson Linux - flash: [15.1606] Bootloader version 01.00.0000
16:09:48 INFO: Flash Jetson Linux - flash: [15.7002] 9 reserved_for_chain_A_boot 2688 6783
16:09:48 INFO: Flash Jetson Linux - flash: [15.7057] 9 bpmp-fw-dtb 58746344 58748391
16:09:48 INFO: Flash Jetson Linux - flash: [15.7060] 10 xusb-fw 58748392 58748711
16:09:48 INFO: Flash Jetson Linux - flash: [15.7062] 22 secure-os_b 59008320 59013439
16:09:48 INFO: Flash Jetson Linux - flash: [15.7092] Bootloader version 01.00.0000
16:09:49 INFO: Flash Jetson Linux - flash: [16.2427] Erasing sdmmc_boot: 3 ... [Done]
16:09:49 INFO: Flash Jetson Linux - flash: [17.3170] [...] 100%
16:09:50 INFO: Flash Jetson Linux - flash: [17.4245] Erasing sdmmc_user: 3 ... [Done]
16:09:50 INFO: Flash Jetson Linux - flash: [17.9260] [...] 100%
16:09:50 INFO: Flash Jetson Linux - flash: [17.9275] 000000000d0d2c01: E> NV3P_SERVER: Failed to initialize partition table from GPT.
16:09:50 INFO: Flash Jetson Linux - flash: Command tegradevflash_v2 --pt flash.xml.bin --create
16:09:50 INFO: Flash Jetson Linux - flash: Failed flashing t186ref.
16:09:50 ERROR: Flash Jetson Linux - flash: command terminated with error
16:09:50 SUMMARY: DateTime Target Setup - target: Depends on failed component
INSTALLATION FAILED
Please review the terminal tab for details. Resolve and RETRY.
Related post: [Question about AGX Xavier broken eMMC](https://forums.developer.nvidia.com/t/question-about-agx-xavier-broken-emmc/265947)
**Author:** ![kayccc](https://sea2.discourse-cdn.com/nvidia/user_avatar/forums.developer.nvidia.com/kayccc/32/14043_2.png) [@kayccc](https://forums.developer.nvidia.com/u/kayccc)\
**Post date:** [September 25, 2023, 8:02am UTC](https://forums.developer.nvidia.com/t/cannot-flash-agx-xavier/265945/2 "2023-09-25T08:02:43Z")
</div>
Duplicated with [Question about AGX Xavier broken eMMC - Jetson & Embedded Systems / Jetson AGX Xavier - NVIDIA Developer Forums](https://forums.developer.nvidia.com/t/question-about-agx-xavier-broken-emmc/265947)
**Post date:** [September 25, 2023, 8:02am UTC](https://forums.developer.nvidia.com/t/cannot-flash-agx-xavier/265945/3 "2023-09-25T08:02:48Z")
</div>
Closed on September 25, 2023, 8:02am UTC
