Cannot flash jetpack 5/L4T 34.1
Ive been trying to flash my Xavier devkit with the new JP5 release since we are still waiting on our Orin and its not working. Ive tried the jetson-xavier and jetson-agx-xavier-devkit configs and get the same error each time. No luck flashing through SDK manager either. I have the early access version from a few months ago and it flashes just fine.
My host machine is running ubuntu 18.04 and I did run ./apply_binaries. all permissions are good.
My complete flash command is sudo ./flash.sh jetson-xavier mmcblk0p1.
I get the infamous and unhelpful error 8 at the end. The only other “error” I could find is one line where gzip is trying to extract the already uncompressed kernel for some reason. I looked through flash.sh and couldnt find any references to tar,gzip or the kernel image that make sense for this.
The error is gzip: /home/xxx/Projects/L4T5/Linux_for_Tegra/kernel/Image: not in gzip format
The complete flash log is attached.
flash-error.txt (41.6 KB)
Edit: also tried it on ubuntu 20.04 and had the same problems
Could you also share the uart log from device when flash got stuck?
Sure, Looks like there is some error codes in the output:
a)
[0113.036] I> Boot-mode: Platform RCM
[0113.040] I> Platform: Silicon
[0113.042] I> Chip revision : A02
[0113.045] I> Bootrom patch version : 7 (correctly patched)
[0113.051] I> ATE fuse revision : 0x200
[0113.054] I> Ram repair fuse : 0x0
[0113.057] I> Ram Code : 0x0
[0113.060] I> rst_source: 0xb, rst_level: 0x1
[0113.065] I> USB configuration success
[0115.321] I> mb2 image downloaded
[0115.401] I> Recovery boot mode 0
[0115.407] I> UPHY full init done
[0115.414] I> MB1 done
[0115.419] I> Welcome to MB2(TBoot-BPMP) Applet (version: default.t194-mobile-a1105112)
[0115.426] I> DMA Heap @ [0x40020000 - 0x40065800]
[0115.431] I> Default Heap @ [0xd486400 - 0xd48a400]
[0115.435] W> Profiler not initialized
[0115.460] I> sdmmc DDR50 mode
[0115.464] E> SPI_FLASH: Invalid value device id: 7.
[0115.469] I> QSPI Flash is not present.
[0115.475] E> CLK_RST: instance 6 not found in module 44.
[0115.480] E> MPhy CAR configuration failed error = 1747992077
[0115.486] E> UFS initialization failed
[0115.489] I> UFS is not present
[0115.497] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0115.506] I> Found 42 partitions in SDMMC_USER (instance 3)
[0115.511] W> Profiler not initialized
[0115.514] I> Entering 3p server
[0115.518] I> USB configuration success
[0116.768] I> Populate chip info
[0116.856] I> Populate eeprom info
[0116.860] I> Populate eeprom info for module cvm
[0116.865]  > DEVICE_PROD: device prod is not initialized.
[0117.076] I> Rebooting : reboot-recovery
[0117.081] I> Reset to recovery moduses.
[0021.133] I> MB1 (prd-version: 2.2.0.0-t194-41334769-3540ffaa)
[0021.139] I> Boot-mode: RCM
[0021.141] I> Platform: Silicon
[0021.144] I> Chip revision : A02
[0021.147] I> Bootrom patch version : 7 (correctly patched)
[0021.152] I> ATE fuse revision : 0x200
[0021.156] I> Ram repair fuse : 0x0
[0021.159] I> Ram Code : 0x0
[0021.161] I> rst_source: 0xb, rst_level: 0x1
[0021.167] I> USB configuration success
[0023.301] I> bct_bootrom image downloaded
[0023.310] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0023.316] I> Temperature = 23500
[0023.319] W> Skipping boost for clk: BPMP_CPU_NIC
[0023.323] W> Skipping boost for clk: BPMP_APB
[0023.327] W> Skipping boost for clk: AXI_CBB
[0023.331] W> Skipping boost for clk: AON_CPU_NIC
[0023.335] W> Skipping boost for clk: CAN1
[0023.339] W> Skipping boost for clk: CAN2
[0023.343] I> Boot-device: SDMMC (instance: 3)
[0023.347] I> bct_mb1 image downloaded
[0023.357] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0023.365] W>  Thermal config not found in BCT
[0023.373] W>  MEMIO rail config not found in BCT
[0023.385] C> Task 0x42 failed (err: 0x8c8c011c)
[0023.390] E> Top caller module: MB1_MSS, error module: MB1_MSS, reason: 0x1c, aux_info: 0x01
[0023.397] C> Error: 0x8c8c011c
[0023.400] C> MB1(2.2.0.0-t194-41334769-3540ffaa) BIT boot status dump :
001111111111000000000001111011111100000011111111111110011100011111000000000000000000000000000000000000000000000000000000000000001010000000000101000000000
Is jetpack 4.6 still able to flash this board?
If so, could you also share the uart log?
Well… Its my own fault. I have 12 and 24V power supplies on my desk and it was running off of the 24V one. I switched over to 12V and it worked. Somehow I managed to not notice that.
