Cannot flash OS image to Orin Developer Kit via SDK Manager
Hi
Some questions after I checked the log. May need your reply for them.
  1. According to the log, your board is still able to boot up, are you able to operate with the the uart console?
  2. If you can, could you dump this result and share to us?
sudo i2cdump -y 0 0x50
If you cannot , could you share the sticker on your module?
  1. Have you ever flashed this device successfully before?
Hi, @WayneWWW ,
  1. Yes, I can login via the uart console.
  2. I attached results by i2cdump.
  3. Yes.
    log220803_i2cdump.txt (1.3 KB)
Hello, is your “yes” for this question? Then you mean this board suddenly cannot be flashed anymore?
Hi, @WayneWWW ,
Yes, I flashed this device before, but I cannot do now.
So your last successful flash was trying to flash “jetson-agx-orin-devkit-as-nx-16gb.conf”? with same host as what you are using now?
Hi, @WayneWWW ,
Yes, My last successful flash on this device was to flash “jetson-agx-orin-devkit-as-nx-16gb” with the same host.
Could you use the uart console with command “sudo reboot forced-recovery” to put the board instead and run flash.sh again and share me the log (host +uart) again?
I feel this is not an issue that could be resolved by using next release…
Hi, @WayneWWW ,
I logoned via the uart console and executed “sudo reboot forced-recovery”. After a few minutes, I run flash.sh in the recovery mode. I attached the host and uart log files.
log220803_4_minicom.txt (4.8 KB)
log220803_4_flash_ubuntu2004.txt (11.3 KB)
Hi Rayer,
Please wait for the next release first and try it. It shall be ready in 1~2 weeks.
Let me know the result after you try.
The JetPack5.0.2 GA release has been published, please get it a try. Thanks
Hi, @kayccc and @WayneWWW ,
I tried JetPack 5.0.2. Terminal shows “Bus 001 Device 010: ID 0955:7023 NVIDIA Corp. APX”, but showed “File rcm_state open failed” again. I attach the host and uart log files.
log220822_ubuntu2004.txt (11.3 KB)
log220822_minicom.txt (4.7 KB)
Are you still able to boot up the board and check log with minicom?
Yes. I saved boot log with minicom.
log220822_minicom_boot.cap (79.1 KB)
No, I mean are you still able to boot up and let it enter the ubuntu console? But not always in recovery mode.
Yes, I can login ubuntu with minicom.
If you flash the board with sdkmanager +jp5.0.2, will it still tell the same error?
Yes, sdkmanager + jetpack5.0.2 also failed to flash the board.
SDKM_logs_JetPack_5.0.2_Linux_for_Jetson_AGX_Orin_modules_2022-08-23_00-27-47.zip (142.9 KB)
Is the minicom log during flash still the same?
And which type C usb port is in use here? Are you sure you use the correct flash port?
Do we have other host machine that can test flash?
The minicom shows the same log while flashing via sdkmanager. I use type C usb port next to 40 pins.
Does other host machine means other Jetson machines? I have other Jetson machines (not Orin), but cannot overwrite their OS by flash.
