Hi, I’ve got an Jetson Orin Nano Dev Kit, and I’m trying to flash Jetpack 6.2 onto the SSD
Following the instructions here: Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
Using r36.4.3
Made it to Step 6, and here’s the terminal output, I’d scroll to the bottom where it says “Flash failed”:
[ 2.4892 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 2.4924 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 2.4926 ] Header already present for tsec_t234_aligned.bin
[ 2.4941 ] Header already present for nvdec_t234_prod_aligned.fw
[ 2.4963 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 2.5003 ] adding BCH for xusb_t234_prod_aligned.bin
[ 2.5095 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[ 2.5153 ] adding BCH for tegra234-bpmp-3767-0003-3768-super_with_odm_aligned.dtb
[ 2.5268 ] Header already present for pscfw_t234_prod_aligned.bin
[ 2.5326 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 2.5362 ] Header already present for sc7_t234_prod.bin
[ 2.5383 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 2.5405 ] adding BCH for mb2rf_t234_aligned.bin
[ 2.5420 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[ 2.5877 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 92%
[ 2.5911 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[ 2.6336 ] adding BCH for tos-optee_t234_aligned.img
[ 2.6737 ] adding BCH for eks_t234_aligned.img
[ 2.7129 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv-super_aligned.bin
[ 2.8608 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv-super_aligned.bin, ratio = 6%
[ 2.8739 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv-super_aligned_blob_w_bin_aligned.bin
[ 2.8886 ] adding BCH for spe_t234_aligned.bin
[ 2.8973 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 2.9035 ] adding BCH for adsp-fw_aligned.bin
[ 2.9137 ] INFO: compressing nvpva_020_aligned.fw
[ 2.9481 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[ 2.9500 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[ 2.9524 ] Filling MB1 storage info
[ 2.9524 ] Parsing dev params for multi chains
[ 2.9572 ] Generating br-bct
[ 2.9574 ] Updating dev and MSS params in BR BCT
[ 2.9574 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 3.0118 ] Updating bl info
[ 3.0120 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 3.0172 ] Generating br-bct
[ 3.0174 ] Updating dev and MSS params in BR BCT
[ 3.0174 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 3.0680 ] Updating bl info
[ 3.0682 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 3.0690 ] Generating BCT backup image
[ 3.0690 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 3.0692 ] 32768+0 records in
[ 3.1120 ] 32768+0 records out
[ 3.1120 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0423419 s, 774 kB/s
[ 3.1120 ]
[ 3.1120 ] Concatenating BCT for chain A to bct_backup.img
[ 3.1120 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 3.1122 ] 8192+0 records in
[ 3.1245 ] 8192+0 records out
[ 3.1246 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0119851 s, 684 kB/s
[ 3.1246 ]
[ 3.1246 ] Concatenating BCT for chain B to bct_backup.img
[ 3.1246 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 3.1248 ] 8192+0 records in
[ 3.1380 ] 8192+0 records out
[ 3.1380 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0126423 s, 648 kB/s
[ 3.1380 ]
[ 3.1380 ] Generating signatures
[ 3.1384 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.1385 ] Assuming zero filled SBK key
[ 3.1960 ] Warning: pub_key.key is not found
[ 3.1972 ] Parsing dev params for multi chains
[ 3.1972 ] Generating br-bct
[ 3.1974 ] Updating dev and MSS params in BR BCT
[ 3.1974 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 3.2494 ] Updating customer data section
[ 3.2498 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[ 3.2504 ] Updating bl info
[ 3.2507 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 3.2519 ] Generating SHA2 Hash
[ 3.2528 ] Sha saved in br_bct_BR.sha
[ 3.2525 ] Get Signed section of bct
[ 3.2526 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 3.2532 ] Signing BCT
[ 3.2536 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.2537 ] Assuming zero filled SBK key
[ 3.2548 ] Sha saved in br_bct_BR.sha
[ 3.2550 ] Warning: pub_key.key is not found
[ 3.2546 ] Updating BCT with signature
[ 3.2547 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 3.2549 ] Offset :4608 Len :3584
[ 3.2552 ] Generating SHA2 Hash
[ 3.2556 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 3.2557 ] Assuming zero filled SBK key
[ 3.2569 ] Sha saved in br_bct_BR.sha
[ 3.2567 ] Updating BCT with SHA2 Hash
[ 3.2568 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 3.2570 ] Offset :4608 Len :3584
[ 3.2572 ] Offset :68 Len :8124
[ 3.2574 ] Generating br-bct
[ 3.2575 ] Updating dev and MSS params in BR BCT
[ 3.2575 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 3.3082 ] Updating customer data section
[ 3.3086 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[ 3.3091 ] Updating bl info
[ 3.3093 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 3.3106 ] Generating SHA2 Hash
[ 3.3115 ] Sha saved in br_bct_BR.sha
[ 3.3112 ] Get Signed section of bct
[ 3.3114 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 3.3118 ] Signing BCT
[ 3.3123 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.3124 ] Assuming zero filled SBK key
[ 3.3136 ] Sha saved in br_bct_BR.sha
[ 3.3138 ] Warning: pub_key.key is not found
[ 3.3134 ] Updating BCT with signature
[ 3.3135 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 3.3137 ] Offset :4608 Len :3584
[ 3.3140 ] Generating SHA2 Hash
[ 3.3145 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 3.3146 ] Assuming zero filled SBK key
[ 3.3161 ] Sha saved in br_bct_BR.sha
[ 3.3159 ] Updating BCT with SHA2 Hash
[ 3.3161 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 3.3162 ] Offset :4608 Len :3584
[ 3.3164 ] Offset :68 Len :8124
[ 3.3166 ] Generating BCT backup image
[ 3.3166 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 3.3169 ] 32768+0 records in
[ 3.3601 ] 32768+0 records out
[ 3.3601 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0427226 s, 767 kB/s
[ 3.3602 ]
[ 3.3602 ] Concatenating BCT for chain A to bct_backup.img
[ 3.3602 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 3.3606 ] 8192+0 records in
[ 3.3740 ] 8192+0 records out
[ 3.3741 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0129293 s, 634 kB/s
[ 3.3741 ]
[ 3.3741 ] Concatenating BCT for chain B to bct_backup.img
[ 3.3741 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 3.3743 ] 8192+0 records in
[ 3.3870 ] 8192+0 records out
[ 3.3870 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0122604 s, 668 kB/s
[ 3.3870 ]
[ 3.3870 ] Generating coldboot mb1-bct
[ 3.3873 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 3.3875 ] MB1-BCT version: 0.13
[ 3.3887 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[ 3.3888 ] Added Platform Config 0 data with size :- 2416
[ 3.3899 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[ 3.3900 ] WARNING: unknown node 'g2'
[ 3.3901 ] WARNING: unknown node 'g2'
[ 3.3902 ] WARNING: unknown node 'g9'
[ 3.3902 ] Added Platform Config 2 data with size :- 24
[ 3.3902 ]
[ 3.3902 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[ 3.3902 ] Added Platform Config 4 data with size :- 288
[ 3.3902 ]
[ 3.3902 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[ 3.3902 ] Added Platform Config 3 data with size :- 52
[ 3.3902 ]
[ 3.3902 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[ 3.3902 ] WARNING: unknown property 'major'
[ 3.3902 ] WARNING: unknown property 'minor'
[ 3.3902 ] Added Platform Config 5 data with size :- 512
[ 3.3902 ]
[ 3.3902 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[ 3.3902 ] Added Platform Config 7 data with size :- 380
[ 3.3902 ]
[ 3.3902 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 3.3903 ] Added Platform Config 8 data with size :- 24
[ 3.3903 ]
[ 3.3903 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 3.3903 ] Added Platform Config 9 data with size :- 100
[ 3.3903 ]
[ 3.3903 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[ 3.3903 ] ModuleCount 0 NumProdNames 0
[ 3.3903 ] Added Platform Config 6 data with size :- 16
[ 3.3903 ]
[ 3.3903 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 3.3903 ]
[ 3.3903 ] Updating mb1-bct with firmware information
[ 3.3905 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 3.3913 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 3.3917 ] Generating SHA2 Hash for mb1bct
[ 3.3927 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[ 3.3933 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[ 3.3931 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 3.3933 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 3.3943 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.3944 ] Assuming zero filled SBK key
[ 3.3953 ] Warning: pub_key.key is not found
[ 3.3950 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 3.3957 ] Generating recovery mb1-bct
[ 3.3959 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 3.3960 ] MB1-BCT version: 0.13
[ 3.3969 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[ 3.3971 ] Added Platform Config 0 data with size :- 2416
[ 3.3980 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[ 3.3982 ] WARNING: unknown node 'g2'
[ 3.3983 ] WARNING: unknown node 'g2'
[ 3.3983 ] WARNING: unknown node 'g9'
[ 3.3983 ] Added Platform Config 2 data with size :- 24
[ 3.3983 ]
[ 3.3983 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[ 3.3983 ] Added Platform Config 4 data with size :- 288
[ 3.3983 ]
[ 3.3983 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[ 3.3983 ] Added Platform Config 3 data with size :- 52
[ 3.3983 ]
[ 3.3983 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[ 3.3983 ] WARNING: unknown property 'major'
[ 3.3984 ] WARNING: unknown property 'minor'
[ 3.3984 ] Added Platform Config 5 data with size :- 512
[ 3.3984 ]
[ 3.3984 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[ 3.3984 ] WARNING: unknown property 'major'
[ 3.3984 ] Added Platform Config 7 data with size :- 380
[ 3.3984 ]
[ 3.3984 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 3.3984 ] Added Platform Config 8 data with size :- 24
[ 3.3984 ]
[ 3.3984 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 3.3984 ] Added Platform Config 9 data with size :- 100
[ 3.3984 ]
[ 3.3984 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[ 3.3984 ] ModuleCount 0 NumProdNames 0
[ 3.3984 ] Added Platform Config 6 data with size :- 16
[ 3.3984 ]
[ 3.3984 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 3.3984 ]
[ 3.3984 ] Updating mb1-bct with firmware information
[ 3.3986 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[ 3.3993 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 3.3995 ] Generating SHA2 Hash for mb1bct
[ 3.4005 ] Sha saved in mb1_bct_MB1_aligned.sha
[ 3.4010 ] Sha saved in mb1_bct_MB1.sha
[ 3.4008 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 3.4010 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 3.4020 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.4020 ] Assuming zero filled SBK key
[ 3.4028 ] Warning: pub_key.key is not found
[ 3.4026 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 3.4032 ] Generating coldboot mem-bct
[ 3.4034 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[ 3.4035 ] packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[ 3.4545 ] Packing sdram param for instance[0]
[ 3.4546 ] Packing sdram param for instance[1]
[ 3.4547 ] Packing sdram param for instance[2]
[ 3.4548 ] Packing sdram param for instance[3]
[ 3.4549 ] Packing sdram param for instance[4]
[ 3.4550 ] Packing sdram param for instance[5]
[ 3.4551 ] Packing sdram param for instance[6]
[ 3.4552 ] Packing sdram param for instance[7]
[ 3.4553 ] Packing sdram param for instance[8]
[ 3.4554 ] Packing sdram param for instance[9]
[ 3.4555 ] Packing sdram param for instance[10]
[ 3.4556 ] Packing sdram param for instance[11]
[ 3.4557 ] Packing sdram param for instance[12]
[ 3.4558 ] Packing sdram param for instance[13]
[ 3.4559 ] Packing sdram param for instance[14]
[ 3.4560 ] Packing sdram param for instance[15]
[ 3.5067 ] Getting sector size from pt
[ 3.5071 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 3.5074 ] BlockSize read from layout is 0x200
[ 3.5076 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct --ratchet_blob ratchet_blob.bin
[ 3.5078 ] Binary 0 length is 58752
[ 3.5079 ] Binary 0 align length is 58880
[ 3.5085 ] Binary 1 length is 58752
[ 3.5085 ] Binary 1 align length is 58880
[ 3.5091 ] Binary 2 length is 58752
[ 3.5092 ] Binary 2 align length is 58880
[ 3.5097 ] Binary 3 length is 58752
[ 3.5098 ] Binary 3 align length is 58880
[ 3.5103 ] Buffer length is 235520
[ 3.5104 ] adding BCH for tegra234-p3767-0001-sdram-l4t_cpp_1.bct
[ 3.5105 ] new length is 243712
[ 3.5111 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[ 3.5116 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[ 3.5118 ] Header already present for mem_coldboot_aligned.bct
[ 3.5129 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.5130 ] Assuming zero filled SBK key
[ 3.5141 ] Warning: pub_key.key is not found
[ 3.5139 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[ 3.5149 ] Generating recovery mem-bct
[ 3.5151 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[ 3.5153 ] packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[ 3.5676 ] Packing sdram param for instance[0]
[ 3.5678 ] Packing sdram param for instance[1]
[ 3.5679 ] Packing sdram param for instance[2]
[ 3.5680 ] Packing sdram param for instance[3]
[ 3.5681 ] Packing sdram param for instance[4]
[ 3.5683 ] Packing sdram param for instance[5]
[ 3.5683 ] Packing sdram param for instance[6]
[ 3.5684 ] Packing sdram param for instance[7]
[ 3.5685 ] Packing sdram param for instance[8]
[ 3.5686 ] Packing sdram param for instance[9]
[ 3.5687 ] Packing sdram param for instance[10]
[ 3.5688 ] Packing sdram param for instance[11]
[ 3.5689 ] Packing sdram param for instance[12]
[ 3.5690 ] Packing sdram param for instance[13]
[ 3.5691 ] Packing sdram param for instance[14]
[ 3.5691 ] Packing sdram param for instance[15]
[ 3.6202 ] Generating mem_bct based on ramcode group number
[ 3.6202 ] Got ramcode 2 from the command line
[ 3.6202 ] Using ramcode group number 0
[ 3.6202 ] Disabled BPMP dtb trim, using default dtb
[ 3.6202 ]
[ 3.6208 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[ 3.6213 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[ 3.6215 ] adding BCH for mem_rcm_aligned.bct
[ 3.6236 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.6236 ] Assuming zero filled SBK key
[ 3.6246 ] Warning: pub_key.key is not found
[ 3.6245 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 3.6252 ] Generating all 4 mem_bct for ramcode group (0..3)
[ 3.6252 ] Disabled BPMP dtb trim, using default dtb
[ 3.6252 ]
[ 3.6255 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_0_aligned.bct
[ 3.6260 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_0_aligned.bct zerosbk
[ 3.6262 ] adding BCH for mem_rcm_0_aligned.bct
[ 3.6283 ] tegrasign_v3.py --key None --list mem_rcm_0_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.6283 ] Assuming zero filled SBK key
[ 3.6291 ] Warning: pub_key.key is not found
[ 3.6289 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_0_aligned_sigheader.bct.encrypt mem_rcm_0_aligned_sigheader.bct.hash zerosbk
[ 3.6296 ] Disabled BPMP dtb trim, using default dtb
[ 3.6296 ]
[ 3.6299 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_1_aligned.bct
[ 3.6304 ] tegrahost_v2 --chip 0x23 0 --magicid MEM1 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_1_aligned.bct zerosbk
[ 3.6305 ] adding BCH for mem_rcm_1_aligned.bct
[ 3.6326 ] tegrasign_v3.py --key None --list mem_rcm_1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.6326 ] Assuming zero filled SBK key
[ 3.6334 ] Warning: pub_key.key is not found
[ 3.6331 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_1_aligned_sigheader.bct.encrypt mem_rcm_1_aligned_sigheader.bct.hash zerosbk
[ 3.6338 ] Disabled BPMP dtb trim, using default dtb
[ 3.6338 ]
[ 3.6342 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_2_aligned.bct
[ 3.6347 ] tegrahost_v2 --chip 0x23 0 --magicid MEM2 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_2_aligned.bct zerosbk
[ 3.6348 ] adding BCH for mem_rcm_2_aligned.bct
[ 3.6369 ] tegrasign_v3.py --key None --list mem_rcm_2_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.6370 ] Assuming zero filled SBK key
[ 3.6377 ] Warning: pub_key.key is not found
[ 3.6375 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_2_aligned_sigheader.bct.encrypt mem_rcm_2_aligned_sigheader.bct.hash zerosbk
[ 3.6382 ] Disabled BPMP dtb trim, using default dtb
[ 3.6382 ]
[ 3.6385 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_3_aligned.bct
[ 3.6390 ] tegrahost_v2 --chip 0x23 0 --magicid MEM3 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_3_aligned.bct zerosbk
[ 3.6391 ] adding BCH for mem_rcm_3_aligned.bct
[ 3.6412 ] tegrasign_v3.py --key None --list mem_rcm_3_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.6413 ] Assuming zero filled SBK key
[ 3.6421 ] Warning: pub_key.key is not found
[ 3.6419 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_3_aligned_sigheader.bct.encrypt mem_rcm_3_aligned_sigheader.bct.hash zerosbk
[ 3.6426 ] Copying signatures
[ 3.6428 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 3.6872 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[ 3.6874 ] gpt_secondary_3_0.bin:
[ 3.6878 ] partition_id partition_name StartingLba EndingLba
[ 3.6879 ] 1 BCT 0 2047
[ 3.6881 ] 2 A_mb1 2048 3071
[ 3.6882 ] 3 A_psc_bl1 3072 3583
[ 3.6884 ] 4 A_MB1_BCT 3584 3839
[ 3.6885 ] 5 A_MEM_BCT 3840 4351
[ 3.6886 ] 6 A_tsec-fw 4352 6399
[ 3.6888 ] 7 A_nvdec 6400 8447
[ 3.6889 ] 8 A_mb2 8448 9471
[ 3.6891 ] 9 A_xusb-fw 9472 9983
[ 3.6892 ] 10 A_bpmp-fw 9984 13055
[ 3.6894 ] 11 A_bpmp-fw-dtb 13056 21247
[ 3.6895 ] 12 A_psc-fw 21248 22783
[ 3.6896 ] 13 A_mts-mce 22784 23807
[ 3.6896 ] 14 A_sc7 23808 24191
[ 3.6896 ] 15 A_pscrf 24192 24575
[ 3.6897 ] 16 A_mb2rf 24576 24831
[ 3.6897 ] 17 A_cpu-bootloader 24832 31999
[ 3.6897 ] 18 A_secure-os 32000 40191
[ 3.6897 ] 19 A_smm-fw 40192 44287
[ 3.6897 ] 20 A_eks 44288 44799
[ 3.6897 ] 21 A_dce-fw 44800 55039
[ 3.6897 ] 22 A_spe-fw 55040 56191
[ 3.6897 ] 23 A_rce-fw 56192 58239
[ 3.6897 ] 24 A_adsp-fw 58240 62335
[ 3.6897 ] 25 A_pva-fw 62336 62847
[ 3.6897 ] 26 A_reserved_on_boot 62848 65023
[ 3.6897 ] 27 B_mb1 65024 66047
[ 3.6897 ] 28 B_psc_bl1 66048 66559
[ 3.6897 ] 29 B_MB1_BCT 66560 66815
[ 3.6897 ] 30 B_MEM_BCT 66816 67327
[ 3.6897 ] 31 B_tsec-fw 67328 69375
[ 3.6897 ] 32 B_nvdec 69376 71423
[ 3.6897 ] 33 B_mb2 71424 72447
[ 3.6897 ] 34 B_xusb-fw 72448 72959
[ 3.6897 ] 35 B_bpmp-fw 72960 76031
[ 3.6897 ] 36 B_bpmp-fw-dtb 76032 84223
[ 3.6897 ] 37 B_psc-fw 84224 85759
[ 3.6897 ] 38 B_mts-mce 85760 86783
[ 3.6897 ] 39 B_sc7 86784 87167
[ 3.6897 ] 40 B_pscrf 87168 87551
[ 3.6897 ] 41 B_mb2rf 87552 87807
[ 3.6897 ] 42 B_cpu-bootloader 87808 94975
[ 3.6897 ] 43 B_secure-os 94976 103167
[ 3.6897 ] 44 B_smm-fw 103168 107263
[ 3.6897 ] 45 B_eks 107264 107775
[ 3.6897 ] 46 B_dce-fw 107776 118015
[ 3.6897 ] 47 B_spe-fw 118016 119167
[ 3.6897 ] 48 B_rce-fw 119168 121215
[ 3.6897 ] 49 B_adsp-fw 121216 125311
[ 3.6898 ] 50 B_pva-fw 125312 125823
[ 3.6898 ] 51 B_reserved_on_boot 125824 127999
[ 3.6898 ] 52 uefi_variables 128000 128511
[ 3.6898 ] 53 uefi_ftw 128512 129535
[ 3.6898 ] 54 reserved 129536 129919
[ 3.6898 ] 55 worm 129920 130303
[ 3.6898 ] 56 BCT-boot-chain_backup 130304 130431
[ 3.6898 ] 57 reserved_partition 130432 130559
[ 3.6898 ] 58 secondary_gpt_backup 130560 130687
[ 3.6898 ] 59 B_VER 130688 130815
[ 3.6898 ] 60 A_VER 130816 130943
[ 3.6898 ] gpt_primary_6_0.bin:
[ 3.6898 ] partition_id partition_name StartingLba EndingLba
[ 3.6898 ] 1 APP 3050048 119537623
[ 3.6898 ] 2 A_kernel 40 262183
[ 3.6898 ] 3 A_kernel-dtb 262184 263719
[ 3.6898 ] 4 A_reserved_on_user 263720 328487
[ 3.6898 ] 5 B_kernel 328488 590631
[ 3.6898 ] 6 B_kernel-dtb 590632 592167
[ 3.6898 ] 7 B_reserved_on_user 592168 656935
[ 3.6898 ] 8 recovery 656936 820775
[ 3.6898 ] 9 recovery-dtb 820776 821799
[ 3.6898 ] 10 esp 821800 952871
[ 3.6898 ] 11 recovery_alt 952872 1116711
[ 3.6898 ] 12 recovery-dtb_alt 1116712 1117735
[ 3.6898 ] 13 esp_alt 1117736 1248807
[ 3.6898 ] 14 UDA 1248832 2068031
[ 3.6898 ] 15 reserved 2068032 3050047
[ 3.6898 ] gpt_secondary_6_0.bin:
[ 3.6899 ] 6 B_kernel-dtb 590632 592167
[ 3.6899 ] 7 B_reserved_on_user 592168 656935
[ 3.6899 ] 8 recovery 656936 820775
[ 3.6899 ] 9 recovery-dtb 820776 821799
[ 3.6899 ] 10 esp 821800 952871
[ 3.6899 ] 11 recovery_alt 952872 1116711
[ 3.6899 ] 12 recovery-dtb_alt 1116712 1117735
[ 3.6899 ] 13 esp_alt 1117736 1248807
[ 3.6899 ] 14 UDA 1248832 2068031
[ 3.6899 ] 15 reserved 2068032 3050047
[ 3.6899 ]
[ 3.6910 ] Get magic id
[ 3.6912 ] tegraparser_v2 --get_magic psc_fw
[ 3.6914 ] PFWP
[ 3.6915 ] partition type psc_fw, magic id = PFWP
[ 3.6921 ] tegrahost_v2 --chip 0x23 0 --align pscfw_t234_prod_aligned.bin
[ 3.6933 ] tegrahost_v2 --chip 0x23 0 --magicid PFWP --ratchet_blob ratchet_blob.bin --appendsigheader pscfw_t234_prod_aligned.bin zerosbk
[ 3.6935 ] Header already present for pscfw_t234_prod_aligned.bin
[ 3.6977 ] tegrasign_v3.py --key None --list pscfw_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.6978 ] Assuming zero filled SBK key
[ 3.6988 ] Warning: pub_key.key is not found
[ 3.6986 ] tegrahost_v2 --chip 0x23 0 --updatesigheader pscfw_t234_prod_aligned_sigheader.bin.encrypt pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[ 3.6999 ] Get magic id
[ 3.7001 ] tegraparser_v2 --get_magic mts_mce
[ 3.7003 ] MTSM
[ 3.7004 ] partition type mts_mce, magic id = MTSM
[ 3.7009 ] tegrahost_v2 --chip 0x23 0 --align mce_flash_o10_cr_prod_aligned.bin
[ 3.7014 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --ratchet_blob ratchet_blob.bin --appendsigheader mce_flash_o10_cr_prod_aligned.bin zerosbk
[ 3.7015 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 3.7043 ] tegrasign_v3.py --key None --list mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.7044 ] Assuming zero filled SBK key
[ 3.7054 ] Warning: pub_key.key is not found
[ 3.7052 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[ 3.7061 ] Get magic id
[ 3.7063 ] tegraparser_v2 --get_magic tsec_fw
[ 3.7065 ] TSEC
[ 3.7066 ] partition type tsec_fw, magic id = TSEC
[ 3.7071 ] tegrahost_v2 --chip 0x23 0 --align tsec_t234_aligned.bin
[ 3.7076 ] tegrahost_v2 --chip 0x23 0 --magicid TSEC --ratchet_blob ratchet_blob.bin --appendsigheader tsec_t234_aligned.bin zerosbk
[ 3.7077 ] Header already present for tsec_t234_aligned.bin
[ 3.7104 ] tegrasign_v3.py --key None --list tsec_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.7105 ] Assuming zero filled SBK key
[ 3.7113 ] Warning: pub_key.key is not found
[ 3.7111 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tsec_t234_aligned_sigheader.bin.encrypt tsec_t234_aligned_sigheader.bin.hash zerosbk
[ 3.7122 ] Get magic id
[ 3.7124 ] tegraparser_v2 --get_magic mb2_applet
[ 3.7126 ] MB2A
[ 3.7127 ] partition type mb2_applet, magic id = MB2A
[ 3.7130 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 3.7135 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader applet_t234_aligned.bin zerosbk
[ 3.7136 ] adding BCH for applet_t234_aligned.bin
[ 3.7206 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.7206 ] Assuming zero filled SBK key
[ 3.7216 ] Warning: pub_key.key is not found
[ 3.7214 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 3.7227 ] Generating recovery mb2-bct
[ 3.7228 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[ 3.7229 ] WARNING: unknown property 'tfc_version'
[ 3.7238 ] WARNING: unknown property 'addr_header_version'
[ 3.7286 ] Updating mb2-bct with storage information for RCM
[ 3.7288 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 3.7294 ] Concatenating mb2-bct to mb2 binary
[ 3.7294 ] mb2_bin_file = mb2_t234.bin
[ 3.7294 ] mb2_bct_file = mb2_bct_MB2.bct
[ 3.7297 ] Get magic id
[ 3.7299 ] tegraparser_v2 --get_magic mb2_bootloader
[ 3.7300 ] MB2B
[ 3.7301 ] partition type mb2_bootloader, magic id = MB2B
[ 3.7306 ] tegrahost_v2 --chip 0x23 0 --align mb2_t234_with_mb2_bct_MB2_aligned.bin
[ 3.7310 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[ 3.7312 ] adding BCH for mb2_t234_with_mb2_bct_MB2_aligned.bin
[ 3.7416 ] tegrasign_v3.py --key None --list mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.7417 ] Assuming zero filled SBK key
[ 3.7428 ] Warning: pub_key.key is not found
[ 3.7426 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[ 3.7441 ] Get magic id
[ 3.7443 ] tegraparser_v2 --get_magic xusb_fw
[ 3.7445 ] XUSB
[ 3.7447 ] partition type xusb_fw, magic id = XUSB
[ 3.7453 ] tegrahost_v2 --chip 0x23 0 --align xusb_t234_prod_aligned.bin
[ 3.7458 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --ratchet_blob ratchet_blob.bin --appendsigheader xusb_t234_prod_aligned.bin zerosbk
[ 3.7459 ] adding BCH for xusb_t234_prod_aligned.bin
[ 3.7502 ] tegrasign_v3.py --key None --list xusb_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.7502 ] Assuming zero filled SBK key
[ 3.7510 ] Warning: pub_key.key is not found
[ 3.7508 ] tegrahost_v2 --chip 0x23 0 --updatesigheader xusb_t234_prod_aligned_sigheader.bin.encrypt xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[ 3.7517 ] Get magic id
[ 3.7519 ] tegraparser_v2 --get_magic pva_fw
[ 3.7521 ] PVAF
[ 3.7522 ] partition type pva_fw, magic id = PVAF
[ 3.7542 ] tegrahost_v2 --chip 0x23 0 --align nvpva_020_aligned.fw
[ 3.7546 ] tegrahost_v2 --chip 0x23 0 --magicid PVAF --ratchet_blob ratchet_blob.bin --appendsigheader nvpva_020_aligned.fw zerosbk
[ 3.7548 ] adding BCH for nvpva_020_aligned.fw
[ 3.8039 ] tegrasign_v3.py --key None --list nvpva_020_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.8040 ] Assuming zero filled SBK key
[ 3.8073 ] Warning: pub_key.key is not found
[ 3.8071 ] tegrahost_v2 --chip 0x23 0 --updatesigheader nvpva_020_aligned_sigheader.fw.encrypt nvpva_020_aligned_sigheader.fw.hash zerosbk
[ 3.8119 ] Kernel DTB used: kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb
[ 3.8119 ] Concatenating kernel-dtb to dce-fw binary
[ 3.8119 ] dce_bin = display-t234-dce.bin
[ 3.8119 ] kernel_dtb = kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb
[ 3.8119 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv-super.bin
[ 3.8221 ] Get magic id
[ 3.8224 ] tegraparser_v2 --get_magic dce_fw
[ 3.8226 ] DCEF
[ 3.8227 ] partition type dce_fw, magic id = DCEF
[ 3.8334 ] tegrahost_v2 --chip 0x23 0 --align display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv-super_aligned.bin
[ 3.8339 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --ratchet_blob ratchet_blob.bin --appendsigheader display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv-super_aligned.bin zerosbk
[ 3.8341 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv-super_aligned.bin
[ 4.1019 ] tegrasign_v3.py --key None --list display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv-super_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.1021 ] Assuming zero filled SBK key
[ 4.1252 ] Warning: pub_key.key is not found
[ 4.1252 ] tegrahost_v2 --chip 0x23 0 --updatesigheader display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv-super_aligned_sigheader.bin.encrypt display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv-super_aligned_sigheader.bin.hash zerosbk
[ 4.1595 ] Get magic id
[ 4.1598 ] tegraparser_v2 --get_magic nvdec
[ 4.1600 ] NDEC
[ 4.1601 ] partition type nvdec, magic id = NDEC
[ 4.1606 ] tegrahost_v2 --chip 0x23 0 --align nvdec_t234_prod_aligned.fw
[ 4.1611 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --ratchet_blob ratchet_blob.bin --appendsigheader nvdec_t234_prod_aligned.fw zerosbk
[ 4.1613 ] Header already present for nvdec_t234_prod_aligned.fw
[ 4.1652 ] tegrasign_v3.py --key None --list nvdec_t234_prod_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.1653 ] Assuming zero filled SBK key
[ 4.1665 ] Warning: pub_key.key is not found
[ 4.1664 ] tegrahost_v2 --chip 0x23 0 --updatesigheader nvdec_t234_prod_aligned_sigheader.fw.encrypt nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[ 4.1676 ] Get magic id
[ 4.1678 ] tegraparser_v2 --get_magic bpmp_fw
[ 4.1679 ] BPMF
[ 4.1681 ] partition type bpmp_fw, magic id = BPMF
[ 4.1692 ] tegrahost_v2 --chip 0x23 0 --align bpmp_t234-TE950M-A1_prod_aligned.bin
[ 4.1697 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader bpmp_t234-TE950M-A1_prod_aligned.bin zerosbk
[ 4.1700 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[ 4.1822 ] tegrasign_v3.py --key None --list bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.1823 ] Assuming zero filled SBK key
[ 4.1849 ] Warning: pub_key.key is not found
[ 4.1847 ] tegrahost_v2 --chip 0x23 0 --updatesigheader bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin.encrypt bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin.hash zerosbk
[ 4.1876 ] Using bpmp-dtb concatenated with odmdata
[ 4.1876 ] Get magic id
[ 4.1878 ] tegraparser_v2 --get_magic bpmp_fw_dtb
[ 4.1880 ] BPMD
[ 4.1881 ] partition type bpmp_fw_dtb, magic id = BPMD
[ 4.1887 ] tegrahost_v2 --chip 0x23 0 --align tegra234-bpmp-3767-0003-3768-super_with_odm_aligned.dtb
[ 4.1891 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader tegra234-bpmp-3767-0003-3768-super_with_odm_aligned.dtb zerosbk
[ 4.1893 ] adding BCH for tegra234-bpmp-3767-0003-3768-super_with_odm_aligned.dtb
[ 4.1957 ] tegrasign_v3.py --key None --list tegra234-bpmp-3767-0003-3768-super_with_odm_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.1958 ] Assuming zero filled SBK key
[ 4.1970 ] Warning: pub_key.key is not found
[ 4.1968 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tegra234-bpmp-3767-0003-3768-super_with_odm_aligned_sigheader.dtb.encrypt tegra234-bpmp-3767-0003-3768-super_with_odm_aligned_sigheader.dtb.hash zerosbk
[ 4.1979 ] Get magic id
[ 4.1980 ] tegraparser_v2 --get_magic rce_fw
[ 4.1982 ] RCEF
[ 4.1983 ] partition type rce_fw, magic id = RCEF
[ 4.1989 ] tegrahost_v2 --chip 0x23 0 --align camera-rtcpu-t234-rce_aligned.img
[ 4.1993 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --ratchet_blob ratchet_blob.bin --appendsigheader camera-rtcpu-t234-rce_aligned.img zerosbk
[ 4.1995 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 4.2101 ] tegrasign_v3.py --key None --list camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.2103 ] Assuming zero filled SBK key
[ 4.2118 ] Warning: pub_key.key is not found
[ 4.2117 ] tegrahost_v2 --chip 0x23 0 --updatesigheader camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[ 4.2132 ] Get magic id
[ 4.2135 ] tegraparser_v2 --get_magic ape_fw
[ 4.2136 ] APEF
[ 4.2137 ] partition type ape_fw, magic id = APEF
[ 4.2143 ] tegrahost_v2 --chip 0x23 0 --align adsp-fw_aligned.bin
[ 4.2148 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --ratchet_blob ratchet_blob.bin --appendsigheader adsp-fw_aligned.bin zerosbk
[ 4.2149 ] adding BCH for adsp-fw_aligned.bin
[ 4.2245 ] tegrasign_v3.py --key None --list adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.2246 ] Assuming zero filled SBK key
[ 4.2257 ] Warning: pub_key.key is not found
[ 4.2255 ] tegrahost_v2 --chip 0x23 0 --updatesigheader adsp-fw_aligned_sigheader.bin.encrypt adsp-fw_aligned_sigheader.bin.hash zerosbk
[ 4.2269 ] Get magic id
[ 4.2271 ] tegraparser_v2 --get_magic spe_fw
[ 4.2273 ] SPEF
[ 4.2274 ] partition type spe_fw, magic id = SPEF
[ 4.2279 ] tegrahost_v2 --chip 0x23 0 --align spe_t234_aligned.bin
[ 4.2283 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader spe_t234_aligned.bin zerosbk
[ 4.2285 ] adding BCH for spe_t234_aligned.bin
[ 4.2352 ] tegrasign_v3.py --key None --list spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.2353 ] Assuming zero filled SBK key
[ 4.2363 ] Warning: pub_key.key is not found
[ 4.2362 ] tegrahost_v2 --chip 0x23 0 --updatesigheader spe_t234_aligned_sigheader.bin.encrypt spe_t234_aligned_sigheader.bin.hash zerosbk
[ 4.2374 ] Get magic id
[ 4.2376 ] tegraparser_v2 --get_magic tos
[ 4.2377 ] TOSB
[ 4.2378 ] partition type tos, magic id = TOSB
[ 4.2396 ] tegrahost_v2 --chip 0x23 0 --align tos-optee_t234_aligned.img
[ 4.2401 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader tos-optee_t234_aligned.img zerosbk
[ 4.2402 ] adding BCH for tos-optee_t234_aligned.img
[ 4.2827 ] tegrasign_v3.py --key None --list tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.2828 ] Assuming zero filled SBK key
[ 4.2862 ] Warning: pub_key.key is not found
[ 4.2861 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tos-optee_t234_aligned_sigheader.img.encrypt tos-optee_t234_aligned_sigheader.img.hash zerosbk
[ 4.2906 ] Get magic id
[ 4.2908 ] tegraparser_v2 --get_magic eks
[ 4.2910 ] EKSB
[ 4.2912 ] partition type eks, magic id = EKSB
[ 4.2915 ] tegrahost_v2 --chip 0x23 0 --align eks_t234_aligned.img
[ 4.2920 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader eks_t234_aligned.img zerosbk
[ 4.2921 ] adding BCH for eks_t234_aligned.img
[ 4.2929 ] tegrasign_v3.py --key None --list eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.2930 ] Assuming zero filled SBK key
[ 4.2939 ] Warning: pub_key.key is not found
[ 4.2937 ] tegrahost_v2 --chip 0x23 0 --updatesigheader eks_t234_aligned_sigheader.img.encrypt eks_t234_aligned_sigheader.img.hash zerosbk
[ 4.2957 ] tegrahost_v2 --chip 0x23 0 --align uefi_jetson_minimal_with_dtb_aligned.bin
[ 4.2961 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader uefi_jetson_minimal_with_dtb_aligned.bin zerosbk
[ 4.2963 ] adding BCH for uefi_jetson_minimal_with_dtb_aligned.bin
[ 4.3407 ] tegrasign_v3.py --key None --list uefi_jetson_minimal_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.3408 ] Assuming zero filled SBK key
[ 4.3442 ] Warning: pub_key.key is not found
[ 4.3441 ] tegrahost_v2 --chip 0x23 0 --updatesigheader uefi_jetson_minimal_with_dtb_aligned_sigheader.bin.encrypt uefi_jetson_minimal_with_dtb_aligned_sigheader.bin.hash zerosbk
[ 4.3496 ] Copying enc\/signed file in /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3679 ] Copying br bct for multi chains
[ 4.3680 ] Signed BCT for boot chain A is copied to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/br_bct_BR.bct
[ 4.3681 ] Signed BCT for boot chain B is copied to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/br_bct_b_BR.bct
[ 4.3681 ] Copying BCT backup image bct_backup.img to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/bct_backup.img
[ 4.3703 ] Copying pscfw_t234_prod_sigheader.bin.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3707 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/pscfw_t234_prod_sigheader.bin.encrypt
[ 4.3707 ] Copying mce_flash_o10_cr_prod_sigheader.bin.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3709 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/mce_flash_o10_cr_prod_sigheader.bin.encrypt
[ 4.3709 ] Copying tsec_t234_sigheader.bin.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3711 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/tsec_t234_sigheader.bin.encrypt
[ 4.3711 ] Copying applet_t234_sigheader.bin.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3713 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/applet_t234_sigheader.bin.encrypt
[ 4.3713 ] Copying mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3716 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt
[ 4.3716 ] Copying xusb_t234_prod_sigheader.bin.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3718 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/xusb_t234_prod_sigheader.bin.encrypt
[ 4.3718 ] Copying nvpva_020_sigheader.fw.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3730 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/nvpva_020_sigheader.fw.encrypt
[ 4.3730 ] Copying display-t234-dce_sigheader.bin.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3797 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/display-t234-dce_sigheader.bin.encrypt
[ 4.3797 ] Copying display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv-super_sigheader.bin.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3865 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0005-nv-super_sigheader.bin.encrypt
[ 4.3866 ] Copying nvdec_t234_prod_sigheader.fw.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3869 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/nvdec_t234_prod_sigheader.fw.encrypt
[ 4.3869 ] Copying bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3878 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt
[ 4.3878 ] Copying tegra234-bpmp-3767-0003-3768-super_with_odm_sigheader.dtb.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3880 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/tegra234-bpmp-3767-0003-3768-super_with_odm_sigheader.dtb.encrypt
[ 4.3880 ] Copying camera-rtcpu-t234-rce_sigheader.img.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3885 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/camera-rtcpu-t234-rce_sigheader.img.encrypt
[ 4.3885 ] Copying adsp-fw_sigheader.bin.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3888 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/adsp-fw_sigheader.bin.encrypt
[ 4.3889 ] Copying spe_t234_sigheader.bin.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3891 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/spe_t234_sigheader.bin.encrypt
[ 4.3891 ] Copying tos-optee_t234_sigheader.img.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3907 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/tos-optee_t234_sigheader.img.encrypt
[ 4.3907 ] Copying eks_t234_sigheader.img.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3908 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/eks_t234_sigheader.img.encrypt
[ 4.3908 ] Copying uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt to /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed
[ 4.3919 ] Signed file: /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt
[ 4.3934 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/brettpac/Desktop/Linux_for_Tegra/bootloader/signed/flash.xml.tmp flash.idx
Using bpmp-dtb concatenated with odmdata in blob for t23x
./tegraflash.py --bl uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3768-0000+p3767-0005-nv-super.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0003-3768-super_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot.img; kernel_dtb tegra234-p3768-0000+p3767-0005-nv-super.dtb" --bct_backup
saving flash command in flashcmd.txt
no_flash ...; prepare rcmboot_blob ...
flashcmd with --no_flash:
./tegraflash.py --bl uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3768-0000+p3767-0005-nv-super.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0003-3768-super_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot.img; kernel_dtb tegra234-p3768-0000+p3767-0005-nv-super.dtb" --bct_backup --no_flash
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
Entering RCM boot
[ 0.0168 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0168 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0168 ] rcm boot with presigned binaries
[ 0.0171 ] Generating blob for T23x
[ 0.0178 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.0180 ] The number of images in blob is 19
[ 0.0183 ] blobsize is 81668937
[ 0.0184 ] Added binary blob_uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt of size 2043968
[ 0.0475 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[ 0.0479 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[ 0.0481 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[ 0.0482 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279808
[ 0.0484 ] Not supported type: mb2_applet
[ 0.0484 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 440944
[ 0.0487 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.0488 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[ 0.0501 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12070416
[ 0.0580 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.0590 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1027008
[ 0.0599 ] Added binary blob_tegra234-bpmp-3767-0003-3768-super_with_odm_sigheader.dtb.encrypt of size 264192
[ 0.0601 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[ 0.0603 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 415008
[ 0.0605 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.0606 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1887312
[ 0.0616 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.0618 ] Added binary blob_boot.img of size 58953728
[ 0.1003 ] Added binary blob_tegra234-p3768-0000+p3767-0005-nv-super.dtb of size 249353
[ 0.2026 ] All RCM required files are saved in rcmboot_blob folder
rcmboot_blob generated.
*** no-flash flag enabled. Exiting now... ***
User can run above saved command in factory environment without
providing pkc and sbk keys to flash a device
Example:
$ cd bootloader
$ sudo bash ./flashcmd.txt
Save initrd flashing command parameters to /home/brettpac/Desktop/Linux_for_Tegra/tools/kernel_flash/initrdflashparam.txt
/tmp/tmp.sbB81Op6Zd /home/brettpac/Desktop/Linux_for_Tegra
writing boot image config in bootimg.cfg
extracting kernel in zImage
extracting ramdisk in initrd.img
/tmp/tmp.sbB81Op6Zd/initrd /tmp/tmp.sbB81Op6Zd /home/brettpac/Desktop/Linux_for_Tegra
96292 blocks
148032 blocks
flashimg0=boot0.img
Success
Cleaning up...
Finish generating flash package.
# Entry added by NVIDIA initrd flash tool
/home/brettpac/Desktop/Linux_for_Tegra/tools/kernel_flash/tmp 127.0.0.1(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
rpcbind: another rpcbind is already running. Aborting
Export list for localhost:
/home/brettpac/Desktop/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --network usb0 --usb-instance 3-2 --device-instance 0 --flash-only --external-device nvme0n1p1 -c "tools/kernel_flash/flash_l4t_t234_nvme.xml" --network usb0 jetson-orin-nano-devkit-super internal
* Step 1: Build the flashing environment *
Create flash environment 0
/home/brettpac/Desktop/Linux_for_Tegra/bootloader /home/brettpac/Desktop/Linux_for_Tegra
Finish creating flash environment 0.
* Step 2: Boot the device with flash initrd image *
/home/brettpac/Desktop/Linux_for_Tegra/temp_initrdflash/bootloader0 /home/brettpac/Desktop/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3768-0000+p3767-0005-nv-super.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --instance 3-2 --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0003-3768-super_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3768-0000+p3767-0005-nv-super.dtb" --bct_backup
version 1.0.0
Entering RCM boot
[ 0.0151 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0151 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0151 ] rcm boot with presigned binaries
[ 0.0154 ] tegrarcm_v2 --instance 3-2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0156 ] BR_CID: 0x80012344705DF28840000000160280C0
[ 0.0293 ] Sending bct_br
[ 0.0348 ] Sending mb1
[ 0.0353 ] Sending psc_bl1
[ 0.0447 ] Sending bct_mb1
[ 0.0508 ] Generating blob for T23x
[ 0.0518 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.0521 ] The number of images in blob is 19
[ 0.0523 ] blobsize is 99955529
[ 0.0523 ] Added binary blob_uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt of size 2043968
[ 0.0890 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[ 0.0894 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[ 0.0896 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[ 0.0897 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279808
[ 0.0899 ] Not supported type: mb2_applet
[ 0.0899 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 440944
[ 0.0901 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.0903 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[ 0.0914 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12070416
[ 0.0997 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.1009 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1027008
[ 0.1016 ] Added binary blob_tegra234-bpmp-3767-0003-3768-super_with_odm_sigheader.dtb.encrypt of size 264192
[ 0.1018 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[ 0.1020 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 415008
[ 0.1021 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.1022 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1887312
[ 0.1034 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.1036 ] Added binary blob_boot0.img of size 77240320
[ 0.1550 ] Added binary blob_tegra234-p3768-0000+p3767-0005-nv-super.dtb of size 249353
[ 0.2199 ] tegrarcm_v2 --instance 3-2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.2202 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[ 0.3109 ] Sending bct_mem
[ 0.3167 ] Sending blob
[ 3.6898 ] RCM-boot started
* Step 3: Start the flashing process *
Waiting for target to boot-up...
Waiting for device to expose ssh ......Waiting for device to expose ssh ...Run command: flash on fc00:1:1:0::2
SSH ready
blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
[ 0]: l4t_flash_from_kernel: Serial Number: 1425024313192
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /mnt/internal/flash.idx
Number of lines is 61
max_index=60
[ 2]: l4t_flash_from_kernel: Successfully create gpt for emmc
[ 2]: l4t_flash_from_kernel: Starting to create gpt for external device
Active index file is /mnt/external/flash.idx
Number of lines is 18
max_index=17
writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, 42f0d673394f63a74af9553ea8cf5949984f4ea9
Writing primary_gpt partition with gpt_primary_9_0.bin
Offset is not aligned to K Bytes, no optimization is applied
dd if=/mnt/external/gpt_primary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0 seek=512 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0253548 s, 666 kB/s
Writing primary_gpt partition done
Error: The backup GPT table is corrupt, but the primary appears OK, so that will be used.
Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 368859504 blocks) or continue with the current setting?
Writing secondary_gpt partition with gpt_secondary_9_0.bin
dd if=/mnt/external/gpt_secondary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0 seek=61203267072 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0250265 s, 675 kB/s
Writing secondary_gpt partition done
Fix/Ignore? Fix
Model: WD Blue SN570 250GB SSD (nvme)
Disk /dev/nvme0n1: 250GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
2 20.5kB 134MB 134MB A_kernel msftdata
3 134MB 135MB 786kB A_kernel-dtb msftdata
4 135MB 168MB 33.2MB A_reserved_on_user msftdata
5 168MB 302MB 134MB B_kernel msftdata
6 302MB 303MB 786kB B_kernel-dtb msftdata
7 303MB 336MB 33.2MB B_reserved_on_user msftdata
8 336MB 420MB 83.9MB recovery msftdata
9 420MB 421MB 524kB recovery-dtb msftdata
10 421MB 488MB 67.1MB esp boot, esp
11 488MB 572MB 83.9MB recovery_alt msftdata
12 572MB 572MB 524kB recovery-dtb_alt msftdata
13 572MB 639MB 67.1MB esp_alt msftdata
14 639MB 1059MB 419MB UDA msftdata
15 1059MB 1562MB 503MB reserved msftdata
1 1562MB 61.2GB 59.6GB APP msftdata
[ 29]: l4t_flash_from_kernel: Expanding last partition to fill the storage device
[ 29]: l4t_flash_from_kernel: Successfully create gpt for external device
[ 29]: l4t_flash_from_kernel: Starting to flash to emmc
[ 29]: l4t_flash_from_kernel: Starting to flash to external device
Flash index file is /mnt/internal/flash.idx
max_index=60
max_index=60
max_index=17
[ 29]: l4t_flash_from_kernel: Starting to flash to qspi
QSPI storage size: 67108864 bytes.
writing item=0, 9:0:master_boot_record, 0, 512, mbr_9_0.bin, 512, fixed-<reserved>-0, 694898d1c345bdb31b377790ed7fc0b0db184bf7
writing item=2, 9:0:A_kernel, 20480, 134217728, boot.img, 58953728, fixed-<reserved>-2, 718d6aad66f76d6dba22db51f94508a053e7b64d
Writing A_kernel partition with boot.img
Get size of partition through connection.
58953728 bytes from /mnt/external/boot.img to /dev/nvme0n1: 1KB block=57572 remainder=0
dd if=/mnt/external/boot.img of=/dev/nvme0n1 bs=1K skip=0 seek=20 count=57572
[ 30]: l4t_flash_from_kernel: Successfully flash the emmc
57572+0 records in
57572+0 records out
58953728 bytes (59 MB, 56 MiB) copied, 1.79679 s, 32.8 MB/s
Writing A_kernel partition done
writing item=3, 9:0:A_kernel-dtb, 134238208, 786432, kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb, 249353, fixed-<reserved>-3, a26ad92d82c63ade216bc8ec55583fac0f6e8a0f
Writing A_kernel-dtb partition with kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb
249353 bytes from /mnt/external/kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb to /dev/nvme0n1: 1KB block=243 remainder=521
dd if=/mnt/external/kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb of=/dev/nvme0n1 bs=1K skip=0 seek=131092 count=243
243+0 records in
243+0 records out
248832 bytes (249 kB, 243 KiB) copied, 0.00335606 s, 74.1 MB/s
dd if=/mnt/external/kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb of=/dev/nvme0n1 bs=1 skip=248832 seek=134487040 count=521
521+0 records in
521+0 records out
521 bytes copied, 0.00126342 s, 412 kB/s
Writing A_kernel-dtb partition done
writing item=4, 9:0:A_reserved_on_user, 135024640, 33161216, , , fixed-<reserved>-4,
[ 31]: l4t_flash_from_kernel: Warning: skip writing A_reserved_on_user partition as no image is specified
writing item=5, 9:0:B_kernel, 168185856, 134217728, boot.img, 58953728, fixed-<reserved>-5, 718d6aad66f76d6dba22db51f94508a053e7b64d
Writing B_kernel partition with boot.img
dd if=/mnt/external/boot.img of=/dev/nvme0n1 bs=1K skip=0 seek=164244 count=57572
57572+0 records in
57572+0 records out
58953728 bytes (59 MB, 56 MiB) copied, 0.665971 s, 88.5 MB/s
Writing B_kernel partition done
writing item=6, 9:0:B_kernel-dtb, 302403584, 786432, kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb, 249353, fixed-<reserved>-6, a26ad92d82c63ade216bc8ec55583fac0f6e8a0f
Writing B_kernel-dtb partition with kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb
dd if=/mnt/external/kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb of=/dev/nvme0n1 bs=1K skip=0 seek=295316 count=243
243+0 records in
243+0 records out
248832 bytes (249 kB, 243 KiB) copied, 0.00310848 s, 80.0 MB/s
dd if=/mnt/external/kernel_tegra234-p3768-0000+p3767-0005-nv-super.dtb of=/dev/nvme0n1 bs=1 skip=248832 seek=302652416 count=521
521+0 records in
521+0 records out
521 bytes copied, 0.00131008 s, 398 kB/s
Writing B_kernel-dtb partition done
writing item=7, 9:0:B_reserved_on_user, 303190016, 33161216, , , fixed-<reserved>-7,
[ 32]: l4t_flash_from_kernel: Warning: skip writing B_reserved_on_user partition as no image is specified
writing item=8, 9:0:recovery, 336351232, 83886080, recovery.img, 64051200, fixed-<reserved>-8, 5478dff8eda5fd381df0068f1efe2a372238475b
Writing recovery partition with recovery.img
64051200 bytes from /mnt/external/recovery.img to /dev/nvme0n1: 1KB block=62550 remainder=0
dd if=/mnt/external/recovery.img of=/dev/nvme0n1 bs=1K skip=0 seek=328468 count=62550
Flash failure
Either the device cannot mount the NFS server on the host or a flash command has failed. Check your network setting (VPN, firewall,...) to make sure the device can mount NFS server. Debug log saved to /tmp/tmp.jbvGpzvEbz. You can access the target's terminal through "sshpass -p root ssh root@fc00:1:1:0::2"
Cleaning up...
What do I do?
One note: Please don’t refer me to the SDK Manager - I already tested that method and it doesn’t work, or using the SD card, I need it on the SSD.
My System
Host: Ubuntu 22.04.05 LTS
Target: Jetson Orin Nano Dev Kit
Part Number#: 945-13766-0000-000
SSD: Western Digital SN570 - 250GB NVMe SSD
