I have a radix_sort.cu file that includes a prefix_sum.cu file. In prefix_sum.cu I have a function called CHECK_ERROR.
I get the following errors:
Error 1 error LNK2005: “void __cdecl CHECK_ERROR(void)” (?CHECK_ERROR@@YAXXZ) already defined in prefix_sum.cu.obj radix_sort.cu.obj
Error 2 fatal error LNK1169: one or more multiply defined symbols found G:\School\MasterThesis\CollisionDetection\CUDACD\CUDACD\x64\Release\CUDACD.exe 1
But I only have one instance of CHECK_ERROR in prefix_sum.cu. When I comment the function the compilation works fine. I seems like the compiler sees 2 instances of CHECK_ERROR function because I have a include statement of prefix_sum.cu in radix_sort.cu
My code:
prefix_sum.cu
#include <math.h>
#include <stdio.h>
#include <cuda.h>
#include "VecTypes.cu"
//HELPER FUNCTIONS
//just printf errors that has occurred
__host__ void CHECK_ERROR()
//cudaGetLastError() resets to cudaSuccess
cudaError err = cudaGetLastError();
switch(err)
case cudaSuccess:
printf("No error.\n");
break;
case cudaErrorMissingConfiguration :
printf("Missing configuration error\n");
break;
case cudaErrorMemoryAllocation :
printf("Memory allocation error\n");
break;
case cudaErrorInitializationError :
printf("Initialization error\n");
break;
case cudaErrorLaunchFailure :
printf("Launch failure\n");
break;
case cudaErrorPriorLaunchFailure :
printf("Prior launch failure.\n");
break;
case cudaErrorLaunchTimeout :
printf("Launch timeout error.\n");
break;
case cudaErrorLaunchOutOfResources :
printf("Launch out of resources error.\n");
break;
case cudaErrorInvalidDeviceFunction :
printf("Invalid device function.\n");
break;
case cudaErrorInvalidConfiguration :
printf("Invalid configuration.\n");
break;
case cudaErrorInvalidDevice :
printf("Invalid device. \n");
break;
case cudaErrorInvalidValue :
printf("Invalid value. \n");
break;
case cudaErrorInvalidPitchValue :
printf("Invalid pitch value. \n");
break;
case cudaErrorInvalidSymbol :
printf("Invalid symbol. \n");
break;
case cudaErrorMapBufferObjectFailed :
printf("Map buffer object failed.\n");
break;
case cudaErrorUnmapBufferObjectFailed :
printf("Unmap buffer object failed.\n");
break;
case cudaErrorInvalidHostPointer :
printf("Invalid host pointer.\n");
break;
case cudaErrorInvalidDevicePointer :
printf("Invalid device pointer.\n");
break;
case cudaErrorInvalidTexture :
printf("Invalid texture.\n");
break;
case cudaErrorInvalidTextureBinding :
printf("Invalid texture binding.\n");
break;
case cudaErrorInvalidChannelDescriptor :
printf("Invalid channel descriptor.\n");
break;
case cudaErrorInvalidMemcpyDirection :
printf("Invalid memcpy direction.");
break;
case cudaErrorAddressOfConstant :
printf("Address of constant error.\n");
break;
case cudaErrorTextureFetchFailed :
printf("Texture fetch failed.\n");
break;
case cudaErrorTextureNotBound :
printf("Texture not bound error. \n");
break;
case cudaErrorSynchronizationError :
printf("Synchronization error\n");
break;
case cudaErrorInvalidFilterSetting :
printf("Invalid filter setting. \n");
break;
case cudaErrorInvalidNormSetting :
printf("Invalid norm setting. \n");
break;
case cudaErrorMixedDeviceExecution :
printf("Mixed device execution.\n");
break;
case cudaErrorCudartUnloading :
printf("CUDA runtime unloading.\n");
break;
case cudaErrorUnknown :
printf("Unknown error condition.\n");
break;
case cudaErrorNotYetImplemented :
printf("Function not yet implemented.\n");
break;
case cudaErrorMemoryValueTooLarge :
printf("Memory value too large.\n");
break;
case cudaErrorInvalidResourceHandle :
printf("Invalid resource handle.\n");
break;
case cudaErrorNotReady :
printf("Not ready error.\n");
break;
case cudaErrorInsufficientDriver :
printf("CUDA runtime is newer than driver.\n");
break;
case cudaErrorSetOnActiveProcess :
printf("Set on active process error.\n");
break;
case cudaErrorNoDevice :
printf("No available CUDA device.\n");
break;
case cudaErrorStartupFailure :
printf("Startup failure\n");
break;
case cudaErrorApiFailureBase :
printf("API failure base.\n");
break;
default:
printf("No case to catch: Unknown Error.\n");
break;
in radix_sort.cu I include prefix_sum.cu
#include <prefix_sum.cu>
Does anyone know why I get this error?
