I am building a Xavier AGX development environment with an Ubuntu 18.04 host.
I have successfully flashed the Xavier AGX and installed all software on the host with the exception of the cross-compile package. The following error is in the logs:
20:04:15 INFO: CUDA Cross Compile Package on Host - host: Reading state information…
20:04:15 INFO: CUDA Cross Compile Package on Host - host: The following packages have unmet dependencies:
20:04:16 INFO: CUDA Cross Compile Package on Host - host: Depends: cuda-npp-cross-aarch64-10-2 (>= 10.2.89)
20:04:16 ERROR: CUDA Cross Compile Package on Host - host: E
20:04:16 ERROR: CUDA Cross Compile Package on Host - host: command terminated with error
20:04:16 SUMMARY: CUDA Cross Compile Package on Host - host: First Error: APT system is broken and requires manual fix
Running the install manually the following more descriptive error is displayed:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:The following packages have unmet dependencies:
cuda-cross-aarch64-10-2 : Depends: cuda-cufft-cross-aarch64-10-2 (>= 10.2.89)
Depends: cuda-curand-cross-aarch64-10-2 (>= 10.2.89)
E: Unable to correct problems, you have held broken packages.
