Hello.
I’m trying to configure my AppVeyor CI server to install CUDA but it fails due to timeout. Here is my CI log:
Build started
git clone -q ...
git fetch -q origin +refs/pull/34/merge:
git checkout -qf FETCH_HEAD
Running Install scripts
appveyor DownloadFile https://developer.nvidia.com/compute/cuda/9.1/Prod/local_installers/cuda_9.1.85_win10 -FileName cuda_9.1.exe
Downloading cuda_9.1.exe (1,446,894,456 bytes)...1%
Downloading cuda_9.1.exe (1,446,894,456 bytes)...10%
Downloading cuda_9.1.exe (1,446,894,456 bytes)...20%
Downloading cuda_9.1.exe (1,446,894,456 bytes)...30%
Downloading cuda_9.1.exe (1,446,894,456 bytes)...40%
Downloading cuda_9.1.exe (1,446,894,456 bytes)...50%
Downloading cuda_9.1.exe (1,446,894,456 bytes)...60%
Downloading cuda_9.1.exe (1,446,894,456 bytes)...70%
Downloading cuda_9.1.exe (1,446,894,456 bytes)...80%
Downloading cuda_9.1.exe (1,446,894,456 bytes)...90%
Downloading cuda_9.1.exe (1,446,894,456 bytes)...100%
Start-Process -FilePath "cuda_9.1.exe" -ArgumentList "-s nvcc_9.1 cublas_9.1 cublas_dev_9.1 cufft_9.1 cufft_dev_9.1 npp_9.1 npp_dev_9.1 Display.Driver" -Wait
Then in hangs for 1 hour without writing any logs and then CI cancels the build due to timeout.
Why it takes so much time? Is there any workaround to reduce it? I don’t want to increase timeout, because it’s not fonny when build takes several hours.
It seems that the last parameter Display.Driver require some user interaction and it doesn’ work on UI-less CI server. However, documentation says that it’s mandatory for CUDA.
What should I do?
