I already remove everything about deepstream 5.1 on my computer. However, when I install deepstream 6.0 through the deb file, it still showed me the error:
Unpacking deepstream-6.0 (6.0.0-1) …
dpkg: error processing archive deepstream-6.0_6.0.0-1_amd64.deb (–install):
trying to overwrite ‘/opt/nvidia/deepstream/deepstream’, which is also in package deepstream-5.1 5.1.0-1
Errors were encountered while processing:
There is even no folder called “/opt/nvidia/deepstream/” now. I don’t know how to fix this problem and install deepstream 6.0 now.
Please use uninstall.sh under /opt/nvidia/deepstream/deepstream-5.1 to remove deestream installation.
cd /opt/nvidia/deepstream/deepstream-5.1
sudo ./uninstall.sh
@amycao
It showed
“ii deepstream-5.1 5.1.0-1 amd64 DeepStreamSDK runtime libraries, development files and samples”
But I cannot purge or remove it. It showed “dpkg: warning: ignoring request to remove deepstream which isn’t installed”
If I re-run the uninstall script it will say “This version of DeepStream is not present in the system.”
I can run “dpkg -S deepstream” and it will show many deepstream-5.1’s information. But I don’t know the best way to remove it.
