Cannot Install Isaac ROS 3.2 on Fresh JetPack 6.2.1 - Both Docker and Source Build Methods Fail
System Environment:
  • Hardware: Jetson Orin Nano 8GB Developer Kit
  • Software: Fresh flash of JetPack 6.2.1 (L4T 36.4.4)
  • ROS Distro: ROS 2 Humble
  • Docker Image: Successfully pulled nvcr.io/nvidia/isaac/ros:aarch64-ros2_humble_77e6a678c2058abf96bedcb8f7dd4330
Goal:
To set up a development environment for Isaac ROS 3.2.
Problem Summary:
On a freshly flashed and supported JetPack 6.2.1 system, both of the official documented procedures for setting up an Isaac ROS 3.2 development environment are failing due to broken scripts and missing files.
Failure Method 1: Official Docker Script (run_dev.sh)
  1. A clean ROS 2 workspace is created.
  2. The isaac_ros_common repository is cloned into the src directory.
  3. The official script ${ISAAC_ROS_WS}/src/isaac_ros_common/scripts/run_dev.sh is executed.
  4. Result: The script exits immediately and silently without starting a container, even though the correct pre-built Docker image has been pulled.
Failure Method 2: Manual Source Build (vcs import)
  1. To get the source code for Isaac ROS 3.2, the isaac_ros_common repository is cloned and the v3.2.0 tag is checked out.
  2. The command vcs import src < src/isaac_ros_common/isaac_ros.repos is run to download the rest of the source packages.
  3. Result: The command fails with No such file or directory. The required isaac_ros.repos manifest file is missing from the v3.2.0 tag, and all other documented URLs for this file result in 404 Not Found errors.
Conclusion:
It is currently impossible to begin development with Isaac ROS 3.2 on this platform, as both the automated Docker script and the manual source download methods are broken.
Thank you @Ahung at your suggestion i tried JetPack 6.2 using Isaac ROS 3.2 but I couldn’t get it to work. I opened a new topic a reported my problem:
Any help is appreciated.
Problem Summary:
On a freshly flashed and supported JetPack 6.2.1 system, every documented method for installing and running Isaac ROS 3.2 fails due to a series of critical bugs. We have tried the official Docker script, a manual source build, and the pre-built Docker image with apt packages. All methods are currently blocked, making Isaac ROS 3.2 unusable on this platform.
This is the primary recommended setup method.
  3. The script ${ISAAC_ROS_WS}/src/isaac_ros_common/scripts/run_dev.sh is executed.
Result: The script fails silently. It exits immediately with no error messages. Running with bash -x shows the script completes initial checks and then exits cleanly without ever attempting to build or run a Docker container.
This is the alternative for building the code manually.
  1. Following the Isaac ROS 3.2 documentation, we attempt to download the source code using the isaac_ros.repos manifest file.
  2. The isaac_ros_common repository is cloned and the official v3.2.0 release tag is checked out.
Result: The process fails because the required manifest file, isaac_ros.repos, is missing from the v3.2.0 tag. All other documented URLs for this file result in 404 Not Found errors, making it impossible to download the source code.
Failure Method 3: Pre-built Docker Image + Apt Packages
This is the most direct method, bypassing the broken scripts.
  1. The official pre-built image is successfully pulled from NGC: nvcr.io/nvidia/isaac/ros:aarch64-ros2_humble_77e6a678c2058abf96bedcb8f7dd4330.
  2. We enter the container and attempt to install packages using apt-get.
Result: This method fails for two critical reasons:
  • Missing Drivers: The repository is missing key hardware drivers, such as ros-humble-zed-ros2-wrapper. An apt-cache search confirms the package does not exist.
  • Broken Networking: Even when we install a non-camera package like isaac_ros_jetson_stats, ROS 2 nodes cannot communicate with each other inside the container. A publisher in one terminal is not visible to a subscriber in a second terminal, even after confirming ROS_DOMAIN_ID and forcing ROS_LOCALHOST_ONLY=1. This indicates a fundamental DDS discovery failure within the container.
Conclusion:
All paths to a working Isaac ROS 3.2 installation on JetPack 6.2.1 are currently blocked. The official tools are broken, the source repositories are incomplete, and the pre-built environment has critical runtime bugs. Assistance from the development team is required to resolve these issues.
Title: Isaac ROS Debian Packages are Undiscoverable on ROS 2 Graph in Dev Container
Body:
System: Jetson Orin Nano, JetPack 6.2.1, using official Isaac ROS Dev Docker Image (...aarch64-ros2_humble_77e...).
Problem: ROS 2 nodes installed from the pre-built Isaac ROS apt repository (e.g., ros-humble-isaac-ros-jetson-stats) are not discoverable on the ROS 2 network, while standard ROS 2 demo nodes work perfectly in the same environment.
Steps to Reproduce:
  1. Start the official Isaac ROS dev container.
  2. In Terminal 1 (inside container): Install and run the jtop node: apt-get install -y ros-humble-isaac-ros-jetson-stats ros2 run isaac_ros_jetson_stats jtop
  3. In Terminal 2 (inside container): Source the environment and run ros2 topic list. Result: The /jetson_stats topic is not visible.
Verification:
  1. In Terminal 1: Run ros2 run demo_nodes_cpp talker.
  2. In Terminal 2: Run ros2 run demo_nodes_cpp listener. Result: The listener successfully receives messages from the talker, proving the base ROS 2 communication is functional.
Conclusion: This indicates a critical issue with how the pre-built Isaac ROS Debian packages are configured that makes them invisible to the ROS 2 network.
Hi @dennis.darrow1,
Thank you for your post.
  1. Result: The script exits immediately and silently without starting a container, even though the correct pre-built Docker image has been pulled.
We have received similar reports before, and the issue was resolved by following the documentation on the Isaac ROS website to set up the Compute and Developer Environment. Could you check these again?
Compute Setup
Developer Environment Setup
Best,
Ahung
Hi @Ahung,
Thank you for your suggestion and i checked again.
Update: After meticulously following the “Compute Setup” guide and installing the docker-buildx-plugin, the run_dev.sh script now successfully starts the build process.
However, the build consistently fails with a pip error: error: metadata-generation-failed. This happens during the RUN python3 -m pip install -U ... step inside the Dockerfile.aarch64.
This appears to be a bug in the Dockerfile itself, as one of the required Python packages is failing to build.
Your continued guidance and help is really appreciated!
Hi @dennis.darrow1
Thanks for the update. Good to know that silent issue is gone.
About the build error, the info you provided is not sufficient for issue triage. Could you attach the full log?
Best,
Ahung
Hi @Ahung,
The problem was resolved after the buildx plugin was installed.
Thank you.
