I have tried to install the NeMo both from the command line and building from the source package. For both cases the installation failed on the installation on the sentencepiece package.
A. build from the command line
sudo pip3(or pip) install sentencepiece
B. build from the sentencepiece-0.1.91 package
Both gave me the following errors.
Can you give me the suggestions how to solve the problem?
Jimmy
========== Failed Message
Package sentencepiece was not found in the pkg-config search path.
Perhaps you should add the directory containing `sentencepiece.pc’
to the PKG_CONFIG_PATH environment variable
No package ‘sentencepiece’ found
Failed to find sentencepiece pkgconfig
Hello! Is this issue solved?
I’m on python3.6 as well and I’ve tried installing sentencepice and setuptools-rust but still failing to build on tokenizer
