Cannot install on Ubuntu 22.04
When I rum ./NVIDIA-AI-Workbench-0.28.29-x86_64.AppImage when it asks to “select a container runtime” and I select docker it displays the password prompt and but then after I enter it the log just shows:
15:49:15.520 (start-service-admin)                › { gpuInstallSelected: false, runtime: 'docker' }
15:49:15.521 (start-service-admin)                › Install Command  /home/dave/.nvwb/bin/wb-svc -websocket -docker  -gid 1000 -uid 1000 -debug install
15:49:15.523 (start-service-admin)                › isAdminPrivileged false
15:49:15.528 (renderer)                           › Navigating to run-install-workflow, /prompt-to-select-runtime
15:49:15.551 (start-service-admin)                › { size: 0, timeout: 0 }
15:49:16.555 (start-service-admin)                › rejected password
15:49:16.560 (start-service-admin)                › { size: 0, timeout: 0 }
15:49:17.561 (start-service-admin)                › rejected password
15:49:17.566 (start-service-admin)                › { size: 0, timeout: 0 }
15:49:18.567 (start-service-admin)                › rejected password
15:49:18.572 (start-service-admin)                › { size: 0, timeout: 0 }
I’m entering the correct password - I used to option to display it to confirm. Also I already have docker installed.
There were some issues with using Docker on the Beta 0.28.29 build that have since been fixed on the GA 0.44.8 build. Try updating your AIWB to the latest version from here and try again.
