hi
I want to install tensorflow object_detection library from GitHub repository (this link)
and when I write the command:
python3 -m pip install .
it returns an ERROR for the tensorflow library:
ERROR: No matching distribution found for tensorflow_io
seems like there is no matching distribution for Python3.6 and aarch64.
what can I do?
CUDA: 10.2
TensorRT: 8.2
cuDNN: 8.2
Python: 3.6
NVIDIA Jetson TX1
The library has lots of dependencies.
It’s recommended to check with the library owner if they can support the Jetson environment first.
seems like it has a problem with Python3.6
For object detection, you can check if jetson-inference can meet your requirement.
@dusty_nv
Hey, dusty, how are you?
can I use your jetson-inference repository on GitHub to train my own custom object detection model?
I want to collect my own dataset, label the images and train the object detection model, and after that, infer on the jetson board.
can I do that?
@AastaLLL
Thank you so much for your a response ❤🌸🌸
