Hello everybody,
I´m running Ubuntu 20.04 on a Workstation with a A5000 card with Driver 525.60.11:
| NVIDIA-SMI 525.60.11 Driver Version: 525.60.11 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA RTX A5000 Off | 00000000:01:00.0 On | Off |
| 30% 32C P8 29W / 230W | 604MiB / 24564MiB | 22% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1341 G /usr/lib/xorg/Xorg 57MiB |
| 0 N/A N/A 2073 G /usr/lib/xorg/Xorg 131MiB |
| 0 N/A N/A 2204 G /usr/bin/gnome-shell 91MiB |
| 0 N/A N/A 2628 G ...RendererForSitePerProcess 93MiB |
| 0 N/A N/A 3566 G /usr/lib/firefox/firefox 219MiB |
When I try to launch Isaac Sim or Create over the launch Button of the Omniverse-Launcher, nothing happens. The button changes for a small period of time to grey and after that it becomes white again.
This is the log-File for the Create launch via the launcher.
kit_20230113_110521.log (408.1 KB)
When I try to start the App via the command line, I get this prompt:
Doing a complete reinstall with the cleanup-tool hasn´t solved the problem.
Using the Docker-Container for Isaac Sim and the streaming client accessing the Docker-Container, everything works fine.
Thank you!
Konrad
