I have the same basic issue. In my case, I’m debugging (attempting) NDK sample applications (SanAndreas and MoreTeapots).
Here’s some additional observations on this issue:
Using AMIDuos (Android 5.0), which is an x86 based implementation, debugging works flawlessly. Zero issues - breakpoints fire in Java and C++ code.
Using x86 based AVDs (Android 4.01 through Android 5.1, specifically 4.2.2 and 4.4.2, debugging functions correctly.
Using any ARM based AVD (same Android versions) debugging fails with various issues. Sometimes it’s launching that fails, sometimes it’s other issues which are resolved by erasing the partially installed remnants and trying again, only to fail later in the process.
Virtually all ARM based AVD debugging fails to launch GDBServer, or some similar problem.
On AVD 4.01, the target can’t be for multiple architectures (it won’t pass ODEX optimization otherwise) - must be build only from ARMEABI. Other Android versions (4.2.2 and 4.4.2) don’t have the problem.
Note (repeating), on all of the same version AVD’s, if the target is an x86 based machine, debugging functions as expected with little to no issue, even when mixed architectures.
On physical devices (one Android 4.1.2, another Android 4.2.2), GDBServer will not launch. However, the release build of the application can be installed and will run via ADB.
It seems consistent that ARM based target devices or AVD’s can’t be debugged, but x86 devices or virtual machines (like AMIDuos) have no problem.
Edit:
One curious observation based on two late experiments. Based on the notion that some Samsung devices WITHOUT run-as might work, I tried renaming run-as in two tests.
Test one, on a device:
GDBServer couldn’t be launched.
Logcat (partial) from that session below
12-05 09:01:50.745 378 662 I ActivityManager: Start proc com.example.SanAngeles for activity com.example.SanAngeles/.DemoActivity: pid=1409 uid=10049 gids={50049, 1028}
12-05 09:01:50.807 1409 1409 W Trace : error opening trace file: No such file or directory (2)
12-05 09:01:50.815 1409 1409 W ActivityThread: Application com.example.SanAngeles is waiting for the debugger on port 8100...
12-05 09:01:50.823 1409 1409 I System.out: Sending WAIT chunk
12-05 09:01:54.315 378 380 D dalvikvm: GC_CONCURRENT freed 456K, 17% free 7038K/8444K, paused 15ms+9ms, total 122ms
12-05 09:01:54.885 1450 1450 D su : su invoked.
12-05 09:01:54.893 1451 1451 E su : Unknown id: :2020
12-05 09:01:55.002 1455 1455 D su : su invoked.
12-05 09:01:55.018 1456 1456 E su : Unknown id: /data/local/tmp/gdbserver
12-05 09:01:55.127 1460 1460 D su : su invoked.
12-05 09:01:55.135 1461 1461 D su : Allowing root/system/radio.
12-05 09:01:55.151 1462 1462 D su : 0 /system/bin/mksh executing 777 chmod using binary /system/bin/sh : sh -c chmod /data/data/com.example.SanAngeles/gdbserver
12-05 09:01:55.284 1467 1467 D su : su invoked.
12-05 09:01:55.291 1468 1468 E su : Unknown id: :2020
12-05 09:01:55.385 1471 1471 F libc : Fatal signal 13 (SIGPIPE) at 0x000005bf (code=0), thread 1471 (sh)
12-05 09:01:55.495 108 108 I DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
12-05 09:01:55.495 108 108 I DEBUG : Build fingerprint: 'Android/cm_otter/otter:4.2.2/JDQ39E/eng.jenkins.20130923.174520:userdebug/test-keys'
12-05 09:01:55.495 108 108 I DEBUG : Revision: '16'
12-05 09:01:55.495 108 108 I DEBUG : pid: 1471, tid: 1471, name: sh >>> /system/bin/sh <<<
12-05 09:01:55.495 108 108 I DEBUG : signal 13 (SIGPIPE), code -6 (?), fault addr --------
12-05 09:01:55.502 108 108 I DEBUG : r0 ffffffe0 r1 416d6140 r2 00001000 r3 00001001
12-05 09:01:55.502 108 108 I DEBUG : r4 00000000 r5 00000003 r6 416d611c r7 00000004
12-05 09:01:55.502 108 108 I DEBUG : r8 416d6140 r9 416d6090 sl 416d6140 fp 40077e40
12-05 09:01:55.502 108 108 I DEBUG : ip 4007cf38 sp be8d36b8 lr 4006465d pc 4018ed98 cpsr 00070010
12-05 09:01:55.502 108 108 I DEBUG : d0 0000000000000000 d1 0000000000000000
12-05 09:01:55.502 108 108 I DEBUG : d2 0000000000000000 d3 0000000000000000
12-05 09:01:55.502 108 108 I DEBUG : d4 0000000000000000 d5 0000000000000000
12-05 09:01:55.502 108 108 I DEBUG : d6 0000000000000000 d7 07728e3c00000000
12-05 09:01:55.502 108 108 I DEBUG : d8 0000000000000000 d9 0000000000000000
12-05 09:01:55.502 108 108 I DEBUG : d10 0000000000000000 d11 0000000000000000
12-05 09:01:55.502 108 108 I DEBUG : d12 0000000000000000 d13 0000000000000000
12-05 09:01:55.502 108 108 I DEBUG : d14 0000000000000000 d15 0000000000000000
12-05 09:01:55.502 108 108 I DEBUG : d16 4150243d48544150 d17 6d6f63202e3a4854
12-05 09:01:55.502 108 108 I DEBUG : d18 2f6b726f77656d61 d19 7365636976726573
12-05 09:01:55.502 108 108 I DEBUG : d20 79732f3a72616a2e d21 6172662f6d657473
12-05 09:01:55.502 108 108 I DEBUG : d22 612f6b726f77656d d23 6d782d6568636170
12-05 09:01:55.502 108 108 I DEBUG : d24 0000000000000000 d25 0000000000000000
12-05 09:01:55.502 108 108 I DEBUG : d26 0000000000000000 d27 0000000000000000
12-05 09:01:55.502 108 108 I DEBUG : d28 0000000000000000 d29 0000000000000000
12-05 09:01:55.502 108 108 I DEBUG : d30 0000000000000000 d31 0000000000000000
12-05 09:01:55.502 108 108 I DEBUG : scr 00000010
12-05 09:01:55.510 108 108 I DEBUG :
12-05 09:01:55.510 108 108 I DEBUG : backtrace:
12-05 09:01:55.518 108 108 I DEBUG : #00 pc 00016d98 /system/lib/libc.so (write+12)
12-05 09:01:55.518 108 108 I DEBUG : #01 pc 0000e659 /system/bin/mksh
12-05 09:01:55.518 108 108 I DEBUG : #02 pc 0000b71f /system/bin/mksh
12-05 09:01:55.518 108 108 I DEBUG : #03 pc 0000d423 /system/bin/mksh
12-05 09:01:55.518 108 108 I DEBUG : #04 pc 0000c709 /system/bin/mksh
12-05 09:01:55.518 108 108 I DEBUG : #05 pc 00014917 /system/bin/mksh
12-05 09:01:55.518 108 108 I DEBUG : #06 pc 0000c76d /system/bin/mksh
12-05 09:01:55.518 108 108 I DEBUG : #07 pc 000185f9 /system/bin/mksh
12-05 09:01:55.518 108 108 I DEBUG : #08 pc 0001925b /system/bin/mksh
12-05 09:01:55.518 108 108 I DEBUG : #09 pc 00012733 /system/lib/libc.so (__libc_init+38)
12-05 09:01:55.518 108 108 I DEBUG : #10 pc 000023ac /system/bin/mksh
12-05 09:01:55.518 108 108 I DEBUG : stack:
12-05 09:01:55.518 108 108 I DEBUG : be8d3678 0000100b
12-05 09:01:55.518 108 108 I DEBUG : be8d367c 401893d7 /system/lib/libc.so (dlmalloc+5170)
12-05 09:01:55.518 108 108 I DEBUG : be8d3680 416d609c [heap]
12-05 09:01:55.518 108 108 I DEBUG : be8d3684 00000000
12-05 09:01:55.518 108 108 I DEBUG : be8d3688 416d60f0 [heap]
12-05 09:01:55.518 108 108 I DEBUG : be8d368c 401893d7 /system/lib/libc.so (dlmalloc+5170)
12-05 09:01:55.518 108 108 I DEBUG : be8d3690 be8d36b4 [stack]
12-05 09:01:55.518 108 108 I DEBUG : be8d3694 4007ce98 /system/bin/mksh
12-05 09:01:55.518 108 108 I DEBUG : be8d3698 00000000
12-05 09:01:55.518 108 108 I DEBUG : be8d369c 416d6140 [heap]
12-05 09:01:55.518 108 108 I DEBUG : be8d36a0 00001001
12-05 09:01:55.518 108 108 I DEBUG : be8d36a4 00000000
12-05 09:01:55.518 108 108 I DEBUG : be8d36a8 00000003
12-05 09:01:55.518 108 108 I DEBUG : be8d36ac 416d611c [heap]
12-05 09:01:55.518 108 108 I DEBUG : be8d36b0 df0027ad
12-05 09:01:55.518 108 108 I DEBUG : be8d36b4 00000000
12-05 09:01:55.518 108 108 I DEBUG : #00 be8d36b8 00000000
12-05 09:01:55.518 108 108 I DEBUG : be8d36bc 00001000
12-05 09:01:55.518 108 108 I DEBUG : #01 be8d36c0 416d6088 [heap]
12-05 09:01:55.518 108 108 I DEBUG : be8d36c4 0001382c
12-05 09:01:55.518 108 108 I DEBUG : be8d36c8 00000001
12-05 09:01:55.518 108 108 I DEBUG : be8d36cc 4007ce98 /system/bin/mksh
12-05 09:01:55.518 108 108 I DEBUG : be8d36d0 40081d70
12-05 09:01:55.518 108 108 I DEBUG : be8d36d4 40081d74
12-05 09:01:55.518 108 108 I DEBUG : be8d36d8 40081b9c
12-05 09:01:55.518 108 108 I DEBUG : be8d36dc 416d6088 [heap]
12-05 09:01:55.518 108 108 I DEBUG : be8d36e0 416d2fb4 [heap]
12-05 09:01:55.518 108 108 I DEBUG : be8d36e4 40081de2
12-05 09:01:55.518 108 108 I DEBUG : be8d36e8 00000001
12-05 09:01:55.518 108 108 I DEBUG : be8d36ec 40061721 /system/bin/mksh
12-05 09:01:55.518 108 108 I DEBUG : #02 be8d36f0 416d6088 [heap]
12-05 09:01:55.518 108 108 I DEBUG : be8d36f4 0000001f
12-05 09:01:55.518 108 108 I DEBUG : be8d36f8 416d610c [heap]
12-05 09:01:55.518 108 108 I DEBUG : be8d36fc 416d5bec [heap]
12-05 09:01:55.518 108 108 I DEBUG : be8d3700 00000000
12-05 09:01:55.518 108 108 I DEBUG : be8d3704 00000000
12-05 09:01:55.518 108 108 I DEBUG : be8d3708 00000004
12-05 09:01:55.518 108 108 I DEBUG : be8d370c 40063427 /system/bin/mksh
12-05 09:01:55.526 108 108 I DEBUG :
12-05 09:01:55.526 108 108 I DEBUG : memory near r1:
12-05 09:01:55.526 108 108 I DEBUG : 416d6120 6f6c2f61 2f6c6163 2f706d74 73626467
12-05 09:01:55.534 108 108 I DEBUG : 416d6130 65767265 00000072 00000000 0000100b
12-05 09:01:55.534 108 108 I DEBUG : 416d6140 18bd8070 e59f302c e79f3003 e5933000
12-05 09:01:55.534 108 108 I DEBUG : 416d6150 e3530000 08bd8070 e1a01005 e1a00004
12-05 09:01:55.534 108 108 I DEBUG : 416d6160 ebfff8a7 e8bd4070 e1a01000 e59f0008
12-05 09:01:55.534 108 108 I DEBUG : 416d6170 e08f0000 ea00382e 00056dc8 000437f0
12-05 09:01:55.534 108 108 I DEBUG : 416d6180 e92d4010 ebffcd85 e5904020 e3540000
12-05 09:01:55.534 108 108 I DEBUG : 416d6190 1a000003 e8bd8010 e5944000 e3540000
12-05 09:01:55.534 108 108 I DEBUG : 416d61a0 0a00000a e5943004 e3530001 8afffff9
12-05 09:01:55.534 108 108 I DEBUG : 416d61b0 e5943024 e3530000 1afffff6 e1a00004
12-05 09:01:55.534 108 108 I DEBUG : 416d61c0 ebfffa99 e5944000 e3540000 1afffff4
12-05 09:01:55.534 108 108 I DEBUG : 416d61d0 e8bd8010 e92d41f0 e1a04000 e1a05001
12-05 09:01:55.534 108 108 I DEBUG : 416d61e0 ebffcd6e e1a08000 e5b8601c e1a07000
12-05 09:01:55.534 108 108 I DEBUG : 416d61f0 e3560000 1a000004 e8bd81f0 e1a08006
12-05 09:01:55.534 108 108 I DEBUG : 416d6200 e5966000 e3560000 0a00001a e596c010
12-05 09:01:55.534 108 108 I DEBUG : 416d6210 e59c3004 e3530001 8afffff7 e1cc21d0
12-05 09:01:55.534 108 108 I DEBUG : memory near r2:
12-05 09:01:55.534 108 108 I DEBUG : 00000fe0 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : 00000ff0 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : 00001000 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : 00001010 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : 00001020 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : 00001030 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : 00001040 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : 00001050 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : 00001060 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : 00001070 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : 00001080 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : 00001090 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : 000010a0 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : 000010b0 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : 000010c0 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : 000010d0 ffffffff ffffffff ffffffff ffffffff
12-05 09:01:55.534 108 108 I DEBUG : memory near r3:
12-05 09:01:55.534 108 108 I DEBUG : memory near r6:
12-05 09:01:55.534 108 108 I DEBUG : 416d60fc 401c2c64 00000010 00000012 00000000
12-05 09:01:55.534 108 108 I DEBUG : 416d610c 00746163 00000000 0000002b 416d6108
12-05 09:01:55.534 108 108 I DEBUG : 416d611c 7461642f 6f6c2f61 2f6c6163 2f706d74
12-05 09:01:55.541 108 108 I DEBUG : 416d612c 73626467 65767265 00000072 00000000
12-05 09:01:55.541 108 108 I DEBUG : 416d613c 0000100b 18bd8070 e59f302c e79f3003
12-05 09:01:55.541 108 108 I DEBUG : 416d614c e5933000 e3530000 08bd8070 e1a01005
12-05 09:01:55.541 108 108 I DEBUG : 416d615c e1a00004 ebfff8a7 e8bd4070 e1a01000
12-05 09:01:55.541 108 108 I DEBUG : 416d616c e59f0008 e08f0000 ea00382e 00056dc8
12-05 09:01:55.541 108 108 I DEBUG : 416d617c 000437f0 e92d4010 ebffcd85 e5904020
12-05 09:01:55.541 108 108 I DEBUG : 416d618c e3540000 1a000003 e8bd8010 e5944000
12-05 09:01:55.541 108 108 I DEBUG : 416d619c e3540000 0a00000a e5943004 e3530001
12-05 09:01:55.541 108 108 I DEBUG : 416d61ac 8afffff9 e5943024 e3530000 1afffff6
12-05 09:01:55.541 108 108 I DEBUG : 416d61bc e1a00004 ebfffa99 e5944000 e3540000
12-05 09:01:55.541 108 108 I DEBUG : 416d61cc 1afffff4 e8bd8010 e92d41f0 e1a04000
12-05 09:01:55.541 108 108 I DEBUG : 416d61dc e1a05001 ebffcd6e e1a08000 e5b8601c
12-05 09:01:55.541 108 108 I DEBUG : 416d61ec e1a07000 e3560000 1a000004 e8bd81f0
12-05 09:01:55.541 108 108 I DEBUG : memory near r8:
12-05 09:01:55.541 108 108 I DEBUG : 416d6120 6f6c2f61 2f6c6163 2f706d74 73626467
12-05 09:01:55.541 108 108 I DEBUG : 416d6130 65767265 00000072 00000000 0000100b
12-05 09:01:55.541 108 108 I DEBUG : 416d6140 18bd8070 e59f302c e79f3003 e5933000
12-05 09:01:55.541 108 108 I DEBUG : 416d6150 e3530000 08bd8070 e1a01005 e1a00004
12-05 09:01:55.541 108 108 I DEBUG : 416d6160 ebfff8a7 e8bd4070 e1a01000 e59f0008
12-05 09:01:55.541 108 108 I DEBUG : 416d6170 e08f0000 ea00382e 00056dc8 000437f0
12-05 09:01:55.541 108 108 I DEBUG : 416d6180 e92d4010 ebffcd85 e5904020 e3540000
12-05 09:01:55.541 108 108 I DEBUG : 416d6190 1a000003 e8bd8010 e5944000 e3540000
12-05 09:01:55.541 108 108 I DEBUG : 416d61a0 0a00000a e5943004 e3530001 8afffff9
12-05 09:01:55.541 108 108 I DEBUG : 416d61b0 e5943024 e3530000 1afffff6 e1a00004
12-05 09:01:55.541 108 108 I DEBUG : 416d61c0 ebfffa99 e5944000 e3540000 1afffff4
12-05 09:01:55.541 108 108 I DEBUG : 416d61d0 e8bd8010 e92d41f0 e1a04000 e1a05001
12-05 09:01:55.541 108 108 I DEBUG : 416d61e0 ebffcd6e e1a08000 e5b8601c e1a07000
12-05 09:01:55.541 108 108 I DEBUG : 416d61f0 e3560000 1a000004 e8bd81f0 e1a08006
12-05 09:01:55.541 108 108 I DEBUG : 416d6200 e5966000 e3560000 0a00001a e596c010
12-05 09:01:55.541 108 108 I DEBUG : 416d6210 e59c3004 e3530001 8afffff7 e1cc21d0
12-05 09:01:55.541 108 108 I DEBUG : memory near r9:
12-05 09:01:55.541 108 108 I DEBUG : 416d6070 00000000 00000004 00000000 0000001b
12-05 09:01:55.541 108 108 I DEBUG : 416d6080 416d6118 00000000 416d610c 416d611c
12-05 09:01:55.549 108 108 I DEBUG : 416d6090 00000000 00000063 416d6080 416d5ca8
12-05 09:01:55.549 108 108 I DEBUG : 416d60a0 be8d3b7c 00000000 00000000 416d2024
12-05 09:01:55.549 108 108 I DEBUG : 416d60b0 416d609c 416d5b1c 00000006 00000003
12-05 09:01:55.549 108 108 I DEBUG : 416d60c0 416d609c 416d5cac 00000006 00000003
12-05 09:01:55.549 108 108 I DEBUG : 416d60d0 00000000 00000000 00000000 00000000
12-05 09:01:55.549 108 108 I DEBUG : 416d60e0 00000000 00000000 00000000 00000000
12-05 09:01:55.549 108 108 I DEBUG : 416d60f0 00000000 00000011 416d4ce8 401c2c64
12-05 09:01:55.549 108 108 I DEBUG : 416d6100 00000010 00000012 00000000 00746163
12-05 09:01:55.549 108 108 I DEBUG : 416d6110 00000000 0000002b 416d6108 7461642f
12-05 09:01:55.549 108 108 I DEBUG : 416d6120 6f6c2f61 2f6c6163 2f706d74 73626467
12-05 09:01:55.549 108 108 I DEBUG : 416d6130 65767265 00000072 00000000 0000100b
12-05 09:01:55.549 108 108 I DEBUG : 416d6140 18bd8070 e59f302c e79f3003 e5933000
12-05 09:01:55.549 108 108 I DEBUG : 416d6150 e3530000 08bd8070 e1a01005 e1a00004
12-05 09:01:55.549 108 108 I DEBUG : 416d6160 ebfff8a7 e8bd4070 e1a01000 e59f0008
12-05 09:01:55.549 108 108 I DEBUG : memory near sl:
12-05 09:01:55.549 108 108 I DEBUG : 416d6170 e08f0000 ea00382e 00056dc8 000437f0
12-05 09:01:55.549 108 108 I DEBUG : 416d6180 e92d4010 ebffcd85 e5904020 e3540000
12-05 09:01:55.549 108 108 I DEBUG : 416d6190 1a000003 e8bd8010 e5944000 e3540000
12-05 09:01:55.549 108 108 I DEBUG : 416d61a0 0a00000a e5943004 e3530001 8afffff9
12-05 09:01:55.549 108 108 I DEBUG : 416d61b0 e5943024 e3530000 1afffff6 e1a00004
12-05 09:01:55.549 108 108 I DEBUG : 416d61c0 ebfffa99 e5944000 e3540000 1afffff4
12-05 09:01:55.549 108 108 I DEBUG : 416d61d0 e8bd8010 e92d41f0 e1a04000 e1a05001
12-05 09:01:55.549 108 108 I DEBUG : 416d61e0 ebffcd6e e1a08000 e5b8601c e1a07000
12-05 09:01:55.549 108 108 I DEBUG : 416d61f0 e3560000 1a000004 e8bd81f0 e1a08006
12-05 09:01:55.549 108 108 I DEBUG : 416d6200 e5966000 e3560000 0a00001a e596c010
12-05 09:01:55.549 108 108 I DEBUG : 416d6210 e59c3004 e3530001 8afffff7 e1cc21d0
12-05 09:01:55.549 108 108 I DEBUG : memory near fp:
12-05 09:01:55.549 108 108 I DEBUG : 40077e20 27000a27 49005c00 22005346 27262423
12-05 09:01:55.549 108 108 I DEBUG : 40077e30 3a2a2928 3e3d3c3b 605c5b3f 007d7c7b
12-05 09:01:55.557 108 108 I DEBUG : 40077e40 203a7325 67007325 68626172 00747369
12-05 09:01:55.557 108 108 I DEBUG : 40077e50 20646162 74736968 2079726f 61727261
12-05 09:01:55.557 108 108 I DEBUG : 40077e60 20200079 25002020 64252073 20636600
12-05 09:01:55.557 108 108 I DEBUG : 40077e70 2420652d 5349567b 3a4c4155 457b242d
12-05 09:01:55.557 108 108 I DEBUG : 40077e80 4f544944 762d3a52 207d7d69 1b002d2d
12-05 09:01:55.557 108 108 I DEBUG : 40077e90 1b483b5b 0a004a5b 68746f6e 20676e69
12-05 09:01:55.557 108 108 I DEBUG : 40077ea0 79206f74 006b6e61 6e61790a 6f73206b
12-05 09:01:55.557 108 108 I DEBUG : 40077eb0 6874656d 20676e69 73726966 50460074
12-05 09:01:55.557 108 108 I DEBUG : 40077ec0 00485441 656c6966 626f6c67 64616200
12-05 09:01:55.557 108 108 I DEBUG : 40077ed0 62757320 74697473 6f697475 7c3b006e
12-05 09:01:55.557 108 108 I DEBUG : 40077ee0 60292826 79002000 005e0024 276e6163
12-05 09:01:55.557 108 108 I DEBUG : 40077ef0 69622074 202c646e 20746f6e 74742061
12-05 09:01:55.557 108 108 I DEBUG : 40077f00 6f740079 6f6c206f 6b20676e 73207965
12-05 09:01:55.557 108 108 I DEBUG : 40077f10 65757165 0065636e 203a7325 25207325
12-05 09:01:55.557 108 108 I DEBUG : memory near ip:
12-05 09:01:55.557 108 108 I DEBUG : 4007cf18 4018f55c 4019405f 40191109 4018f950
12-05 09:01:55.557 108 108 I DEBUG : 4007cf28 4018e970 4018ed70 401b0de0 40184f55
12-05 09:01:55.557 108 108 I DEBUG : 4007cf38 4018ed8c 40192f39 4018ec34 40193fa5
12-05 09:01:55.557 108 108 I DEBUG : 4007cf48 4018fd98 40193fdd 40190154 4018f524
12-05 09:01:55.557 108 108 I DEBUG : 4007cf58 4018ec18 4018ebfc 4018e9fc 4018f738
12-05 09:01:55.557 108 108 I DEBUG : 4007cf68 40192a99 4019d1f5 4018f934 401949df
12-05 09:01:55.557 108 108 I DEBUG : 4007cf78 40194fd1 40194fe9 4019512f 4018ec6c
12-05 09:01:55.557 108 108 I DEBUG : 4007cf88 40194a21 401a1c51 4018ee88 4018a9ab
12-05 09:01:55.557 108 108 I DEBUG : 4007cf98 4019d631 4018f378 4018e9e0 40193f1f
12-05 09:01:55.557 108 108 I DEBUG : 4007cfa8 4018eac8 4018f47c 40199e11 40190858
12-05 09:01:55.557 108 108 I DEBUG : 4007cfb8 4018f0e0 4018f0a4 401967eb 4018e9a8
12-05 09:01:55.557 108 108 I DEBUG : 4007cfc8 4018e9c4 4019d225 4018eb70 4018ec50
12-05 09:01:55.557 108 108 I DEBUG : 4007cfd8 40194915 4018f404 4018f3e8 4018eb00
12-05 09:01:55.557 108 108 I DEBUG : 4007cfe8 40190c21 40191081 4018f4ec 4018f3b0
12-05 09:01:55.557 108 108 I DEBUG : 4007cff8 4018ee48 4019d771 00000020 00000020
12-05 09:01:55.557 108 108 I DEBUG : 4007d008 4007e215 00000000 00001000 00000000
12-05 09:01:55.557 108 108 I DEBUG : memory near sp:
12-05 09:01:55.565 108 108 I DEBUG : be8d3698 00000000 416d6140 00001001 00000000
12-05 09:01:55.565 108 108 I DEBUG : be8d36a8 00000003 416d611c df0027ad 00000000
12-05 09:01:55.565 108 108 I DEBUG : be8d36b8 00000000 00001000 416d6088 0001382c
12-05 09:01:55.565 108 108 I DEBUG : be8d36c8 00000001 4007ce98 40081d70 40081d74
12-05 09:01:55.565 108 108 I DEBUG : be8d36d8 40081b9c 416d6088 416d2fb4 40081de2
12-05 09:01:55.565 108 108 I DEBUG : be8d36e8 00000001 40061721 416d6088 0000001f
12-05 09:01:55.565 108 108 I DEBUG : be8d36f8 416d610c 416d5bec 00000000 00000000
12-05 09:01:55.565 108 108 I DEBUG : be8d3708 00000004 40063427 416d2048 416d610c
12-05 09:01:55.565 108 108 I DEBUG : be8d3718 f792d809 416d2024 f792d809 4007ce98
12-05 09:01:55.565 108 108 I DEBUG : be8d3728 4007836b 416d2024 416d609c 0001502b
12-05 09:01:55.565 108 108 I DEBUG : be8d3738 00015309 0000001f 00000001 416d2fb4
12-05 09:01:55.565 108 108 I DEBUG : be8d3748 4007ce98 00000000 f792d809 40061d67
12-05 09:01:55.565 108 108 I DEBUG : be8d3758 416d6088 00000000 416d5bec 416d2fb4
12-05 09:01:55.565 108 108 I DEBUG : be8d3768 4007ce98 40081c8c 00000000 4008144c
12-05 09:01:55.565 108 108 I DEBUG : be8d3778 40081454 4006270d be8d37c0 00000000
12-05 09:01:55.565 108 108 I DEBUG : be8d3788 4007ce98 00000004 00000001 b2ed8ac4
12-05 09:01:55.565 108 108 I DEBUG : code around pc:
12-05 09:01:55.565 108 108 I DEBUG : 4018ed78 ef000000 e8bd0090 e1b00000 512fff1e
12-05 09:01:55.565 108 108 I DEBUG : 4018ed88 ea00944e e92d0090 e3a07004 ef000000
12-05 09:01:55.565 108 108 I DEBUG : 4018ed98 e8bd0090 e1b00000 512fff1e ea009447
12-05 09:01:55.565 108 108 I DEBUG : 4018eda8 e1a0c00d e92d00f0 e89c0070 e3a070b4
12-05 09:01:55.565 108 108 I DEBUG : 4018edb8 ef000000 e8bd00f0 e1b00000 512fff1e
12-05 09:01:55.565 108 108 I DEBUG : 4018edc8 ea00943e e1a0c00d e92d00f0 e89c0070
12-05 09:01:55.565 108 108 I DEBUG : 4018edd8 e3a070b5 ef000000 e8bd00f0 e1b00000
12-05 09:01:55.565 108 108 I DEBUG : 4018ede8 512fff1e ea009435 e92d0090 e3a07005
12-05 09:01:55.565 108 108 I DEBUG : 4018edf8 ef000000 e8bd0090 e1b00000 512fff1e
12-05 09:01:55.565 108 108 I DEBUG : 4018ee08 ea00942e e92d0090 e59f7010 ef000000
12-05 09:01:55.565 108 108 I DEBUG : 4018ee18 e8bd0090 e1b00000 512fff1e ea009427
12-05 09:01:55.565 108 108 I DEBUG : 4018ee28 00000142 e92d0090 e3a07006 ef000000
12-05 09:01:55.565 108 108 I DEBUG : 4018ee38 e8bd0090 e1b00000 512fff1e ea00941f
12-05 09:01:55.565 108 108 I DEBUG : 4018ee48 e92d0090 e3a07013 ef000000 e8bd0090
12-05 09:01:55.573 108 108 I DEBUG : 4018ee58 e1b00000 512fff1e ea009418 e1a0c00d
12-05 09:01:55.573 108 108 I DEBUG : 4018ee68 e92d00f0 e89c0070 e3a0708c ef000000
12-05 09:01:55.573 108 108 I DEBUG : code around lr:
12-05 09:01:55.573 108 108 I DEBUG : 4006463c f7f32401 4631ed36 46584602 fe64f009
12-05 09:01:55.573 108 108 I DEBUG : 4006464c b310e023 200146c2 463a4651 ed4cf7f3
12-05 09:01:55.573 108 108 I DEBUG : 4006465c bf1c1c43 0707ebc0 d1134482 ece4f7f3
12-05 09:01:55.573 108 108 I DEBUG : 4006466c 2a046802 6800d00e ed1af7f3 44794916
12-05 09:01:55.573 108 108 I DEBUG : 4006467c 48164602 f0094478 b17dfe47 f7f34628
12-05 09:01:55.573 108 108 I DEBUG : 4006468c e00becf8 d1de2f00 b115e7c0 f7f34628
12-05 09:01:55.573 108 108 I DEBUG : 4006469c f8d9ecf0 2b003000 e000d196 46402401
12-05 09:01:55.573 108 108 I DEBUG : 400646ac ec5cf7f3 e8bd4620 bf008ffe 000187b8
12-05 09:01:55.573 108 108 I DEBUG : 400646bc 00014019 00018816 00014014 0001382c
12-05 09:01:55.573 108 108 I DEBUG : 400646cc 00013870 00013fd9 00013f46 000137bc
12-05 09:01:55.573 108 108 I DEBUG : 400646dc ab01b51f 44784806 e883c807 4a050007
12-05 09:01:55.573 108 108 I DEBUG : 400646ec 6812447a 46186010 ff3cf7ff bd00b005
12-05 09:01:55.573 108 108 I DEBUG : 400646fc 00018952 000186c4 4604b570 68401d05
12-05 09:01:55.573 108 108 I DEBUG : 4006470c 491ab130 f7f34479 b908ec30 0508f104
12-05 09:01:55.573 108 108 I DEBUG : 4006471c b1086828 b12c686c 24014815 f0094478
12-05 09:01:55.573 108 108 I DEBUG : 4006472c e021fdf3 f9f8f00c b9804606 ec7cf7f3
12-05 09:01:55.596 378 399 I BootReceiver: Copying /data/tombstones/tombstone_05 to DropBox (SYSTEM_TOMBSTONE)
12-05 09:01:55.713 1477 1477 D su : su invoked.
12-05 09:01:55.721 1478 1478 D su : Allowing root/system/radio.
12-05 09:01:55.729 1479 1479 D su : 0 /system/bin/mksh executing 777 chmod using binary /system/bin/sh : sh -c chmod /data/data/com.example.SanAngeles/gdbserver
12-05 09:01:55.862 1484 1484 D su : su invoked.
12-05 09:01:55.870 1485 1485 E su : Unknown id: :2020
12-05 09:01:55.987 1489 1489 D su : su invoked.
12-05 09:01:55.995 1490 1490 E su : Unknown id: :2020
12-05 09:01:56.291 1493 1493 D AndroidRuntime:
12-05 09:01:56.291 1493 1493 D AndroidRuntime: >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
12-05 09:01:56.291 1493 1493 D AndroidRuntime: CheckJNI is OFF
Test two, ARM based AVD on Android 4.2.2
In this test, the GDBServer launched (run-as was renamed). However, there were two “illegal instruction” messages which seemed to be from NSight or VS2015 (pro), and not from the AVD. After hitting “continue” on each popup dialog, the NSight/VS2015 debugging session ended, but the application actually started running (SanAndreas). This scenario is repeatable (consistent).
Logcat from that session follows
12-05 14:11:28.087 954 954 D AndroidRuntime: CheckJNI is ON
12-05 14:11:28.087 954 954 D AndroidRuntime: >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
12-05 14:11:28.108 954 954 D dalvikvm: Trying to load lib libjavacore.so 0x0
12-05 14:11:28.118 954 954 D dalvikvm: Added shared lib libjavacore.so 0x0
12-05 14:11:28.128 954 954 D dalvikvm: Added shared lib libnativehelper.so 0x0
12-05 14:11:28.128 954 954 D dalvikvm: Trying to load lib libnativehelper.so 0x0
12-05 14:11:28.458 954 954 D dalvikvm: Note: class Landroid/app/ActivityManagerNative; has 157 unimplemented (abstract) methods
12-05 14:11:28.458 954 954 D AndroidRuntime: Calling main entry com.android.commands.am.Am
12-05 14:11:28.468 276 503 I ActivityManager: Killing proc 922:com.example.SanAngeles/u0a10050: force stop com.example.SanAngeles
12-05 14:11:28.468 276 503 I ActivityManager: Force stopping package com.example.SanAngeles appid=10050 user=0
12-05 14:11:28.478 954 954 D AndroidRuntime: Shutting down VM
12-05 14:11:28.488 954 958 D dalvikvm: GC_CONCURRENT freed 89K, 17% free 455K/548K, paused 0ms+1ms, total 4ms
12-05 14:11:28.927 966 966 D AndroidRuntime: CheckJNI is ON
12-05 14:11:28.927 966 966 D AndroidRuntime: >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
12-05 14:11:28.947 966 966 D dalvikvm: Added shared lib libjavacore.so 0x0
12-05 14:11:28.947 966 966 D dalvikvm: Trying to load lib libjavacore.so 0x0
12-05 14:11:28.967 966 966 D dalvikvm: Added shared lib libnativehelper.so 0x0
12-05 14:11:28.967 966 966 D dalvikvm: Trying to load lib libnativehelper.so 0x0
12-05 14:11:29.288 966 966 D dalvikvm: Note: class Landroid/app/ActivityManagerNative; has 157 unimplemented (abstract) methods
12-05 14:11:29.288 966 966 D AndroidRuntime: Calling main entry com.android.commands.am.Am
12-05 14:11:29.308 276 409 W WindowManager: Failure taking screenshot for (246x410) to layer 21005
12-05 14:11:29.308 276 409 I ActivityManager: START u0 {flg=0x10000000 cmp=com.example.SanAngeles/.DemoActivity} from pid 966
12-05 14:11:29.308 276 409 I ActivityManager: Force stopping package com.example.SanAngeles appid=10050 user=-1
12-05 14:11:29.328 976 976 D dalvikvm: Not late-enabling CheckJNI (already on)
12-05 14:11:29.328 966 966 D AndroidRuntime: Shutting down VM
12-05 14:11:29.348 276 416 I ActivityManager: Start proc com.example.SanAngeles for activity com.example.SanAngeles/.DemoActivity: pid=976 uid=10050 gids={50050, 1028}
12-05 14:11:29.358 966 970 D dalvikvm: GC_CONCURRENT freed 91K, 16% free 494K/588K, paused 0ms+0ms, total 6ms
12-05 14:11:29.408 37 37 E SurfaceFlinger: ro.sf.lcd_density must be defined as a build property
12-05 14:11:29.548 976 976 E Trace : error opening trace file: No such file or directory (2)
12-05 14:11:29.568 276 373 E ThrottleService: problem during onPollAlarm: java.lang.IllegalStateException: problem parsing stats: java.io.FileNotFoundException: /proc/net/xt_qtaguid/iface_stat_all: open failed: ENOENT (No such file or directory)
12-05 14:11:29.628 976 976 W ActivityThread: Application com.example.SanAngeles is waiting for the debugger on port 8100...
12-05 14:11:29.668 976 976 I System.out: Sending WAIT chunk
12-05 14:11:29.937 37 79 E SurfaceFlinger: ro.sf.lcd_density must be defined as a build property
12-05 14:11:29.937 276 293 I Choreographer: Skipped 40 frames! The application may be doing too much work on its main thread.
12-05 14:11:32.682 976 982 I dalvikvm: Debugger is active
12-05 14:11:33.528 976 976 I System.out: waiting for debugger to settle...
12-05 14:11:33.528 976 976 I System.out: Debugger has connected
12-05 14:11:33.735 976 976 I System.out: waiting for debugger to settle...
12-05 14:11:33.936 976 976 I System.out: waiting for debugger to settle...
12-05 14:11:34.137 976 976 I System.out: waiting for debugger to settle...
12-05 14:11:34.337 976 976 I System.out: waiting for debugger to settle...
12-05 14:11:34.540 976 976 I System.out: waiting for debugger to settle...
12-05 14:11:34.741 976 976 I System.out: waiting for debugger to settle...
12-05 14:11:34.942 976 976 I System.out: debugger has settled (1408)
12-05 14:11:34.978 976 976 D dalvikvm: Trying to load lib /data/app-lib/com.example.SanAngeles-2/libsanangeles.so 0x40cd0b60
12-05 14:11:39.327 276 290 W ActivityManager: Launch timeout has expired, giving up wake lock!
12-05 14:11:39.497 276 290 W ActivityManager: Activity idle timeout for ActivityRecord{40ff7178 u0 com.example.SanAngeles/.DemoActivity}
12-05 14:11:40.718 35 35 I DEBUG : ptrace attach failed: Operation not permitted
12-05 14:11:40.718 976 976 F libc : Fatal signal 4 (SIGILL) at 0x40005a52 (code=1), thread 976 (mple.SanAngeles)
12-05 14:11:41.988 276 503 I ActivityManager: Process com.example.SanAngeles (pid 976) has died.
12-05 14:11:41.988 38 38 D Zygote : Process 976 terminated by signal (4)
12-05 14:11:42.008 1023 1023 D dalvikvm: Not late-enabling CheckJNI (already on)
12-05 14:11:42.028 276 503 I ActivityManager: Start proc com.example.SanAngeles for activity com.example.SanAngeles/.DemoActivity: pid=1023 uid=10050 gids={50050, 1028}
12-05 14:11:42.078 1023 1023 E Trace : error opening trace file: No such file or directory (2)
12-05 14:11:42.098 1023 1023 D dalvikvm: No JNI_OnLoad found in /data/app-lib/com.example.SanAngeles-2/libsanangeles.so 0x40cd1510, skipping init
12-05 14:11:42.098 1023 1023 D dalvikvm: Added shared lib /data/app-lib/com.example.SanAngeles-2/libsanangeles.so 0x40cd1510
12-05 14:11:42.098 1023 1023 D dalvikvm: Trying to load lib /data/app-lib/com.example.SanAngeles-2/libsanangeles.so 0x40cd1510
12-05 14:11:42.218 37 620 E SurfaceFlinger: ro.sf.lcd_density must be defined as a build property
12-05 14:11:42.268 1023 1037 D libEGL : Emulator without GPU support detected. Fallback to software renderer.
12-05 14:11:42.268 37 79 E SurfaceFlinger: ro.sf.lcd_density must be defined as a build property
12-05 14:11:42.278 1023 1037 D libEGL : loaded /system/lib/egl/libGLES_android.so
12-05 14:11:42.328 1023 1023 D gralloc_goldfish: Emulator without GPU emulation detected.
12-05 14:11:42.407 276 292 I ActivityManager: Displayed com.example.SanAngeles/.DemoActivity: +13s93ms
12-05 14:11:42.838 1023 1037 I SanAngeles: resize w=480 h=690
12-05 14:11:42.878 1023 1037 I ARMAssembler: generated scanline__00000197:03010102_00000000_00000000 [ 26 ipp] (59 ins) at [0x499be1f0:0x499be2dc] in 3421703 ns
12-05 14:11:42.888 1023 1037 I ARMAssembler: generated scanline__00000177:03202002_00000000_00000000 [ 37 ipp] (54 ins) at [0x499be2e0:0x499be3b8] in 647681 ns
