Hi
After installing Omniverse on DGX A100 with Ubuntu 20.04, I tried to install Omniverse Create. However, the launch button remains grey after the installation is completed. i clicked the launch button but it seems that the Create is launched for 1 sec and disappeared afterwards.
he / him | LinkedIn | Discord ID: Prof E#2041
Omniverse: “A New Era of Collaboration and Simulation” (video)
Omniverse Create’s latest features show & tell: Twitch livestream.
As seen in VentureBeat | Physics Showcase
PLEASE NOTE: If you are reporting a bug/issue, please provide OS, GPU, GPU Driver, the version of the app, and full log file (if applicable). For crashes, please zip and provide a link to your logs → C:\Users\ [YOUR NAME] \ .nvidia-omniverse\logs
hello @ryan_lin - The DGX A100 station has a display card that does not have RTX capabilities. Applications like Create require that the display card attached to the monitor have this feature. The NVIDIA DGX A100 station currently has no option to have an RTX type of display card.
The A100 GPUs on that system can be used for rendering, but cannot drive a display. Thus the A100 station could be used as a render farm for a remote server, but cannot run Omniverse Create. This is the error you are seeing.
Hi @mirice
Thanks for your feedback, does that mean I could install Omniverse Farm Queue on DGX Workstation and install Omniverse Farm Agent on RTX enabled laptop to send jobs to DGX Workstation to run?
Good evening, I have the same problem even though my computer has an RTX3060 card. What can it depend on? the computer in my possession is an MSI Katana GF66, the graphic driver is 495
Hello @gendiego! The development team got back to me with some more information. They mentioned that the 495 driver that you are using has cache issues which take several (7+) minutes to load. They recommend using the 470 driver instead. Try that out and let me know if that solves your problem.
If not, then I will need you to grab another log file for Create which should be found in the same location.
hello @ryan_lin - Yes you will be able to install the Farm Agent on the A100 station and used another server that has RTX card. That RTX server can send render jobs to the A100 station. We are finalizing docs on how to do this.
