Cannot link Streammux to Capsfilter and Nvinfer
I am trying to create this pipeline:
appsrc(rgb jpeg) -> nvvidconv -> capsfilter(video/x-raw(memory:NVMM), format=(string)RGBA) -> nvstreammux -> nvinfer -> nvjpegenc -> appsink.
But for some reason I cannot link streammux to capsfilter and nvinfer.
Below is the code:
pipelineData.pipeline = gst_pipeline_new ("rtsp-pipeline");
pipelineData.source = gst_element_factory_make ("appsrc", "source");
pipelineData.convert = gst_element_factory_make ("nvvidconv", "videoconvert");
pipelineData.capsfilter = gst_element_factory_make ("capsfilter", "capsfilter");
pipelineData.nvstreammux = gst_element_factory_make ("nvstreammux", "nvstreammux");
pipelineData.nvinfer = gst_element_factory_make ("nvinfer", "nvinfer");
pipelineData.jpegenc = gst_element_factory_make ("nvjpegenc", "nvjpegenc");
pipelineData.sink = gst_element_factory_make ("appsink", "sink");
if (!pipelineData.source || !pipelineData.convert || !pipelineData.capsfilter ||
!pipelineData.nvstreammux || !pipelineData.nvinfer || !pipelineData.jpegenc || !pipelineData.sink) {
	std::cout << " Pipelines could not be created " << std::endl;
	terminate = TRUE;
GstCaps *caps = gst_caps_from_string(“video/x-raw(memory:NVMM), format=(string)RGBA”);
g_object_set (G_OBJECT (pipelineData.capsfilter), “caps”, caps, NULL);
gst_bin_add_many (GST_BIN (pipelineData.pipeline), pipelineData.source , pipelineData.convert, pipelineData.capsfilter, pipelineData.nvstreammux, pipelineData.nvinfer, pipelineData.jpegenc, pipelineData.sink, NULL);
if (!gst_element_link_many (pipelineData.source, pipelineData.convert, pipelineData.capsfilter, NULL)) {
std::cout << “Elements could not be linked.” <<std::endl;
gst_object_unref (pipelineData.pipeline);
terminate = TRUE;
if (!gst_element_link_many (pipelineData.nvstreammux, pipelineData.nvinfer, pipelineData.jpegenc, pipelineData.sink, NULL)) {
terminate = TRUE;
GstPad *streamk_pad = gst_element_get_request_pad (pipelineData.nvstreammux, “sink_0”);
if (!streamk_pad) {
std::cout <<“Streammux request sink pad failed. Exiting.\n”<<std::endl;
terminate = TRUE;
  GstPad *caps_pad = gst_element_get_static_pad (pipelineData.capsfilter, "src");
if (!sink_pad) {
	std::cout << "sink_pad request sink pad failed. Exiting.\n"<<std::endl;
	terminate = TRUE;
if (gst_pad_link (caps_pad, streamk_pad) != GST_PAD_LINK_OK) { // Fails here
	std::cout << "Failed to link caps_pad to stream muxer. Exiting.\n"<<std::endl;
	terminate = TRUE;
Any help will be appreciated.
I also tried
g_signal_connect (pipelineData.capsfilter, “pad-added”, G_CALLBACK (pad_added_handler), &pipelineData);
but it never gets fired.
Could you help to set GST_DEBUG=3 and share me with the log?
Below are the logs.
Pipeline state changed from NULL to READY:
0:00:00.151996590 18355 0x7f982f3370 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:source:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:00.152177168 18355 0x7f982f3370 FIXME videodecoder gstvideodecoder.c:933:gst_video_decoder_drain_out: Sub-class should implement drain()
ApSrc needs data!!!
Pushing Data.
Pushed buffer to appsrc
0:00:15.018156897 18355 0x7f982f3370 WARN videodecoder gstvideodecoder.c:2443:gst_video_decoder_chain: Received buffer without a new-segment. Assuming timestamps start from 0.
0:00:15.018229972 18355 0x7f982f3370 FIXME videodecoder gstvideodecoder.c:933:gst_video_decoder_drain_out: Sub-class should implement drain()
0:00:15.025113152 18355 0x7f982f3370 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps: transform could not transform video/x-raw(memory:NVMM), width=(int)720, height=(int)576, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1, format=(string)RGBA in anything we support
0:00:15.025306750 18355 0x7f982f3370 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps: transform could not transform video/x-raw(memory:NVMM), width=(int)720, height=(int)576, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1, format=(string)RGBA in anything we support
0:00:15.025339355 18355 0x7f982f3370 WARN GST_PADS gstpad.c:4226:gst_pad_peer_query:videoconvert:src could not send sticky events
0:00:15.027595866 18355 0x7f982f3370 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps: transform could not transform video/x-raw(memory:NVMM), width=(int)720, height=(int)576, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1, format=(string)RGBA in anything we support
0:00:15.065020638 18355 0x7f982f3370 ERROR nvvideoconvert gstnvvideoconvert.c:2551:gst_nvvideoconvert_transform: Input buffer is not NvBufSurface
0:00:15.065075535 18355 0x7f982f3370 ERROR nvvideoconvert gstnvvideoconvert.c:2930:gst_nvvideoconvert_transform: buffer transform failed
0:00:15.065148453 18355 0x7f982f3370 WARN basesrc gstbasesrc.c:3055:gst_base_src_loop: error: Internal data stream error.
0:00:15.065176579 18355 0x7f982f3370 WARN basesrc gstbasesrc.c:3055:gst_base_src_loop: error: streaming stopped, reason error (-5)
Gst Message Error!!!
Exiting from pipeline!!!
0:00:15.065672945 18355 0x7f982f3370 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps: transform could not transform video/x-raw(memory:NVMM), width=(int)720, height=(int)576, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1, format=(string)RGBA in anything we support
0:00:15.065865918 18355 0x7f982f3370 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps: transform could not transform video/x-raw(memory:NVMM), width=(int)720, height=(int)576, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1, format=(string)RGBA in anything we support
(node:18355): GLib-CRITICAL **: 11:13:36.496: g_source_remove: assertion ‘tag > 0’ failed
Please take note of :
The input is a jpeg image.
which platform are u using?
Is it possible to replace appsrc with uridecodebin and give a try?
I am using the jetson nano TX1. With uridecodebin it works but that would not work for my use case.
I am creating a binding for nodejs. So there will be multiple pipelines.i.e
uridecodebin[
n]-> nvconvert -> jpegenc -> appsink
Feed all to nvinfer, etc
next pipeline
“appsrc(rgb jpeg)”
Did you decode jpeg image to be RGB format in appsrc ?
Please use nvvideoconvert in deepstream pipeline, but not use nvvidconv which does not have deepstream flag.
The jpeg image is in rgb. Besides nvvidconv should do the conversion if not.
Is it possible for you to do a working pipeline, even if its in gst launch that uses appsrc and nvinfer?
Is there no example of running nvinfer through appsrc? I cannot seem to be able to solve this problem.
I made a pipeline uridecodebin->nvstreammux->nvinfer->appsink got the graph and noticed nvv4l2decoder before streammux. So I changed the pipeline and it works.
New Pipeline:
appsrc->nvv4l2decoder->streammux->nvinfer->appsink.
