I am trying to command a robot arm through the ROS bridge using a position target. I have attached the USD I am using.
fanuc_test.usd (6.1 KB)
I am able to read the joint state by echoing the /joint_states topic, so I know the ROS bridge is basically functioning. However, as stated, I am trying to command the robot to move using the following /joint_command :
rostopic pub /joint_command sensor_msgs/JointState “header:
seq: 0
stamp: {secs: 1, nsecs: 0}
frame_id: ‘’
position: [90,0,0,0,0,0]”
But the robot does not move at all. Initially I also tried with position vector {1,0,0,0,0,0} which should be withing limits if they are in radians. But either way, the robot does not move. I also don’t see any change in the joint efforts (by echoing /joint_states) when I publish this topic. Please advise what properties may be missing or if some configuration is wrong.
Thank you
