Hi everyone,
I use the oclea board as an h264 video encoder and streaming via my lan.
The oclea streaming the video by gstreamer with this command:
gst-launch-1.0 olcamerasrc ! video/x-h264,width=1920,height=1080,stream-format=byte-stream,bitrate=160000 ! queue ! mpegtsmux ! rndbuffersize min=940 max=940 ! udpsink host=172.17.1.10 port=9000
I can decode and playing this encoded video by ffplay and everything is fine.
But, when I tried to decode this video by jetson nano at 02_video_dec_example, I got this error:
Video Resolution: 1920x1080
[INFO] (NvEglRenderer.cpp:110) Setting Screen width 1920 height 1200
libv4l2_nvvidconv (0):(802) (INFO) : Allocating (14) OUTPUT PLANE BUFFERS Layout=1
libv4l2_nvvidconv (0):(818) (INFO) : Allocating (14) CAPTURE PLANE BUFFERS Layout=0
Query and set capture successful
libv4l2_nvvidconv (0):(1688) (ERROR) : NvDdkVicConfigure Failed
libv4l2_nvvidconv (0):(1710) (ERROR) : NVVIDCONV ERROR 2
What is the problem ?
Best regards.
