Chester:
I verified that our Mavericks system has Xcode 5.1.1 installed:
cparrott@mavericks /Applications/Xcode.app/Contents $ cat version.plist
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>BuildVersion</key>
<string>10</string>
<key>CFBundleShortVersionString</key>
<string>5.1.1</string>
<key>CFBundleVersion</key>
<string>5085</string>
<key>ProductBuildVersion</key>
<string>5B1008</string>
<key>ProjectName</key>
<string>IDEFrameworks</string>
<key>SourceVersion</key>
<string>5085000000000000</string>
</dict>
</plist>
And I see that our system has a stddef.h file in /usr/include:
cparrott@mavericks /Applications/Xcode.app/Contents $ ls -l /usr/include/stddef.h
-r--r--r-- 1 root wheel 5079 Apr 10 15:07 /usr/include/stddef.h
This is the contents of this file:
cparrott@mavericks /Applications/Xcode.app/Contents $ cat /usr/include/stddef.h
* Copyright (c) 2000 Apple Computer, Inc. All rights reserved.
* @APPLE_LICENSE_HEADER_START@
* This file contains Original Code and/or Modifications of Original Code
* as defined in and that are subject to the Apple Public Source License
* Version 2.0 (the 'License'). You may not use this file except in
* compliance with the License. Please obtain a copy of the License at
* http://www.opensource.apple.com/apsl/ and read it before using this
* file.
* The Original Code and all software distributed under the License are
* distributed on an 'AS IS' basis, WITHOUT WARRANTY OF ANY KIND, EITHER
* EXPRESS OR IMPLIED, AND APPLE HEREBY DISCLAIMS ALL SUCH WARRANTIES,
* INCLUDING WITHOUT LIMITATION, ANY WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE, QUIET ENJOYMENT OR NON-INFRINGEMENT.
* Please see the License for the specific language governing rights and
* limitations under the License.
* @APPLE_LICENSE_HEADER_END@
/* $OpenBSD: stddef.h,v 1.2 1997/09/21 10:45:52 niklas Exp $ */
/* $NetBSD: stddef.h,v 1.4 1994/10/26 00:56:26 cgd Exp $ */
* Copyright (c) 1990 The Regents of the University of California.
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* 1. Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* 3. All advertising materials mentioning features or use of this software
* must display the following acknowledgement:
* This product includes software developed by the University of
* California, Berkeley and its contributors.
* 4. Neither the name of the University nor the names of its contributors
* may be used to endorse or promote products derived from this software
* without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
* SUCH DAMAGE.
* @(#)stddef.h 5.5 (Berkeley) 4/3/91
#if !defined(__STDDEF_H__)
#if !defined(__need_wchar_t) && !defined(__need_size_t) \
&& !defined(__need_ptrdiff_t) && !defined(__need_NULL) \
&& !defined(__need_wint_t) && !defined(__need_rsize_t)
#define __STDDEF_H__
#endif /* none of __need_* defined */
#include <_types.h>
#if defined(__STDDEF_H__) || defined(__need_ptrdiff_t)
#include <sys/_types/_ptrdiff_t.h>
#endif /* __STDDEF_H__ || __need_ptrdiff_t */
#if defined(__STDDEF_H__) || defined(__need_size_t)
/* DO NOT REMOVE THIS COMMENT: fixincludes needs to see:
* _GCC_SIZE_T */
#include <sys/_types/_size_t.h>
#endif /* __STDDEF_H__ || __need_size_t */
#if (defined(__STDDEF_H__) && defined(__STDC_WANT_LIB_EXT1__) && __STDC_WANT_LIB_EXT1__ >= 1) || defined(__need_rsize_t)
#include <sys/_types/_rsize_t.h>
#endif /* (__STDDEF_H__ && __STDC_WANT_LIB_EXT1__ >= 1) || __need_rsize_t */
#if defined(__STDDEF_H__) || defined(__need_wchar_t)
#include <sys/_types/_wchar_t.h>
#endif /* __STDDEF_H__ || __need_wchar_t */
#if (defined(__STDDEF_H__) && !defined(_ANSI_SOURCE) && (!defined(_POSIX_C_SOURCE) || defined(_DARWIN_C_SOURCE))) \
#include <sys/_types/_wint_t.h>
#endif /* __STDDEF_H__ && !_ANSI_SOURCE && (!_POSIX_C_SOURCE || _DARWIN_C_SOURCE) || __need_wchar_t */
#if defined(__STDDEF_H__) || defined(__need_NULL)
#include <sys/_types/_null.h>
#endif /* __STDDEF_H__ || __need_NULL */
#ifdef __STDDEF_H__
#if defined(__GNUC__) && (__GNUC__ == 3 && __GNUC_MINOR__ >= 5 || __GNUC__ > 3)
#ifndef __offsetof /* Deprecated: for source compatibility only */
#define __offsetof(type, field) __builtin_offsetof(type, field)
#endif
#define offsetof(type, field) __builtin_offsetof(type, field)
#else /* ! (gcc >= 3.5) */
#define __offsetof(type, field) ((size_t)(&((type *)0)->field))
#endif
#define offsetof(type, field) ((size_t)(&((type *)0)->field))
#endif /* (gcc >= 3.5) */
#endif /* __STDDEF_H__ */
#undef __need_ptrdiff_t
#undef __need_size_t
#undef __need_wchar_t
#undef __need_wint_t
#undef __need_NULL
Can you confirm whether /usr/include/stddef.h is present on your system? And if so, does it match the contents as above?
Best regards,
+chris
