Cannot pull any images from nvcr.io (502 bad gateway error)
hello. I’m in s.korea
Server spec: ubuntu 20.04
Trying to pull clara-train-sdk version (3.0, 3.1.01, 4.0)
I can’t download all sdk versions.
error message: Error response from daemon: login attempt to https://nvcr.io/v2/ failed with status: 502 Bad Gateway
i can’t login docker nvcr.io too.
same here, trying to pull nvcr.io/nvidia/l4t-base:r32.6.1
docker pull nvcr.io/nvidia/l4t-base:r32.6.1
it is still not working and error message is same.
“Error response from daemon: received unexpected HTTP status: 502 Bad Gateway”
I also couldn’t login to nvcr.io.
Hello everyone,
I have the engineers looking into this issue now. Watch here for updates.
Thanks for your patience,
Tom K
