Cannot pull clara-monitor server image
Trying to run clara monitor 0.7.4.
terminal freezes when I execute
clara monitor start. Also found this error for kubectl pods.
clara-monitor-server-monitor-server-7446fcb697-blxzd 0/1 ImagePullBackOff 0 31h
I can think of two things to do in this situation.
  1. Run the command kubectl describe pod clara-monitor-server-monitor-server-7446fcb697-blxzd.
    Near the end of the output it should list all errors with details. This should provide us the URL Kubernetes is trying to use to pull the image.
  2. Not use the Monitor Server. It does not provide any critical functionality for Clara. All it does is allow visualization of utilization ala Graphana.
Thanks Jwyman, can you help me out on this one too?
