Cannot pull trsenorRT image from NGC. received unexpected HTTP status: 502 Bad Gateway
Hi I am trying to pull NGC docker image for TensorRT 8.2.3, but I keep recieving following error:
docker pull nvcr.io/nvidia/tensorrt:22.02-py3
Error response from daemon: received unexpected HTTP status: 502 Bad Gateway
Me too!!!
Me too
Me too!
i think all of images from NGC can’t pull today
Cannot pull any image from nvcr.io (502) - NGC GPU Cloud / Docker and NVIDIA Docker - NVIDIA Developer Forums
the same problem:
Username: $oauthtoken
Password:
Error response from daemon: login attempt to https://nvcr.io/v2/ failed with status: 502 Bad Gateway
Same here today, looks like Nvidia’s problem, not mine
I have same issue today, ngc has some thing problems…
Me too, the following error: => ERROR [internal] load metadata for nvcr.io/nvidia/pytorch:22.02-py3 121.8s
=> [auth] nvidia/pytorch:pull,push token for nvcr.io 0.0s
[internal] load metadata for nvcr.io/nvidia/pytorch:22.02-py3:
nvcr.io/nvidia/pytorch:22.02-py3: pulling from host nvcr.io failed with status code [manifests 22.02-py3]: 504 Gateway Time-out
It works now!
