Cannot register existing type 'GstVideoAggregator'
I’m trying to create a drowsiness detection program. Where specific behaviors will output actions like play alarm or display gif.
What i’ve tried
rm .cache/gstreamer-1.0/registry.aarch64.bin
updated to gst-inspect-1.0 version 1.16.3 from original version, which didnt fix anything.
gdb --args python3 script.py
gdb run
(gst-plugin-scanner:7308): GLib-GObject-WARNING **: 16:10:18.108: cannot register existing type 'GstVideoAggregator'
(gst-plugin-scanner:7308): GLib-GObject-CRITICAL **: 16:10:18.110: g_type_add_interface_static: assertion 'G_TYPE_IS_INSTANTIATABLE (instance_type)' failed
(gst-plugin-scanner:7308): GLib-CRITICAL **: 16:10:18.110: g_once_init_leave: assertion 'result != 0' failed
(gst-plugin-scanner:7308): GLib-GObject-CRITICAL **: 16:10:18.110: g_type_register_static: assertion 'parent_type > 0' failed
(gst-plugin-scanner:7308): GStreamer-CRITICAL **: 16:10:18.110: gst_element_register: assertion 'g_type_is_a (type, GST_TYPE_ELEMENT)' failed
Full Debug log
gst-inspect-1.0 -b
Blacklisted files:
  libgstnvcompositor.so
Total count: 1 blacklisted file
Source Code
import os
import sys
import time
import jetson.utils
import jetson.inference
from threading import Thread
from playsound import playsound
from PIL import Image,  ImageSequence
GIF_TIME = 3  # seconds
CLOSE_EYE_TIME = 3  # seconds
CAMERA_PATH = "/dev/video1"
DISPLAY_PATH = "display://0"
FILE_DIR = os.path.dirname(os.path.realpath(__file__))
MODEL_DIR = os.path.join(FILE_DIR, 'model')
AUDIO_DIR = os.path.join(FILE_DIR, 'audio')
GIF_DIR = os.path.join(FILE_DIR, 'gif')
output = jetson.utils.videoOutput(DISPLAY_PATH)
def play_alarm():
    playsound(os.path.join(AUDIO_DIR, "alarm.wav"), block=False)
class DrawGif(Thread):
    def __init__(self) -> None:
        super().__init__()
        self.counter = 0
        self.current_state = "default"
        self.states = {
            "default": self.get_frames("HappyDefault.png"),
            "smile": self.get_frames("smile.gif"),
            "mad": self.get_frames("mad.gif"),
    def set_state(self, state):
        self.current_state = state
        self.counter = 0
    def get_frames(self, gif):
        path = os.path.join(GIF_DIR, gif)
        frames = []
        seq = ImageSequence.Iterator(Image.open(path))
        for img in seq:
            frames.append(img)
        return frames
    def run(self):
        while True:
            if self.counter == len(self.states[self.current_state]):
                self.counter = 0
            try:
                output.Render(self.states[self.current_state][self.counter])
            except:
                self.counter = 0
            self.counter += 1
            time.sleep(20/1000)
gif_thread = DrawGif()
def main():
    net = jetson.inference.detectNet('googlenet', [
        '--model={}'.format(os.path.join(MODEL_DIR, 'ssd-mobilenet.onnx')),
        '--labels={}'.format(os.path.join(MODEL_DIR, 'labels.txt')),
        '--input-blob=input_0', '--output-cvg=scores', '--output-bbox=boxes'
    item = 0
    speed = 0.0
    camera = jetson.utils.videoSource(CAMERA_PATH)
fr
    info = jetson.utils.cudaFont()
    dt = time.time()
    close_state = False
    timer = time.time()
    try:
        while True:
            img = camera.Capture()
            detections = net.Detect(img)
            # Define new list items
            items = []
            for detection in detections:
                # turns ClassID into string
                item = net.GetClassDesc(detection.ClassID)
                # Add detected item to items list
                items.append(item)
                info.OverlayText(img, 5, 5, "speed:{:.2f}".format(speed), int(
                    detection.Left)+5, int(detection.Top)+35, info.White, info.Gray40)
            # If animation show for while
            if gif_thread.current_state != "default":
                if (time.time() - timer) > GIF_TIME:
                    gif_thread.set_state("default")
            if close_state:
                if (time.time() - dt) > CLOSE_EYE_TIME:
                    gif_thread.set_state("mad")
                    play_alarm()
            if "ClosedEyes" in items or "LookingDown" in items:
                if not close_state:
                    close_state = True
                    dt = time.time()
            elif "OpenEyes" in items:
                close_state = False
            elif "Phone" in items:
                timer = time.time()
                print("Wow really going on your phone huh")
            output.SetStatus(
                "Object Detection | Network {:.0f} FPS".format(
                    net.GetNetworkFPS()
            # print out performance info
            # net.PrintProfilerTimes()
    except KeyboardInterrupt:
        sys.exit(0)
    except Exception as e:
        print(e)
    finally:
        sys.exit(0)
if __name__ == '__main__':
    main_thread = Thread(target=main, args=())
    gif_thread.start()
    main_thread.start()
A possible solution is to rebuild nvcompositor plugin. Please refer to this post:
How to make videomix-plugin not block when one or more datasource stop? - #5 by DaneLLL
Does this mean I have to downgrade to Jetpack 4.5 to rebuild nvcompositor? I’m currently on 4.6.
The source code is public after Jetpack 4.5.1. Please download the package fitting the version.
