I had successfully installed NVIDIA drivers 410 on this computer before. After a power failure, my NVIDIA drivers were no longer properly (not detected). I purged and rebooted, then reinstalled the drivers. However, the drivers are still not found after installation.
The only error I get is:
Error! Bad return status for module build on kernel: 5.3.0-40-generic (x86_64)
Consult /var/lib/dkms/nvidia/410.104/build/make.log for more information.
In this file, there is in the beginning:
DKMS make.log for nvidia-410.104 for kernel 5.3.0-40-generic (x86_64)
Fr Feb 21 16:35:59 CET 2020
make[1]: Entering directory '/usr/src/linux-headers-5.3.0-40-generic'
test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( \
echo >&2; \
echo >&2 " ERROR: Kernel configuration is invalid."; \
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.";\
echo >&2 " Run 'make oldconfig && make prepare' on kernel src to fix it."; \
echo >&2 ; \
/bin/false)
make -f ./scripts/Makefile.build obj=/var/lib/dkms/nvidia/410.104/build need-modorder=1
ln -sf /var/lib/dkms/nvidia/410.104/build/nvidia/nv-kernel.o_binary /var/lib/dkms/nvidia/410.104/build/nvidia/nv-kernel.o
ln -sf /var/lib/dkms/nvidia/410.104/build/nvidia-modeset/nv-modeset-kernel.o_binary /var/lib/dkms/nvidia/410.104/build/nvidia-modeset/nv-modeset-kernel.o
{ echo /var/lib/dkms/nvidia/410.104/build/nvidia.ko; echo /var/lib/dkms/nvidia/410.104/build/nvidia-uvm.ko; echo /var/lib/dkms/nvidia/410.104/build/nvidia-modeset.ko; echo /var/lib/dkms/nvidia/410.104/build/nvidia-drm.ko; :; } \
| awk '!x[$0]++' - > /var/lib/dkms/nvidia/410.104/build/modules.order
And in the end:
scripts/Makefile.build:288: recipe for target '/var/lib/dkms/nvidia/410.104/build/nvidia/nv-chrdev.o' failed
make[2]: *** [/var/lib/dkms/nvidia/410.104/build/nvidia/nv-chrdev.o] Error 1
scripts/Makefile.build:288: recipe for target '/var/lib/dkms/nvidia/410.104/build/nvidia/nv-dma.o' failed
make[2]: *** [/var/lib/dkms/nvidia/410.104/build/nvidia/nv-dma.o] Error 1
scripts/Makefile.build:288: recipe for target '/var/lib/dkms/nvidia/410.104/build/nvidia/nv-i2c.o' failed
make[2]: *** [/var/lib/dkms/nvidia/410.104/build/nvidia/nv-i2c.o] Error 1
scripts/Makefile.build:288: recipe for target '/var/lib/dkms/nvidia/410.104/build/nvidia/nv-instance.o' failed
make[2]: *** [/var/lib/dkms/nvidia/410.104/build/nvidia/nv-instance.o] Error 1
scripts/Makefile.build:288: recipe for target '/var/lib/dkms/nvidia/410.104/build/nvidia/nv-acpi.o' failed
make[2]: *** [/var/lib/dkms/nvidia/410.104/build/nvidia/nv-acpi.o] Error 1
scripts/Makefile.build:288: recipe for target '/var/lib/dkms/nvidia/410.104/build/nvidia/nv-frontend.o' failed
make[2]: *** [/var/lib/dkms/nvidia/410.104/build/nvidia/nv-frontend.o] Error 1
scripts/Makefile.build:288: recipe for target '/var/lib/dkms/nvidia/410.104/build/nvidia/nv-gvi.o' failed
make[2]: *** [/var/lib/dkms/nvidia/410.104/build/nvidia/nv-gvi.o] Error 1
scripts/Makefile.build:288: recipe for target '/var/lib/dkms/nvidia/410.104/build/nvidia/nv-pat.o' failed
make[2]: *** [/var/lib/dkms/nvidia/410.104/build/nvidia/nv-pat.o] Error 1
scripts/Makefile.build:288: recipe for target '/var/lib/dkms/nvidia/410.104/build/nvidia/nv-vm.o' failed
make[2]: *** [/var/lib/dkms/nvidia/410.104/build/nvidia/nv-vm.o] Error 1
scripts/Makefile.build:288: recipe for target '/var/lib/dkms/nvidia/410.104/build/nvidia/nv.o' failed
make[2]: *** [/var/lib/dkms/nvidia/410.104/build/nvidia/nv.o] Error 1
scripts/Makefile.build:288: recipe for target '/var/lib/dkms/nvidia/410.104/build/nvidia/nv-usermap.o' failed
make[2]: *** [/var/lib/dkms/nvidia/410.104/build/nvidia/nv-usermap.o] Error 1
scripts/Makefile.build:288: recipe for target '/var/lib/dkms/nvidia/410.104/build/nvidia/nv-p2p.o' failed
make[2]: *** [/var/lib/dkms/nvidia/410.104/build/nvidia/nv-p2p.o] Error 1
Makefile:1655: recipe for target '_module_/var/lib/dkms/nvidia/410.104/build' failed
make[1]: *** [_module_/var/lib/dkms/nvidia/410.104/build] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-5.3.0-40-generic'
Makefile:79: recipe for target 'modules' failed
make: *** [modules] Error 2
install_nvidia.log (10.7 KB)
nvidia-bug-report.log.gz (72.1 KB)
dkms_make.log (61.1 KB)
