Cannot run Gaze Demo
Jetson Orin 4012, NVIDIA Jetson Orin NX Bundle, 8x 2GHz, 16GB DDR5
• DeepStream Version
Container: deepstream:7.1-triton-multiarch
see Container: deepstream:7.1-triton-multiarch
• TensorRT Version
Bug/Crash
$ sudo docker pull nvcr.io/nvidia/jetson-gaze:r32.4.2
$ sudo xhost +si:localuser:root
$ sudo docker ru --runtime nvidia -it --rm --network host -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/jetson-gaze:r32.4.2 python3 run_gaze_sequential.py /videos/gaze_video.mp4 --loop --codec=h264
I also tried running the Gaze Demo found at Gaze Demo for Jetson/L4T | NVIDIA NGC , but ran into the above issue.
The description says “Note that the gaze demo currently has TensorRT engine files built for Jetson AGX Xavier and Jetson Xavier NX and hence this demo can be run on Jetson AGX Xavier or Jetson Xavier NX only.” - is this the reason for the crash? And is it possible for me to somehow build the needed TensorRT engine files for my system (being the Jetson Orin 4012) and if so, could you hint me to some documentation/tutorials for it?
Thank you in advance!
Yes, the container is built with r32 BSP which is not available for the Orin series.
Alright, thanks!
Is there another demo for running the GazeNet available somewhere?
Can i somehow rebuild the needed model engine files for the Orin 4012?
You can find the model in the TAO toolkit:
https://docs.nvidia.com/tao/tao-toolkit/text/trtexec_integration/index.html
