Cannot run inference server on Jetson nano
Hi All,
I have tried to build Roboflow inference server in jetson nano following this
https://wiki.seeedstudio.com/Roboflow-Jetson-Getting-Started/
(Local Docker Build Method)
after I cloned a project and try to run
docker run --privileged --net=host --runtime=nvidia roboflow/roboflow-inference-server-jetson-5.1.1:seeed1
then I got
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #1: error running hook: exit status 1, stdout: , stderr: time="2024-12-12T16:08:32+07:00" level=info msg="Symlinking /var/lib/docker/overlay2/d7ea998d2ef1fd099474e8bf75ae040fc7da4f16f777b518364bb0cbda0030b9/merged/usr/lib/aarch64-linux-gnu/tegra/libcuda.so to libcuda.so.1.1"
time="2024-12-12T16:08:32+07:00" level=info msg="Symlinking /var/lib/docker/overlay2/d7ea998d2ef1fd099474e8bf75ae040fc7da4f16f777b518364bb0cbda0030b9/merged/usr/lib/aarch64-linux-gnu/tegra/libgstnvcustomhelper.so to libgstnvcustomhelper.so.1.0.0"
time="2024-12-12T16:08:32+07:00" level=info msg="Symlinking /var/lib/docker/overlay2/d7ea998d2ef1fd099474e8bf75ae040fc7da4f16f777b518364bb0cbda0030b9/merged/usr/lib/aarch64-linux-gnu/tegra/libnvidia-kms.so to libnvidia-kms.so.35.4.1"
time="2024-12-12T16:08:32+07:00" level=info msg="Symlinking /var/lib/docker/overlay2/d7ea998d2ef1fd099474e8bf75ae040fc7da4f16f777b518364bb0cbda0030b9/merged/usr/lib/aarch64-linux-gnu/tegra/libnvidia-nvvm.so.4 to libnvidia-nvvm.so.35.4.1"
time="2024-12-12T16:08:32+07:00" level=info msg="Symlinking /var/lib/docker/overlay2/d7ea998d2ef1fd099474e8bf75ae040fc7da4f16f777b518364bb0cbda0030b9/merged/usr/lib/aarch64-linux-gnu/tegra/libnvidia-ptxjitcompiler.so.1 to libnvidia-ptxjitcompiler.so.35.4.1"
time="2024-12-12T16:08:32+07:00" level=info msg="Symlinking /var/lib/docker/overlay2/d7ea998d2ef1fd099474e8bf75ae040fc7da4f16f777b518364bb0cbda0030b9/merged/usr/lib/aarch64-linux-gnu/tegra/libnvidia-vksc-core.so to libnvidia-vksc-core.so.35.4.1"
time="2024-12-12T16:08:32+07:00" level=info msg="Symlinking /var/lib/docker/overlay2/d7ea998d2ef1fd099474e8bf75ae040fc7da4f16f777b518364bb0cbda0030b9/merged/usr/share/glvnd/egl_vendor.d/10_nvidia.json to ../../../lib/aarch64-linux-gnu/tegra-egl/nvidia.json"
time="2024-12-12T16:08:32+07:00" level=error msg="failed to create link [../../../lib/aarch64-linux-gnu/tegra-egl/nvidia.json /usr/share/glvnd/egl_vendor.d/10_nvidia.json]: failed to create symlink: failed to remove existing file: remove /var/lib/docker/overlay2/d7ea998d2ef1fd099474e8bf75ae040fc7da4f16f777b518364bb0cbda0030b9/merged/usr/share/glvnd/egl_vendor.d/10_nvidia.json: device or resource busy": unknown.
ERRO[0000] error waiting for container:
I am not sure what is missing for NVIDIA container or docker.
Please advise me how to resolve it.
Thank you in advance.
Could you try to run it with sudo docker run ...?
