Cannot run Lidar and multiple realsense
Looking at file nvblox_examples/nvblox_examples_bringup/launch/perception/nvblox.launch.py one can see that is not possible to run nvblox with a Lidar and realsense cameras (event a single one!)
  1. Why is that so?
  2. What are the limitations?
  3. Is any future update gonna solve this issue?
I am working with a spot robot (5 onboard cameras) + a Lidar mounted on it and would like to use nvblox.
Any help would be greatly appreciated!
Hello @JeanLesur,
The example of LiDAR + cameras is currently only wired in the Isaac Sim path (get_isaac_sim_remappings(..., lidar) adds the /front_3d_lidar/point_cloud remap when lidar=True).
Please treat nvblox.launch.py as an example, not a hard limit. You can create a custom launch file in your own package that:
  • Imports ComposableNode and constructs nvblox::NvbloxNode exactly like add_nvblox()
  • Includes these parameters:
    • config/nvblox/nvblox_base.yaml
    • A mode specialization (nvblox_dynamics.yaml or your own)
    • A camera+LiDAR specialization YAML you define for Spot (extrinsics, sensor settings){'num_cameras': 5}, {'use_lidar': True}
For reference, the implementation of Nvblox with LiDAR can be found in the OS1 example.
thank for the answer, i will look into it!
I could however see that 5 cameras are not supported:
[INFO] [launch]: All log files can be found below /root/.ros/log/2026-02-05-09-31-19-527106-jean-asus-m16-5517
[INFO] [launch]: Default logging verbosity is set to INFO
Using container type: component_container_isolated, with arguments: ['--ros-args', '--log-level', <launch.substitutions.launch_configuration.LaunchConfiguration object at 0x7d4797298830>]
[INFO] [launch.user]: Adding nodes [ /nvblox_node ] to container nvblox_container.
[INFO] [component_container_isolated-1]: process started with pid [5533]
[INFO] [rviz2-2]: process started with pid [5534]
[rviz2-2] QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
[component_container_isolated-1] [INFO] [1770283880.022482952] [nvblox_container]: Load Library: /opt/ros/jazzy/lib/libnvblox_ros_lib.so
[component_container_isolated-1] [INFO] [1770283880.093201780] [nvblox_container]: Found class: rclcpp_components::NodeFactoryTemplate<nvblox::NvbloxNode>
[component_container_isolated-1] [INFO] [1770283880.093302202] [nvblox_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvblox::NvbloxNode>
[component_container_isolated-1] WARNING: Logging before InitGoogleLogging() is written to STDERR
[component_container_isolated-1] F20260205 09:31:20.305202  5533 nvblox_node.cpp:79] Check failed: params_.num_cameras <= kMaxNumCameras (5 vs. 4)
[component_container_isolated-1] *** Check failure stack trace: ***
[ERROR] [component_container_isolated-1]: process has died [pid 5533, exit code -6, cmd '/opt/ros/jazzy/lib/rclcpp_components/component_container_isolated --ros-args --log-level info --ros-args -r __node:=nvblox_container -p use_sim_time:=True'].
[INFO] [launch]: process[component_container_isolated-1] was required: shutting down launched system
[INFO] [rviz2-2]: sending signal 'SIGINT' to process[rviz2-2]
As there haven’t been any recent updates on this discussion, we’ll be closing the thread to keep the forum organized.
If you continue to experience this issue or have new questions, please start a new topic and include a reference to this discussion for context. This will help our team and other community members assist you more effectively.
Thank you for your participation in the NVIDIA Isaac ROS community.
