Cannot run navigation_rosbridge - can't find library
I’m trying to develop my own ros bridge and started by testing the provided example, but I cannot get it to run.
The command I run is:
bazel run //apps/samples/navigation_rosbridge
However, I get an error saying it cannot find libnavigation_ros_bridge_module.so (full error message below).
The application is looking for the library here:
~/.cache/bazel/_bazel_jjachnik/d190ff169d6b5f6f0b257376fad7b091/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/apps/samples/navigation_rosbridge/navigation_rosbridge.runfiles/com_nvidia_isaac//external/com_nvidia_isaac/apps/samples/navigation_rosbridge/libnavigation_ros_bridge_module.so
but the file actually exists here:
~/.cache/bazel/_bazel_jjachnik/d190ff169d6b5f6f0b257376fad7b091/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/apps/samples/navigation_rosbridge/navigation_rosbridge.runfiles/com_nvidia_isaac/apps/samples/navigation_rosbridge/libnavigation_ros_bridge_module.so
Notice the path where it is looking for the library has an extra “//external/com_nvidia_isaac” in the middle which breaks it.
Any ideas how to fix this?
Full error output:
❯ bazel run //apps/samples/navigation_rosbridge
INFO: Analysed target //apps/samples/navigation_rosbridge:navigation_rosbridge (0 packages loaded, 0 targets configured).
INFO: Found 1 target...
Target //apps/samples/navigation_rosbridge:navigation_rosbridge up-to-date:
  bazel-genfiles/apps/samples/navigation_rosbridge/run_navigation_rosbridge
  bazel-bin/apps/samples/navigation_rosbridge/navigation_rosbridge
INFO: Elapsed time: 0.187s, Critical Path: 0.00s, Remote (0.00% of the time): [queue: 0.00%, setup: 0.00%, process: 0.00%]
INFO: 0 processes.
INFO: Build completed successfully, 1 total action
2019-11-14 10:22:42.851 INFO    engine/alice/tools/websight.cpp@166: Loading websight...
2019-11-14 10:22:42.851 WARNING engine/alice/backend/application_json_loader.cpp@98: This application does not have an explicit scheduler configuration. One will be autogenerated to the best of the system's abilities if possible.
2019-11-14 10:22:42.851 WARNING engine/alice/backend/backend.cpp@168: This application does not have an execution group configuration. One will be autogenerated to the best of the systems abilities if possible.
2019-11-14 10:22:42.851 WARNING engine/gems/scheduler/scheduler.cpp@337: No default execution groups specified. Attempting to create scheduler configuration for 12 remaining cores. This may be non optimal for the system and application.
2019-11-14 10:22:42.851 INFO    engine/gems/scheduler/scheduler.cpp@290: Scheduler execution groups are:
2019-11-14 10:22:42.851 INFO    engine/gems/scheduler/scheduler.cpp@299: __BlockerGroup__: Cores = [9, 10, 11], Workers = No
2019-11-14 10:22:42.851 INFO    engine/gems/scheduler/scheduler.cpp@299: __WorkerGroup__: Cores = [0, 1, 2, 3, 4, 5, 6, 7, 8], Workers = Yes
2019-11-14 10:22:42.855 INFO    engine/alice/backend/modules.cpp@283: Loaded module 'packages/sight/libsight_module.so': Now has 41 components total
2019-11-14 10:22:42.856 ERROR   engine/alice/backend/modules.cpp@307: //apps/samples/navigation_rosbridge:navigation_ros_bridge: /home/jjachnik/.cache/bazel/_bazel_jjachnik/d190ff169d6b5f6f0b257376fad7b091/execroot/com_nvidia_isaac/bazel-out/k8-opt/bin/apps/samples/navigation_rosbridge/navigation_rosbridge.runfiles/com_nvidia_isaac//external/com_nvidia_isaac/apps/samples/navigation_rosbridge/libnavigation_ros_bridge_module.so: cannot open shared object file: No such file or directory
2019-11-14 10:22:42.856 PANIC   engine/alice/backend/modules.cpp@309: Could not load all required modules for application
|                            Isaac application terminated unexpectedly                             |
#01 engine/alice/tools/main(+0x8046a) [0x5573c32ba46a]
#02 engine/alice/tools/main(+0xe86d0) [0x5573c33226d0]
#03 engine/alice/tools/main(+0xe8a40) [0x5573c3322a40]
#04 /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7fb39042b890]
#05 /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7fb38fac5e97]
#06 /lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7fb38fac7801]
#07 engine/alice/tools/main(+0x9d1f7) [0x5573c32d71f7]
#08 engine/alice/tools/main(+0x34bdc) [0x5573c326ebdc]
#09 engine/alice/tools/main(+0x350f3) [0x5573c326f0f3]
#10 engine/alice/tools/main(+0x352e4) [0x5573c326f2e4]
#11 engine/alice/tools/main(+0x15c23) [0x5573c324fc23]
#12 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7fb38faa8b97]
#13 engine/alice/tools/main(+0x1af7a) [0x5573c3254f7a]
Minidump written to: /tmp/d6b32e1c-2c78-4acc-42f0dd87-f44a115e.dmp
Aborted
Pardon the delay, Jan. Were you able to solve it? Or is it still lingering?
@shrinv
we are getting the same issue
running from Host PC
~/dev/sdk$ bazel run //apps/samples/navigation_rosbridge
results in
 module 'packages/sight/libsight_module.so': Now has 31 components total
2021-02-22 16:47:07.533 ERROR external/com_nvidia_isaac_engine/engine/alice/backend/modules.cpp@295: apps/samples/navigation_rosbridge/libnavigation_ros_bridge_module.so: librosconsole_log4cxx.so: cannot open shared object file: No such file or directory
2021-02-22 16:47:07.533 PANIC external/com_nvidia_isaac_engine/engine/alice/backend/modules.cpp@297: Could not load all required modules for application
#01 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0x6cc1a) [0x55ddc7f20c1a]
#02 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0xe3e80) [0x55ddc7f97e80]
#03 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0xe41f0) [0x55ddc7f981f0]
#04 /lib/x86_64-linux-gnu/libpthread.so.0(+0x12980) [0x7f47278f1980]
#05 /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7f4726f8bfb7]
#06 /lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7f4726f8d921]
#07 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0x7810e) [0x55ddc7f2c10e]
#08 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0x315a7) [0x55ddc7ee55a7]
#09 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0x33a69) [0x55ddc7ee7a69]
#10 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0x33dbf) [0x55ddc7ee7dbf]
#11 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0x12873) [0x55ddc7ec6873]
#12 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f4726f6ebf7]
#13 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0x17eca) [0x55ddc7ecbeca]
Minidump written to: /tmp/c440d94e-d1e4-49ec-0c69e5ad-dd43e735.dmp
after installing
sudo apt install librosconsole-dev
sudo apt install libxmlrpcpp
it will just fail with Segfault on execution
any ideas?
version of sdk 2020.2
