Cannot run onnxruntime inference
Hello ,
I can’t run my script od onnxrumtime inference and get ““illegal instruction (core dumped”” error , this is my code
import onnxruntime as ort
import time
import librosa
import kaldi_native_fbank as knf
import numpy as np
import mutagen
from mutagen.wave import WAVE
def compute_feat(filename):
sample_rate = 16000
samples, _ = librosa.load(filename, sr=sample_rate)
opts = knf.FbankOptions()
opts.frame_opts.dither = 0
opts.frame_opts.snip_edges = False
opts.frame_opts.samp_freq = sample_rate
opts.mel_opts.num_bins = 80
online_fbank = knf.OnlineFbank(opts)
online_fbank.accept_waveform(sample_rate, (samples * 32768).tolist())
online_fbank.input_finished()
features = np.stack(
    [online_fbank.get_frame(i) for i in range(online_fbank.num_frames_ready)]
assert features.data.contiguous is True
assert features.dtype == np.float32, features.dtype
mean = features.mean(axis=0, keepdims=True)
stddev = features.std(axis=0, keepdims=True)
features = (features - mean) / (stddev + 1e-5)
return features
def audio_duration(length):
hours = length // 3600 # calculate in hours
length %= 3600
mins = length // 60 # calculate in minutes
length %= 60
seconds = length # calculate in seconds
total_duration = hours * 3600 + mins * 60 + seconds
return float(total_duration)
def main():
filename = “citrinet/sample1.wav”
audio_filepath = filename
#Create a wave object of the audio file
audio = WAVE(audio_filepath)
# contains all the metadata about the wavpack file
audio_info = audio.info
length = int(audio_info.length)
res = audio_duration(length)
#get features of the filename
features = compute_feat(filename)  # (T, C)
features = np.expand_dims(features, axis=0)  # (N, T, C)
features = features.transpose(0, 2, 1)  # (N, C, T)
features_length = np.array([features.shape[2]], dtype=np.int64)
onnx_model_path = "ctc/ctc_rnnt.onnx"
session = ort.InferenceSession(onnx_model_path)
res = session.run(None, {
   'input_ids': inputs['input_ids'].cpu().numpy(),
   'input_mask': inputs['attention_mask'].cpu().numpy(),
   'segment_ids': inputs['token_type_ids'].cpu().numpy()
# evaluate the model
start = time.time()
inputs = {
    session.get_inputs()[0].name: features,
    session.get_inputs()[1].name: features_length,
outputs = session.run([session.get_outputs()[0].name], input_feed=inputs)
end = time.time()
onnxtime=round(end - start, 4)
print("File duration: ", res)
print("ONNX Runtime inference time: ", onnxtime)
rtf=onnxtime/res
print("RTF =" ,rtf)
if name == ‘main’:
main()
Hi @mohandhassan91
Thanks for your interest in Riva,
Apologies, quick check, is the problem related to Riva
can you share details about the Riva Model you are using,
If this is Nemo related query, please let me know
