I’m trying to run the Riva ASR service with the Mandarin Chinese (zh-CN) model on my Jetson Nano Super Developer Kit (8GB). The service fails to start, but it works correctly under these other conditions:
- English (
en-US) ASR on the Jetson Nano Super Developer Kit. - Chinese (
zh-CN) ASR on a Jetson AGX Orin with 64GB of memory.
The issue seems to be specific to running the zh-CN model on the Jetson Nano Super. My main question is: Is there a way to successfully run the Riva zh-CN ASR model on the Jetson Nano Super, or is this hardware not supported for this specific model?
Detailed Information
Hardware
- GPU: Jetson Nano Super developer kit (8GB)
- CPU: Jetson Nano Super developer kit (8GB)
- Operating System: Ubuntu 22.04.5 LTS + Jetpack 6.2
Software
- Riva Version: 2.19.0
Steps to Reproduce I followed the standard Riva deployment process, with the following modifications to config.sh:
- Set
service_enabled_asr=true - Set
service_enabled_nlp=false - Set
service_enabled_tts=false - Set
service_enabled_nmt=false - Set
asr_language_code=("zh-CN")
After these changes, I ran the following commands:
bash ./riva_clean.sh
bash ./riva_init.sh
bash ./riva_start.sh
Observed Behavior The server gets stuck at the “Waiting for Riva server to load all models…retrying in 10 seconds” message and eventually times out.
The docker logs riva-speech output shows a clear failure to load one of the models: riva-trt-riva-punctuation-zh-CN-nn-bert-base-chinese. The error message is:
I0806 17:48:53.308918 22 tensorrt.cc:353] "TRITONBACKEND_ModelInstanceFinalize: delete instance state"
E0806 17:48:53.309015 22 backend_model.cc:692] "ERROR: Failed to create instance: unable to create TensorRT context: ICudaEngine::createExecutionContext: Error Code 1: Myelin ([cask_fusion.cpp:initialize_cask_fusion:381] Cask unknown internal error)"
I0806 17:48:53.309044 22 tensorrt.cc:274] "TRITONBACKEND_ModelFinalize: delete model state"
E0806 17:48:53.309432 22 model_lifecycle.cc:642] "failed to load 'riva-trt-riva-punctuation-zh-CN-nn-bert-base-chinese' version 1: Internal: unable to create TensorRT context: ICudaEngine::createExecutionContext: Error Code 1: Myelin ([cask_fusion.cpp:initialize_cask_fusion:381] Cask unknown internal error)"
I0806 17:48:53.309469 22 model_lifecycle.cc:777] "failed to load 'riva-trt-riva-punctuation-zh-CN-nn-bert-base-chinese'"
The following is the full log:
> Riva waiting for Triton server to load all models...retrying in 1 second
I0806 17:48:51.325719 22 pinned_memory_manager.cc:277] "Pinned memory pool is created at '0x2040ae000' with size 268435456"
I0806 17:48:51.326250 22 cuda_memory_manager.cc:107] "CUDA memory pool is created on device 0 with size 1000000000"
I0806 17:48:51.615222 22 model_lifecycle.cc:472] "loading: riva-trt-conformer-zh-CN-asr-streaming-am-streaming:1"
I0806 17:48:51.615352 22 model_lifecycle.cc:472] "loading: riva-punctuation-zh-CN:1"
I0806 17:48:51.615448 22 model_lifecycle.cc:472] "loading: conformer-zh-CN-asr-streaming-asr-bls-ensemble:1"
I0806 17:48:51.615505 22 model_lifecycle.cc:472] "loading: riva-trt-riva-punctuation-zh-CN-nn-bert-base-chinese:1"
I0806 17:48:51.746274 22 tensorrt.cc:65] "TRITONBACKEND_Initialize: tensorrt"
I0806 17:48:51.746342 22 tensorrt.cc:75] "Triton TRITONBACKEND API version: 1.19"
I0806 17:48:51.746353 22 tensorrt.cc:81] "'tensorrt' TRITONBACKEND API version: 1.19"
I0806 17:48:51.746361 22 tensorrt.cc:105] "backend configuration:\n{\"cmdline\":{\"auto-complete-config\":\"false\",\"backend-directory\":\"/opt/tritonserver/backends\",\"min-compute-capability\":\"5.300000\",\"default-max-batch-size\":\"4\"}}"
I0806 17:48:51.747310 22 tensorrt.cc:231] "TRITONBACKEND_ModelInitialize: riva-trt-riva-punctuation-zh-CN-nn-bert-base-chinese (version 1)"
I0806 17:48:51.747311 22 tensorrt.cc:231] "TRITONBACKEND_ModelInitialize: riva-trt-conformer-zh-CN-asr-streaming-am-streaming (version 1)"
I0806 17:48:51.750005 22 tensorrt.cc:297] "TRITONBACKEND_ModelInstanceInitialize: riva-trt-conformer-zh-CN-asr-streaming-am-streaming_0_0 (GPU device 0)"
I0806 17:48:51.750056 22 tensorrt.cc:297] "TRITONBACKEND_ModelInstanceInitialize: riva-trt-riva-punctuation-zh-CN-nn-bert-base-chinese_0_0 (GPU device 0)"
I0806 17:48:52.619515 22 pipeline_library.cc:24] "TRITONBACKEND_ModelInitialize: riva-punctuation-zh-CN (version 1)"
I0806 17:48:52.621124 22 backend_model.cc:303] "model configuration:\n{\n \"name\": \"riva-punctuation-zh-CN\",\n \"platform\": \"\",\n \"backend\": \"riva_nlp_pipeline\",\n \"runtime\": \"\",\n \"version_policy\": {\n \"latest\": {\n \"num_versions\": 1\n }\n },\n \"max_batch_size\": 1,\n \"input\": [\n {\n \"name\": \"PIPELINE_INPUT\",\n \"data_type\": \"TYPE_STRING\",\n \"format\": \"FORMAT_NONE\",\n \"dims\": [\n 1\n ],\n \"is_shape_tensor\": false,\n \"allow_ragged_batch\": false,\n \"optional\": false,\n \"is_non_linear_format_io\": false\n }\n ],\n \"output\": [\n {\n \"name\": \"PIPELINE_OUTPUT\",\n \"data_type\": \"TYPE_STRING\",\n \"dims\": [\n 1\n ],\n \"label_filename\": \"\",\n \"is_shape_tensor\": false,\n \"is_non_linear_format_io\": false\n }\n ],\n \"batch_input\": [],\n \"batch_output\": [],\n \"optimization\": {\n \"priority\": \"PRIORITY_DEFAULT\",\n \"input_pinned_memory\": {\n \"enable\": true\n },\n \"output_pinned_memory\": {\n \"enable\": true\n },\n \"gather_kernel_buffer_threshold\": 0,\n \"eager_batching\": false\n },\n \"instance_group\": [\n {\n \"name\": \"riva-punctuation-zh-CN_0\",\n \"kind\": \"KIND_CPU\",\n \"count\": 1,\n \"gpus\": [],\n \"secondary_devices\": [],\n \"profile\": [],\n \"passive\": false,\n \"host_policy\": \"\"\n }\n ],\n \"default_model_filename\": \"\",\n \"cc_model_filenames\": {},\n \"metric_tags\": {},\n \"parameters\": {\n \"unk_token\": {\n \"string_value\": \"[UNK]\"\n },\n \"model_api\": {\n \"string_value\": \"PunctuateText\"\n },\n \"input_ids_tensor_name\": {\n \"string_value\": \"input_ids\"\n },\n \"to_lower\": {\n \"string_value\": \"true\"\n },\n \"capit_logits_tensor_name\": {\n \"string_value\": \"capit_logits\"\n },\n \"attn_mask_tensor_name\": {\n \"string_value\": \"attention_mask\"\n },\n \"tokenizer_to_lower\": {\n \"string_value\": \"true\"\n },\n \"model_name\": {\n \"string_value\": \"riva-trt-riva-punctuation-zh-CN-nn-bert-base-chinese\"\n },\n \"preserve_accents\": {\n \"string_value\": \"false\"\n },\n \"token_type_tensor_name\": {\n \"string_value\": \"token_type_ids\"\n },\n \"use_int64_nn_inputs\": {\n \"string_value\": \"False\"\n },\n \"bos_token\": {\n \"string_value\": \"[CLS]\"\n },\n \"delimiter\": {\n \"string_value\": \".\"\n },\n \"pipeline_type\": {\n \"string_value\": \"punctuation\"\n },\n \"code_point_filename\": {\n \"string_value\": \"cp_data.json\"\n },\n \"capitalization_mapping_path\": {\n \"string_value\": \"e97f0158fc914bf4ba333243227d9daf_capit_labels.txt\"\n },\n \"language_code\": {\n \"string_value\": \"zh-CN\"\n },\n \"unicode_normalize\": {\n \"string_value\": \"False\"\n },\n \"punctuation_mapping_path\": {\n \"string_value\": \"9c726721aad54c6b981ef0d51b7fa200_punct_labels.txt\"\n },\n \"load_model\": {\n \"string_value\": \"false\"\n },\n \"remove_spaces\": {\n \"string_value\": \"True\"\n },\n \"tokenizer\": {\n \"string_value\": \"wordpiece\"\n },\n \"vocab\": {\n \"string_value\": \"83e30d7b3628459c8b25043dbc1b59de_vocab.txt\"\n },\n \"pad_chars_with_spaces\": {\n \"string_value\": \"True\"\n },\n \"eos_token\": {\n \"string_value\": \"[SEP]\"\n },\n \"model_family\": {\n \"string_value\": \"riva\"\n },\n \"punct_logits_tensor_name\": {\n \"string_value\": \"punct_logits\"\n }\n },\n \"model_warmup\": []\n}"
I0806 17:48:52.621410 22 pipeline_library.cc:28] "TRITONBACKEND_ModelInstanceInitialize: riva-punctuation-zh-CN_0_0 (device 0)"
I0806 17:48:52.693967 22 pipeline_library.cc:22] "TRITONBACKEND_ModelInitialize: conformer-zh-CN-asr-streaming-asr-bls-ensemble (version 1)"
Found yaml file: /data/models/conformer-zh-CN-asr-streaming-asr-bls-ensemble/1/riva_bls_config.yaml
I0806 17:48:52.766380 22 backend_model.cc:303] "model configuration:\n{\n \"name\": \"conformer-zh-CN-asr-streaming-asr-bls-ensemble\",\n \"platform\": \"\",\n \"backend\": \"riva_asr_ensemble_pipeline\",\n \"runtime\": \"\",\n \"version_policy\": {\n \"latest\": {\n \"num_versions\": 1\n }\n },\n \"max_batch_size\": 1024,\n \"input\": [\n {\n \"name\": \"PIPELINE_INPUT\",\n \"data_type\": \"TYPE_STRING\",\n \"format\": \"FORMAT_NONE\",\n \"dims\": [\n 1\n ],\n \"is_shape_tensor\": false,\n \"allow_ragged_batch\": false,\n \"optional\": false,\n \"is_non_linear_format_io\": false\n }\n ],\n \"output\": [\n {\n \"name\": \"PIPELINE_OUTPUT\",\n \"data_type\": \"TYPE_STRING\",\n \"dims\": [\n 1\n ],\n \"label_filename\": \"\",\n \"is_shape_tensor\": false,\n \"is_non_linear_format_io\": false\n }\n ],\n \"batch_input\": [],\n \"batch_output\": [],\n \"optimization\": {\n \"graph\": {\n \"level\": 0\n },\n \"priority\": \"PRIORITY_DEFAULT\",\n \"cuda\": {\n \"graphs\": false,\n \"busy_wait_events\": false,\n \"graph_spec\": [],\n \"output_copy_stream\": true\n },\n \"input_pinned_memory\": {\n \"enable\": true\n },\n \"output_pinned_memory\": {\n \"enable\": true\n },\n \"gather_kernel_buffer_threshold\": 0,\n \"eager_batching\": false\n },\n \"sequence_batching\": {\n \"oldest\": {\n \"max_candidate_sequences\": 1024,\n \"preferred_batch_size\": [\n 64,\n 128\n ],\n \"max_queue_delay_microseconds\": 1000,\n \"preserve_ordering\": false\n },\n \"max_sequence_idle_microseconds\": 60000000,\n \"control_input\": [\n {\n \"name\": \"START\",\n \"control\": [\n {\n \"kind\": \"CONTROL_SEQUENCE_START\",\n \"int32_false_true\": [\n 0,\n 1\n ],\n \"fp32_false_true\": [],\n \"bool_false_true\": [],\n \"data_type\": \"TYPE_INVALID\"\n }\n ]\n },\n {\n \"name\": \"READY\",\n \"control\": [\n {\n \"kind\": \"CONTROL_SEQUENCE_READY\",\n \"int32_false_true\": [\n 0,\n 1\n ],\n \"fp32_false_true\": [],\n \"bool_false_true\": [],\n \"data_type\": \"TYPE_INVALID\"\n }\n ]\n },\n {\n \"name\": \"END\",\n \"control\": [\n {\n \"kind\": \"CONTROL_SEQUENCE_END\",\n \"int32_false_true\": [\n 0,\n 1\n ],\n \"fp32_false_true\": [],\n \"bool_false_true\": [],\n \"data_type\": \"TYPE_INVALID\"\n }\n ]\n },\n {\n \"name\": \"CORRID\",\n \"control\": [\n {\n \"kind\": \"CONTROL_SEQUENCE_CORRID\",\n \"int32_false_true\": [],\n \"fp32_false_true\": [],\n \"bool_false_true\": [],\n \"data_type\": \"TYPE_UINT64\"\n }\n ]\n }\n ],\n \"state\": [],\n \"iterative_sequence\": false\n },\n \"instance_group\": [\n {\n \"name\": \"conformer-zh-CN-asr-streaming-asr-bls-ensemble_0\",\n \"kind\": \"KIND_CPU\",\n \"count\": 1,\n \"gpus\": [],\n \"secondary_devices\": [],\n \"profile\": [],\n \"passive\": false,\n \"host_policy\": \"\"\n }\n ],\n \"default_model_filename\": \"\",\n \"cc_model_filenames\": {},\n \"metric_tags\": {},\n \"parameters\": {\n \"offline\": {\n \"string_value\": \"False\"\n },\n \"type\": {\n \"string_value\": \"online\"\n },\n \"yaml_parameters_file\": {\n \"string_value\": \"riva_bls_config.yaml\"\n },\n \"sample_rate\": {\n \"string_value\": \"16000\"\n },\n \"streaming\": {\n \"string_value\": \"True\"\n },\n \"model_family\": {\n \"string_value\": \"riva\"\n },\n \"language_code\": {\n \"string_value\": \"zh-CN\"\n }\n },\n \"model_warmup\": [],\n \"model_transaction_policy\": {\n \"decoupled\": true\n }\n}"
I0806 17:48:52.767045 22 pipeline_library.cc:26] "TRITONBACKEND_ModelInstanceInitialize: conformer-zh-CN-asr-streaming-asr-bls-ensemble_0_0 (device 0)"
I0806 17:48:52.951743 22 logging.cc:46] "Loaded engine size: 196 MiB"
W0806 17:48:52.992229 22 logging.cc:43] "Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors."
I0806 17:48:53.058156 22 model_lifecycle.cc:839] "successfully loaded 'riva-punctuation-zh-CN'"
I0806 17:48:53.144200 22 logging.cc:46] "The logger passed into createInferRuntime differs from one already provided for an existing builder, runtime, or refitter. Uses of the global logger, returned by nvinfer1::getLogger(), will return the existing value."
E0806 17:48:53.308815 22 logging.cc:40] "ICudaEngine::createExecutionContext: Error Code 1: Myelin ([cask_fusion.cpp:initialize_cask_fusion:381] Cask unknown internal error)"
I0806 17:48:53.513776 22 logging.cc:46] "Loaded engine size: 253 MiB"
W0806 17:48:53.513925 22 logging.cc:43] "Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors."
I0806 17:48:53.702196 22 logging.cc:46] "[MS] Running engine with multi stream info"
I0806 17:48:53.702268 22 logging.cc:46] "[MS] Number of aux streams is 1"
I0806 17:48:53.702277 22 logging.cc:46] "[MS] Number of total worker streams is 2"
I0806 17:48:53.702285 22 logging.cc:46] "[MS] The main stream provided by execute/enqueue calls is the first worker stream"
I0806 17:48:54.348510 22 logging.cc:46] "[MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +10, now: CPU 0, GPU 442 (MiB)"
I0806 17:48:54.353520 22 instance_state.cc:186] "Created instance riva-trt-conformer-zh-CN-asr-streaming-am-streaming_0_0 on GPU 0 with stream priority 0 and optimization profile default[0];"
I0806 17:48:54.353937 22 model_lifecycle.cc:839] "successfully loaded 'riva-trt-conformer-zh-CN-asr-streaming-am-streaming'"
WARNING: Logging before InitGoogleLogging() is written to STDERR
I0806 17:48:56.826931 41 asr_ensemble_factory.cc:278] Loading acoustic model
I0806 17:48:56.827013 41 asr_ensemble_factory.cc:284] Done loading acoustic model
I0806 17:48:56.831712 41 normalizer.cc:66] Proto String: tokenizer_grammar: "tokenizer.ascii_proto"
verbalizer_grammar: "verbalizer.ascii_proto"
sentence_boundary_regexp: "[\\.:!\\?] "
sentence_boundary_exceptions_file: "sentence_boundary_exceptions.txt"
I0806 17:48:56.863541 22 model_lifecycle.cc:839] "successfully loaded 'conformer-zh-CN-asr-streaming-asr-bls-ensemble'"
I0806 17:48:56.863869 22 server.cc:604]
| Repository Agent | Path |
I0806 17:48:56.863930 22 server.cc:631]
| Backend | Path | Config |
| tensorrt | /opt/tritonserver/backends/tensorrt/libtriton_tensorrt.so | {"cmdline":{"auto-complete-config":"false","backend-directory":"/opt/tritonserver/backends","min-compute-capability":"5.300000","default-max-batch-size":"4"}} |
| riva_nlp_pipeline | /opt/tritonserver/backends/riva_nlp_pipeline/libtriton_riva_nlp_pipeline.so | {"cmdline":{"auto-complete-config":"false","backend-directory":"/opt/tritonserver/backends","min-compute-capability":"5.300000","default-max-batch-size":"4"}} |
| riva_asr_ensemble_pipeline | /opt/tritonserver/backends/riva_asr_ensemble_pipeline/libtriton_riva_asr_ensemble_pipeline.so | {"cmdline":{"auto-complete-config":"false","backend-directory":"/opt/tritonserver/backends","min-compute-capability":"5.300000","default-max-batch-size":"4"}} |
I0806 17:48:56.864079 22 server.cc:674]
| Model | Version | Status |
| conformer-zh-CN-asr-streaming-asr-bls-ensemble | 1 | READY |
| riva-punctuation-zh-CN | 1 | READY |
| riva-trt-conformer-zh-CN-asr-streaming-am-streaming | 1 | READY |
| riva-trt-riva-punctuation-zh-CN-nn-bert-base-chinese | 1 | UNAVAILABLE: Internal: unable to create TensorRT context: ICudaEngine::createExecutionContext: Error Code 1: Myelin ([cask_fusion.cpp:initialize_cask_fusion:381] Cask unknown internal error) |
I0806 17:48:56.864311 22 tritonserver.cc:2598]
| Option | Value |
| server_id | triton |
| server_version | 2.50.0 |
| server_extensions | classification sequence model_repository model_repository(unload_dependents) schedule_policy model_configuration system_shared_memory cuda_shared_memory binary_tensor_data parameters statistics trace logging |
| model_repository_path[0] | /data/models |
| model_control_mode | MODE_NONE |
| strict_model_config | 1 |
| model_config_name | |
| rate_limit | OFF |
| pinned_memory_pool_byte_size | 268435456 |
| cuda_memory_pool_byte_size{0} | 1000000000 |
| min_supported_compute_capability | 5.3 |
| strict_readiness | 1 |
| exit_timeout | 30 |
| cache_enabled | 0 |
I0806 17:48:56.864376 22 server.cc:305] "Waiting for in-flight requests to complete."
I0806 17:48:56.864396 22 server.cc:321] "Timeout 30: Found 0 model versions that have in-flight inferences"
I0806 17:48:56.865070 22 server.cc:336] "All models are stopped, unloading models"
I0806 17:48:56.865094 22 server.cc:345] "Timeout 30: Found 3 live models and 0 in-flight non-inference requests"
I0806 17:48:56.865269 22 pipeline_library.cc:31] "TRITONBACKEND_ModelInstanceFinalize: delete instance state"
I0806 17:48:56.865304 22 tensorrt.cc:353] "TRITONBACKEND_ModelInstanceFinalize: delete instance state"
I0806 17:48:56.865586 22 pipeline_library.cc:29] "TRITONBACKEND_ModelInstanceFinalize: delete instance state"
I0806 17:48:56.880498 22 pipeline_library.cc:27] "TRITONBACKEND_ModelFinalize: delete model state"
I0806 17:48:56.880695 22 model_lifecycle.cc:624] "successfully unloaded 'riva-punctuation-zh-CN' version 1"
I0806 17:48:57.043164 22 tensorrt.cc:274] "TRITONBACKEND_ModelFinalize: delete model state"
I0806 17:48:57.052405 22 model_lifecycle.cc:624] "successfully unloaded 'riva-trt-conformer-zh-CN-asr-streaming-am-streaming' version 1"
I0806 17:48:57.663857 22 pipeline_library.cc:25] "TRITONBACKEND_ModelFinalize: delete model state"
I0806 17:48:57.664118 22 model_lifecycle.cc:624] "successfully unloaded 'conformer-zh-CN-asr-streaming-asr-bls-ensemble' version 1"
I0806 17:48:57.865448 22 server.cc:345] "Timeout 29: Found 0 live models and 0 in-flight non-inference requests"
error: creating server: Internal - failed to load all models
> Triton server died before reaching ready state. Terminating Riva startup.
Check Triton logs with: docker logs
/opt/riva/bin/start-riva: line 1: kill: (22) - No such process
