I’m trying to generate XRDF file for cuMotion planner in MoveIt2 for my custom robot. The USD file is generated in Isaac Sim 6.0.1 using the import function with options:
- robot type: manipulator
- base_type: fixed
The output USD file has the articulaton root assigned to base_link_intertia prim, so it is present in the robot’s model. However I cannot find it in the cuMotion / Lula Robot Description Editor. When I add the articulation root to the physics folder it’s available but no link can be selected.
I have two questions. Where the articulation root should be added in the USD model so that I can select it in the editor’s panel and also the links selection works. Secondly, is it possible to generate USD file from URDF with flat stage hierarchy? Robot models, which are available in Content tab, like UR10e or FrankaPanda have a flat hierarchy with all links being at the same level and they work pretty fine with Lula Robot Description Editor.
Thank you in advance for support.
Peter
Hello @VisteK528,
Welcome to the Isaac ROS forum and thanks for the pose!
I’ll address both of your questions below.
Where to add the articulation root
The articulation root needs to be on the outermost Xform prim of your robot, the prim that sits above all the links and joints, not on a link prim like base_link_inertia. That’s why the editor can see the articulation but can’t enumerate the links from it.
To fix it:
- In the Stage panel, select base_link_inertia.
- In the Properties panel → Physics section, delete the Articulation Root entry.
- Select the top-level robot Xform prim (the root of the entire robot hierarchy, one level above your links). Right-click → Add > Physics > Articulation Root.
- Save the USD.
Also: the Select Link dropdown only populates while the stage is Playing. Open a clean stage, drag in the robot USD, press Play, then open Tools > Robotics > Lula Robot Description Editor.
Generating a flat hierarchy from URDF
There is no “Create Flat Stage Hierarchy” option in the URDF Importer dialog in Isaac Sim 6.0.1. The reference robots (UR10e, FrankaPanda) ship as pre-built USD files with flat hierarchies, not imported via that option. The most reliable way to get a flat hierarchy is to preprocess your URDF before importing. Many ROS-Industrial URDFs (including UR series) use a base_link → base_link_inertia fixed-joint pattern that creates the nested hierarchy. Remove it:
<!-- Remove this pattern -->
<link name="base_link"/>
<link name="base_link_inertia">
<inertial>...</inertial>
<visual>...</visual>
<collision>...</collision>
</link>
<joint name="base_link-base_link_inertia" type="fixed">
<parent link="base_link"/>
<child link="base_link_inertia"/>
</joint>
<!-- Replace with a single link -->
<link name="base_link">
</link>
After importing the cleaned URDF, place the ArticulationRoot on the top-level robot Xform as described in Q1, and the Lula Robot Description Editor should be able to enumerate all links.
Thanks for your answer. However the problem is still present. As I have stated, my model has the articulation root on the base_link and it was added by the URDF importer. I possible to remove it, but I can’t add the articulation root to my topmost xprim (which is ur10e_robotiq_base), there is no such option when I click Property → Add → Physics.
One thing I found out is that after importing the URDF file I have to disable and then again enable the articulation root and then the cuMotion Robot Description Editor sees the articulation root, however only one link (child of base_link - base_link_intertia) is available for selection. My model’s structure looks like this:
PS
I am checking everything with simulation running.
Could you share the URDF you imported, its referenced meshes, and the complete generated USD package, including any referenced layers?
With these files, it will be easier for us to help you investigate the articulation discovery and link-selection behavior and see how we can help resolve the issue.
@vchuang The problem disappeared when I switched to Isaac Sim 6.1.0 and now the editor works fine so I think It won’t be necessary. Nevertheless, thank you for your support.
Thanks for confirming! Since the issue is resolved, we’ll go ahead and close this topic. Feel free to open a new one if you have any other issues.
Thanks for sharing this issue. I hope you find a solution soon!
