Jetsen-TX2
JetPack4.2.2
I can’t set the RTC clock with the command “sudo hwclock -w”. The steps are as follows:
sudo date -s “2019-11-26 12:00:00”
sudo hwclock -w
sudo hwclock -r
I used the command “sudo hwclock -r” to read the RTC time, but found that the RTC clock has not changed.
Have a try below command.
sudo timedatectl set-time ‘2019-11-26 12:00:00’
Hello ShaneCCC
thanks for your suggestion.
After running this command, the system prompts “Failed to set time: Automatic time synchronization is enabled”
Have below command to disable the auto time sync first.
sudo timedatectl set-ntp no
Hello ShaneCCC
First disable automatic time synchronization with the command and then set the RTC time, so that the RTC clock can be modified successfully.
If i use the function to set RTC, how to operate /dev/rtc0?
I operate /dev/rtc0 with the following code, but I can’t set RTC
int rtc_set(struct rtc_time *rtc)
int fd, retval;
fd = open("/dev/rtc0", O_WRONLY);
if (fd == -1)
return -1;
retval = ioctl(fd,RTC_SET_TIME, rtc);
if (retval == -1)
return -2;
close(fd);
return 0;
Did you run it with supervisor mode?
Hello ShaneCCC
I run it with root privileges,How to use supervisor mode?
root privileges is what I said supervisor mode.
You may need to trace why the RTC_SET_TIME failed. Also have try to open /dev/rtc.
I try to open /dev/rtc, and I can set RTC successfully.
