Cannot set up BFB image on SuperNIC or SSH into ARM Core
I followed the Administrator Quick Start guide to set up a Bluefield 3 DPU successfully. However, I cannot set up a Bluefield 3 SuperNIC when following the same instructions.
I was able to see the IP address for the ARM core before starting any of these instruction, but I no longer can. I believe the step that went wrong was Step 5 - “Transferring the BFB image”.
When I run the following command:
curl -k -u root:<password> -H "Content-Type: application/octet-stream" -X GET https://<DPU-BMC-IP>/redfish/v1/UpdateService/FirmwareInventory/DPU_OS, I see “Version”: “”, even after several hours, which suggests to me that the BFB image is not being updated correctly. Is there a different BFB image that needs to be used for SuperNICs? Is it not possible to SSH into the ARM core for SuperNICs? How are SuperNICs meant to be used?
BlueField SuperNIC is shipped by default in ‘NIC Mode’ (ARM cores disabled).
please follow this guide - NIC Mode Installation - NVIDIA Docs
